查看: 12230|回复: 39
[源码] 源码学习 间隙分割,异等偏移,定距等分
发表于 2015-8-11 14:30:41 | 显示全部楼层 |阅读模式
  1. ;;;http://bbs.mjtd.com/thread-113876-1-1.html
  2. ;;;间隙分割,异等偏移,定距等分
  3. ;;;by荒野孤行,修改ucuc2003
  4. (defun c:TT5 (/ o_DIMZIN os sel len gap npy a)
  5.   (princ"定距等分")
  6.   (setvar "cmdecho" 0)
  7.   (setq o_DIMZIN (getvar "DIMZIN"))
  8.   (setq os (getvar "osmode"))
  9. (defun *Error* (msg);出错处理
  10.     (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,*EXIT*,")))
  11.       (progn
  12.         (setvar "DIMZIN" o_DIMZIN)
  13.         (setvar "osmode" os)
  14.       )
  15.     )
  16. )
  17.   (setvar "osmode" 15359)
  18.   (setvar "DIMZIN" 8)
  19.   (if (= djdf_oldlen nil) (setq djdf_oldlen 1000))
  20.   (princ (strcat "\n指定等分总距离<" (rtos djdf_oldlen 2 7) ">: "))
  21.   (setq len (getdist))
  22.   (if len (setq djdf_oldlen len) (setq len djdf_oldlen))
  23.   (if (= djdf_oldgap nil) (setq djdf_oldgap 50))
  24.   (princ (strcat "\n指定固定间距<" (rtos djdf_oldgap 2 7) ">(这个值不能大于等分总距离" (rtos len 2 7) "): "))
  25.   (setq gap (getdist))
  26.   (if gap (setq djdf_oldgap gap) (setq gap djdf_oldgap))
  27.   (if (> gap len)
  28.     (progn (alert "请按照规定重新输入!") (exit))
  29.   )
  30.   (setq a (1+ (fix (/ len gap))))
  31.   (if (= djdf_olddfs nil) (setq djdf_olddfs 10))
  32.   (princ (strcat "\n指定等分数<" (rtos djdf_olddfs 2 7) ">(这个值不能大于" (rtos a 2 7) "):"))
  33.   (setq npy (getint))
  34.   (if npy (setq djdf_olddfs npy) (setq npy djdf_olddfs))
  35.   (setvar "DIMZIN" o_DIMZIN)
  36.   (if (> npy a)
  37.     (progn (alert "请按照规定重新输入!") (exit))
  38.   )
  39. ;(while
  40.   (while
  41.     (progn
  42.       (setq sel (entsel "\n请点选(直线、多段线、圆弧、圆、射线、或构造线):"))
  43.       (not (if (= sel nil)
  44.              nil
  45.              (wcmatch (cdr (assoc 0 (entget (car sel)))) "LWPOLYLINE,POLYLINE,LINE,XLINE,RAY,SPLINE,CIRCLE,ARC") ;实体类型必须为大写
  46.            )
  47.       )
  48.     )
  49.     (princ"\n未选取任何图元,请重新点选:")
  50.   )
  51.   (setq len (/ (- len (* (- npy 1) gap)) npy))
  52.   (initget 1)
  53.   (setq pt1 (getpoint "\n指定等分偏移方向:"))
  54.   (setvar "osmode" 0)
  55.   (setq len1 len
  56.         gap1 gap
  57.   )
  58.   (command "undo" "be")
  59.   (repeat (- npy 1)
  60.     (command "OFFSET" len sel pt1 "")
  61.     (setq gap (+ gap1 len))
  62.     (command "OFFSET" gap sel pt1 "")
  63.     (setq len (+ len1 gap))
  64.   )
  65.   (command "OFFSET" len sel pt1 "")
  66.   (setvar "osmode" os)
  67.   (command "undo" "e")
  68. ;);while
  69.   (princ)
  70. )
源码学习: 《间隙分割,异等偏移,定距等分》
修改了下,增加了自动记忆功能,以及判断等分数,重新发帖
鸣谢原帖作者:荒野孤行
love1030312 + 1 很给力!
相关帖子
发表于 2016-11-1 12:49:17 | 显示全部楼层
大神,能不能把标尺寸的插件发一下啊,
发表于 2019-4-26 08:22:51 | 显示全部楼层
大佬,能麻烦修改下源码嘛,点选对象改成捕捉对角点支持横向竖向,然后。输入等分距离,然后等分数量,空格结束我觉得这样方便点,更快
发表于 2023-3-23 06:20:49 来自手机 | 显示全部楼层
alexmai 发表于 2017-11-29 18:43
如果要实现这种等分,应如何操作?
这个功能实现了吗
发表于 2016-5-16 15:40:18 | 显示全部楼层
顶顶顶!!
发表于 2016-11-1 14:15:30 | 显示全部楼层
感谢 ucuc2003 分享程序!!!!
发表于 2017-10-26 08:43:23 | 显示全部楼层
回帖是一种美德!感谢楼主的无私分享 谢谢
发表于 2017-10-27 10:12:57 | 显示全部楼层
这个修改非常好用了  感谢 感谢
发表于 2017-10-27 11:07:21 | 显示全部楼层
很有用啊,感谢楼主分享
发表于 2017-10-27 11:58:33 | 显示全部楼层
很好的程序,顶楼主
GMT+8, 2025-8-12 10:08 , Processed in 0.326383 second(s), 38 queries , Gzip On.
