查看: 1207|回复: 0
[提问] cad标注问题(一个开源程序)
发表于 2015-8-18 15:57:09 | 显示全部楼层 |阅读模式
桥梁上面的一个插件,在使用  钢束大样   标注时,一直用不了:提示
”选择水平标注位置:; 错误: 参数类型错误: numberp: nil “。
程序为 同济建筑设计院的 开源程序,已联系不上作者。求高手看看。
  1. ———— 预应力工具
  2. ;;;===============================================================================
  3. ;;;-------------------------------------------------------------------------------
  4. ;;; 钢束初始化
  5. ;;; 功能:定义钢束
  6. ;;;-------------------------------------------------------------------------------
  7. (defun c:gscsh(/ id whatnext tendonno count tcount tendonid tendonsty tendonstylst constress prelength orientstyle position symmertry
  8.         ename entlst vlaobj pto orient ptold orientold orientucs tcountold)
  9.   (defun showerrtile()
  10.     (cond
  11.       ((or (null ename)(/= "LWPOLYLINE" (cdr (assoc 0 (entget ename)))))
  12.         (mode_tile "accept" 1)
  13.         (set_tile "error" "未选中有效曲线!"))
  14.       (t
  15.         (mode_tile "accept" 0)
  16.         (set_tile "error" "OK!"))))
  17.   (setq id            (load_dialog "BRTools.dcl")
  18.       tendonstylst '((0 . "15.20") (1 . "12.70") (2 . "11.10") (3 . "9.50") (4 . "JL18") (5 . "JL25") (6 . "JL32") (7 . "JL40")))
  19.   (mapcar 'set '(whatnext tendonno count tcount constress prelength orientstyle position symmertry tendonid tendonsty) '(2 "N1" 1 12 1395 700 "currentucs" "both" "0" 0 "15.20"))
  20.   (setq pto      '(0.0 0.0 0.0)
  21.       ptold     pto
  22.       orient    (MAT:UnitVec2P '(0.0 0.0 0.0) (append (mapcar '+ '(0.0 0.0) (getvar "UCSXDIR")) '(0.0)))
  23.       orientold orient
  24.       orientucs orient
  25.       tcountold tcount)
  26.   (while (>= whatnext 2)
  27.     (new_dialog "SETTENDON" id)
  28.     (mapcar 'set_tile
  29.       '("tendonno" "count" "tendonsty" "constress" "prelength" "orientstyle" "position" "symmertry" "originmsg" "orientmsg")
  30.       (list tendonno (itoa count) (itoa tendonid) (rtos constress 2) (rtos prelength 2) orientstyle position symmertry (vl-princ-to-string pto) (vl-princ-to-string orient)))
  31.     (LT:BUTTON-POINT-PICK "pickorigin" T)
  32.     (LT:BUTTON-SELECT-PICK "picktondon" T)
  33.     (if (= "currentucs" orientstyle)
  34.       (progn
  35.         (mode_tile "pickorient" 1)
  36.         (LT:BUTTON-POINT-PICK "pickorient" nil))
  37.       (progn
  38.         (mode_tile "pickorient" 0)
  39.         (LT:BUTTON-POINT-PICK "pickorient" T)))
  40.     (if (> tendonid 3)
  41.       (progn (mode_tile "tcount" 1) (set_tile "tcount" (itoa tcountold)))
  42.       (progn (mode_tile "tcount" 0) (set_tile "tcount" (itoa tcount))))
  43.     (showerrtile)
  44.     (action_tile "tendonno" "(setq tendonno $value)")
  45.     (action_tile "count" "(setq count (atoi $value))")
  46.     (action_tile "tcount" "(setq tcount (atoi $value))")
  47.     (action_tile "tendonsty" "(setq tendonid (atoi $value) tendonsty (cdr (assoc tendonid tendonstylst)))(if (> (atoi $value) 3) (progn (mode_tile "tcount" 1) (setq tcountold tcount tcount 0))(progn (mode_tile "tcount" 0) (setq tcount tcountold)))")
  48.     (action_tile "constress" "(setq constress (atof $value))")
  49.     (action_tile "prelength" "(setq prelength (atof $value))")
  50.     (action_tile "currentucs" "(setq orientstyle (get_tile "orientstyle") orientold orient orient orientucs)(set_tile "orientmsg" (vl-princ-to-string orient))(mode_tile "pickorient" 1)(LT:BUTTON-POINT-PICK "pickorient" nil)")
  51.     (action_tile "manualorient" "(setq orientstyle (get_tile "orientstyle") orient orientold ) (set_tile "orientmsg" (vl-princ-to-string orient)) (mode_tile "pickorient" 0)(LT:BUTTON-POINT-PICK "pickorient" T)")
  52.     (action_tile "start" "(setq position (get_tile "position"))(mode_tile "symmetry" 1)(setq symmetry "0")")
  53.     (action_tile "end" "(setq position (get_tile "position"))(mode_tile "symmetry" 1)(setq symmetry "0")")
  54.     (action_tile "both" "(setq position (get_tile "position"))(mode_tile "symmetry" 0)(setq symmetry (get_tile "symmertry"))")
  55.     (action_tile "symmetry" "(setq symmertry $value)")
  56.     (action_tile "pickorient" "(done_dialog 4)")
  57.     (action_tile "pickorigin" "(done_dialog 3)")
  58.     (action_tile "picktondon" "(done_dialog 2)")
  59.     (action_tile "help" "(help "BRTools" "4_cmd_04_01_gscsh")")
  60.     (setq whatnext (start_dialog))
  61.     (cond
  62.       ((= 4 whatnext)
  63.         (setq orientold orient)
  64.         (if (setq orient (getpoint (trans pto 0 1) "\n选择方向:"))
  65.           (setq orient    (append (mapcar '+ '(0.0 0.0) (trans orient 1 0)) '(0.0))
  66.               orient    (MAT:UnitVec2P pto orient)
  67.               orientold orient)
  68.           (setq orient orientold)))
  69.       ((= 3 whatnext)
  70.         (setq ptold pto)
  71.         (if (setq pto   (getpoint "\n请输入钢束参考点:"))
  72.           (setq pto   (append (mapcar '+ '(0.0 0.0) (trans pto 1 0)) '(0.0))
  73.               ptold pto)
  74.           (setq pto ptold)))
  75.       ((= 2 whatnext)
  76.         (and
  77.           (setq ename (car (entsel "\n选择一条曲线:")))
  78.           (CK:TendonP ename)
  79.           (mapcar
  80.             '(lambda(x1 x2 x3) (set x1 (BR:GetXdata ename x2 x3)))
  81.             '(tendonno tendonsty tcount count prelength constress position symmetry)
  82.             '(1000 1000 1070 1070 1040 1040 1000 1000)
  83.             '("tendonno" "tendonsty" "tcount" "count" "prelength" "constress" "tenposition" "symmetrystyle"))
  84.           (setq pto    (BR:GetOrigin ename)
  85.               orient (BR:GetOrient ename))))
  86.       ((= 1 whatnext)
  87.         (LA:Rebar)
  88.         (setq entlst (entget ename)
  89.             vlaobj (vlax-ename->vla-object ename)
  90.             entlst (subst (cons 8 "REBAR") (assoc 8 entlst) entlst))
  91.         (entmod entlst)
  92.         (and (minusp (MAT:DotProduct orient (mapcar '- (vlax-curve-getEndPoint vlaobj) (vlax-curve-getStartPoint vlaobj)))) (MD:RevLwPl ename))
  93.         (mapcar
  94.           '(lambda(x1 x2 x3) (BR:SetXdata ename x1 x2 x3))
  95.           '(1000 1000 1070 1070 1040 1040 1000 1000)
  96.           '("tendonno" "tendonsty" "tcount" "count" "prelength" "constress" "tenposition" "symmetrystyle")
  97.           (list tendonno tendonsty tcount count prelength constress position symmertry))
  98.         (BR:SetOrigin ename pto)
  99.         (BR:SetOrient ename orient))
  100.       ((= 0 whatnext)(princ "\n操作取消!"))))
  101.   (unload_dialog id)
  102.   (princ))
  103. ;;;-------------------------------------------------------------------------------
  104. ;;; 钢束大样
  105. ;;; 功能:对预应力钢束大样进行标注
  106. ;;;-------------------------------------------------------------------------------
  107. (defun c:gsdy (/ ename refename pt prolst dstyle)
  108.   (and
  109.     (setq ename (car (entsel "\n请选择钢束曲线:")))
  110.     (progn
  111.       (redraw ename 3)
  112.       (= "LWPOLYLINE" (cdr (assoc 0 (entget ename)))))
  113.     (setq refename (car (entsel "\n请选择标注参考线:")))
  114.     (progn
  115.       (redraw refename 3)
  116.       (member (cdr (assoc 0 (entget refename))) '("LWPOLYLINE" "LINE")))
  117.     (cond
  118.       ((CK:TendonP ename)(setq prolst (list (BR:GetOrient ename) (BR:GetXdata ename 1040 "prelength") (BR:GetXdata ename 1000 "tenposition") (BR:GetXdata ename 1000 "symmetrystyle"))))
  119.       (t (setq prolst (DL:GetTondonProLst '((0 . 700) (1 . "both") (2 . "1"))))))
  120.     (setq pt (trans (getpoint "\n选择水平标注位置:") 1 0))
  121.     (setq dstyle (getvar "DIMSTYLE"))
  122.     (progn
  123.       (or (tblsearch "DIMSTYLE" (strcat dstyle "$4")) (DSTYLE:Radial-Current))
  124.       (LA:CurNote)
  125.       (LA:CurCEN)
  126.       (LA:CurDim)
  127.       (LA:Rebar)
  128.       (BLK:PRESANCHOR)
  129.       (BLK:PRESTENSION)
  130.       (SET:SC))
  131.     (DR:TondonDim ename refename pt dstyle prolst))
  132.   (and ename (redraw ename 4))
  133.   (and refename (redraw refename 4))
  134.   (princ))
  135. ;;;-------------------------------------------------------------------------------
  136. ;;; 钢束导线
  137. ;;; 功能:画出钢束导线
  138. ;;;-------------------------------------------------------------------------------
  139. (defun c:gsdx(/ r ss ename entlst i)
  140.   (setq r    (getvar "FILLETRAD"))
  141.   (and
  142.     (setq ss (ssget '((0 . "LWPOLYLINE"))))
  143.     (progn
  144.       (LA:CurCen)
  145.       (setvar "CMDECHO" 0)
  146.       (setvar "FILLETRAD" 0.0)
  147.       (setq i 0))
  148.     (repeat (sslength ss)
  149.       (setq entlst (entget (ssname ss i))
  150.           i      (1+ i)
  151.           entlst (vl-remove-if '(lambda(x) (member (car x) '(-1 5 330 ))) entlst))
  152.       (entmake entlst)
  153.       (setq ename (entlast))
  154.       (vl-cmdf "fillet" "P" ename)
  155.       (vlax-put-property (vlax-ename->vla-object ename) 'LAYER *CLACEN*))
  156.     (setvar "FILLETRAD" r))
  157.   (princ))
  158. ;;;-------------------------------------------------------------------------------
  159. ;;; 钢束放样
  160. ;;; 功能:
  161. ;;;-------------------------------------------------------------------------------
  162. (defun c:gsfy()
  163.   (princ))
  164. ;;;-------------------------------------------------------------------------------
  165. ;;;===============================================================================
  166. ;;;菜单命令 ———— 钢结构工具
  167. ;;;===============================================================================
GMT+8, 2025-5-17 19:55 , Processed in 0.193982 second(s), 30 queries , Gzip On.
