查看: 677|回复: 1
[提问] 请教程序问题在哪里?
发表于 2015-8-3 14:40:26 | 显示全部楼层 |阅读模式
下面是填充开关的程序,请教为什么图里只要有两个完全一样的填充时,该填充就不能被关闭和打开?
(defun c:tt ( / n x)
  (vl-load-com)
  (foreach n (mapcar
       '(lambda (x)(l_dxf 8 (entget x))      )
       (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget "x" '((0 . "HATCH"))))))
    (if
      (=(vla-get-layeron
      (vla-item
       (vla-get-layers
         (vla-get-activedocument   (vlax-get-acad-object))
        n
    ) :vlax-true)
    (vla-put-layeron
      (vla-item
       (vla-get-layers
        n
      :vlax-false
      (vla-put-layeron
      (vla-item
       (vla-get-layers
        n
      :vlax-true
(defun l_dxf (cd eent) (cdr(assoc cd eent)))
 楼主| 发表于 2015-8-4 10:47:22 | 显示全部楼层
自己顶一下
GMT+8, 2025-7-16 03:43 , Processed in 0.170093 second(s), 32 queries , Gzip On.
