- 积分
- 14125
- 明经币
- 个
- 注册时间
- 2013-9-7
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
还在为图档中零长度的线而烦恼吗?这个程序可以帮您解除烦忧。请见演示图片:
;;;*****选出零长度的线 程序开始****
(defun c:t1 ()
(setvar "cmdecho" 0)
(princ "\n★功能:查找出零长度的短线并置于特定图层.\n")
(vl-load-com) (command "undo" "be")
(initget 6)
(if
(not
(setq maxlen (getreal "\n要查找的线段最大长度为:<0.0001>"))
(setq maxlen 0.0001)
(setq ss (ssget '((0 . "ARC,*POLYLINE,LINE,CIRCLE,SPLINE"))))
(setq i 0
j 0
(setq laystr (strcat "层-长度小于" (rtos maxlen) "的线"))
(command "LAYER" "M" laystr "C" "1" laystr "")
(repeat (sslength ss)
(setq entnam (ssname ss i))
(setq obj (vlax-ename->vla-object entnam))
(if
(< (vlax-curve-getdistatparam
obj
(vlax-curve-getendparam obj)
maxlen
(vla-put-layer obj laystr)
(setq j (+ j 1))
(setq i (+ i 1))
(princ (strcat "\n★提示:共将满足条件的"
(itoa j)
"条线置于 "
laystr
" 图层.\n"
(command "undo" "e")(princ)
;;;*****选出零长度的线 程序结束****
