查看: 1393|回复: 1
引线---麻烦朋友帮小修改一下,
发表于 2015-8-1 20:41:02 | 显示全部楼层 |阅读模式
这是论坛上一个朋友帮忙写的,,可惜已联系不上他。麻烦朋友们帮忙改下----我想要引线的第二点到第三点始终水平,不知道能不能做到 ,谢谢
(defun c:lee (/ ent txt pt1 pt1x pt1y pt2 pt2x pt2y pt3 pt3x pt3y yxfx)
  (setvar "cmdecho" 0)
  (command "_undo" "_be")
  (setq zigao 2.25);设置字高
  (setq zitiyangshi "ROMANS");设置字体样式名称
  (setq ziti "hzasc,hztxt");设置字体
  (if (= (tblsearch "style" zitiyangshi) nil) ; 判断是否存在HZ字体样式
  (command "style" zitiyangshi ziti "0" "0.7" "0.0" "" "" ""); 新建HZ字体样式
  (if (= (tblsearch "layer" "dim") nil) ; 判断是否存在dim图层
    (command "layer" "N" "dim" "C" 1 "dim" ""); 新建dim层
  (if (= (tblsearch "layer" "TXT7") nil) ; 判断是否存在TXT7图层
    (command "layer" "N" "TXT7" "C" 7 "TXT7" ""); 新建TXT7层
  (yinxian)
  (setq ent (entlast))
  (if (> pt2x pt3x)
      (setq yxfx "HL")
      (setq yxfx "HR")
  (setq txt (cdr (assoc 1 (entget (car (entsel "选择已有文字"))))))
  (cond ((= yxfx "HL");;条件1:引线方向水平向左
         (entmake (list '(0 . "text") '(8 . "TXT7") '(10 0.0 0.0 0.0)
                        (list 11 (- pt3x (getvar "dimscale")) pt2y 0.0)
                        (cons 7 zitiyangshi) (cons 40 (* zigao (getvar "dimscale"))) '(41 . 0.7) (cons 1 txt)
                        '(72 . 2) '(73 . 2) ))
        ((= yxfx "HR");;条件1:引线方向水平向右
                        (list 11 (+ pt3x (getvar "dimscale")) pt2y 0.0)
                        '(72 . 0) '(73 . 2) ))
  );end cond
  (command "_undo" "_e")
  (princ "\n ok")
);end main
(defun yinxian()
  (setq pt1 (getpoint "\n选择引线第一点"))
  (setq        pt1x (car pt1)
        pt1y (cadr pt1)
  (setq pt2 (getpoint pt1 "\n选择引线第二点"))
  (setq        pt2x (car pt2)
        pt2y (cadr pt2)
  (setq pt3 (getpoint pt2 "\n选择引线第三点"))
  (setq        pt3x (car pt3)
        pt3y (cadr pt3)
  (entmake (list '(0 . "LEADER") (cons 100 "AcDbEntity") (cons 8 "dim")
                 (cons 100 "AcDbLeader")
                 (cons 3 (rtos (getvar "dimscale"))) '(71 . 1)
                 '(73 . 3) '(74 . 1)'(76 . 3)
                 (list 10 pt1x pt1y 0.0)
                 (list 10 pt2x pt2y 0.0)
                 (list 10 pt3x pt2y 0.0)
  );end entmake
);end defun yinxian
 楼主| 发表于 2015-8-1 21:28:12 | 显示全部楼层
没人帮顶啊,,我愿意付费,,朋友们棒棒忙
GMT+8, 2025-5-24 05:52 , Processed in 0.168638 second(s), 28 queries , Gzip On.
