- 积分
- 195983
- 明经币
- 个
- 注册时间
- 2009-5-21
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2015-8-11 13:34:33
显示全部楼层
;快速填充 by ucuc2003
(defun C:TT5 (/ s1) ;快速选择对象,填充图案
(setvar "cmdecho" 0)
(princ "\n创建独立填充图案,请选择填充区: (***跳过则为拾取内部点填充):")
(setq ytc_d (getvar "hpseparate"))
(setvar "hpassoc" 1) ;控制填充图案是否关联(1:是;0:否)
(setq s1 (cadr (ssgetfirst)))
(while (tt7_1))
);defun
(defun tt7_1 ()
(defun *Error* (msg)
(if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,*EXIT*,")))
(setvar "hpseparate" 0);程序中断/出错则执行(setvar "hpseparate" 0)
(princ "退出!"));progn
);if
);defun *Error*
(princ "\n请选择填充对象:(***跳过则为拾取内部点填充)")
(setvar "hpseparate" 1) ;控制是否创建独立填充图案(1:是;0:否)
(if (or s1 (setq s1 (ssget)))
(progn (command "bhatch" "s" s1 "" "")(setq s1 nil))
(princ "\n请拾取填充内部点:")
(command "bhatch" pause pause)
);progn
);if
(setvar "hpseparate" ytc_d)
