查看: 956|回复: 1
[源码] 图框程序,加个标题求教
发表于 2015-8-28 10:27:50 | 显示全部楼层 |阅读模式
  1. ;;;--------------------------------------------------------------
  2. ;;;功  能:根据给定的左下角和右上角坐标绘制图框
  3. ;;;--------------------------------------------------------------
  4. (defun c:mf ()
  5.     (setq oldosmode (getvar "osmode"))
  6.     (setq oldcmdecho (getvar "cmdecho"))
  7.     (setvar "osmode" 0)      ;指定目标捕捉模式
  8.     (setvar "cmdecho" 0)
  9.     (command)
  10.     (command ".style" "TUKUANG" "文鼎CS细等线" 0 1 0 "N" "N")
  11.     (command)
  12. ;;;设定绘图比例尺
  13.     (setq
  14.   mapscale (getint "输入出图比例尺(1:1000输1;1:2000输2):>")
  15.     )
  16. ;;;设定初始图框
  17.     (print)
  18.     (setq selborder (entsel "请选择初始图框:>"))
  19.     (setq border (entget (car selborder)))
  20. ;;;    (entdel (car selborder))
  21.     (setq index 0
  22.     xmin 999999999.9
  23.     ymin 999999999.9
  24.     xmax -999999999.9
  25.     ymax -999999999.9)
  26.     (repeat (length border)
  27.   (setq xy1 (nth index border))
  28.   (setq index (1+ index))
  29.   (if (= (car xy1 ) 10)
  30.       (progn
  31.     (setq x (cadr xy1)
  32.           y (caddr xy1))
  33.     (if (> xmin x) (setq xmin x))
  34.     (if (> ymin y) (setq ymin y))
  35.     (if (< xmax x) (setq xmax x))
  36.     (if (< ymax y) (setq ymax y)))
  37.       )
  38.   )
  39.
  40.     (setq leftdownx xmin)
  41.     (setq leftdowny ymin)
  42.     (setq leftdownxy (list leftdownx leftdowny))
  43.     (setq outleftdownxy
  44.        (list (- leftdownx (* 10 mapscale))
  45.        (- leftdowny (* 10 mapscale))
  46.        )
  47.     )
  48.     (print)
  49.     (setq rightupx xmax)
  50.     (setq rightupy ymax)
  51.     (setq rightupxy (list rightupx rightupy))
  52.     (setq outrightupxy
  53.        (list (+ rightupx (* 10 mapscale))
  54.        (+ rightupy (* 10 mapscale))
  55.        )
  56.     )
  57.     (print)
  58.     (if  (= (strlen (rtos (fix leftdowny))) 8)
  59.   (progn
  60.       (setq zoneid (atof (substr (rtos (fix leftdowny)) 1 2)))
  61.       (setq centerm (* (/ (* zoneid 3) 180.0) pi))
  62.   )
  63.   (progn
  64.       (setq centerm (getreal "本投影带(3°带)中央经线........"))
  65.       (setq centerm (* (/ centerm 180.0) pi))
  66.   )
  67.     )
  68.     (print)
  69.     (entdel (car selborder))
  70.     (command "_rectang" leftdownxy rightupxy)
  71.     (command)
  72.     (setq inframe (entget (entlast)))
  73.     (setq inframe (subst (cons 8 "图框")
  74.        (assoc 8 inframe)
  75.        inframe))
  76.     (entmod inframe)
  77.     (command "_rectang" outleftdownxy outrightupxy)
  78.     (command)
  79.     (setq outframe (entget (entlast)))
  80.     (setq outframe (subst (cons 43 (* 2 mapscale))
  81.         (assoc 43 outframe)
  82.         outframe
  83.        )
  84.     )
  85.     (setq outframe (subst (cons 8 "图框")
  86.         (assoc 8 outframe)
  87.         outframe))
  88.     (entmod outframe)
  89. ;;;    取netdist的整数位置
  90.     (setq netdist (* 100 mapscale))
  91.     (setq intnetdistx (fix (/ leftdownx netdist)))
  92.     (setq intnetdisty (fix (/ leftdowny netdist)))
  93.     (setq f1x (* netdist intnetdistx))
  94.     (setq f1y (* netdist intnetdisty))
  95. ;;;绘制方格网
  96.     (setq index 1)
  97.     (setq crosswide (* 10 mapscale))
  98.     (setq no_y (1+ (fix (/ (- rightupy leftdowny) netdist))))
  99.     (setq no_x (1+ (fix (/ (- rightupx leftdownx) netdist))))
  100.     (setq fy 0)
  101.     (while (< fy (- rightupy netdist))
  102.   (setq index0 1)
  103.   (setq fy (+ f1y (* index netdist)))
  104.   (setq index (1+ index))
  105.   (setq fx 0)
  106.   (while (< fx (- rightupx netdist))
  107.       (setq fx (+ f1x (* index0 netdist)))
  108.       (drawcross fx fy mapscale)
  109.       (setq index0 (1+ index0))
  110.   )
  111.     )
  112. ;;;绘制边框上的格网点
  113. ;;;    下边
  114.     (setq fx 0)
  115.     (setq index0 1)
  116.     (setq test "aaaaaa")
  117.     (while (< fx (- rightupx netdist))
  118.   (setq fx (+ f1x (* index0 netdist)))
  119.   (drawcrossdown fx leftdowny mapscale)
  120.   (writex fx (- leftdowny (* 7.5 mapscale)) mapscale)
  121.   (setq textlong_fx (strlen (rtos fx 2 0)))
  122.   (setq textstr_fx (substr (rtos fx 2 0) 1 (- textlong_fx 4)))
  123.   (if (/= textstr_fx test)
  124.       (progn
  125.     (writexforeside fx leftdowny mapscale)
  126.     (setq test textstr_fx)
  127.       )
  128.   )
  129.   (setq index0 (1+ index0))
  130.     )
  131.     (writexforeside fx leftdowny mapscale)
  132. ;;;    上边
  133.     (setq fx 0)
  134.     (setq index0 1)
  135.     (setq test "aaaaaa")
  136.     (while (< fx (- rightupx netdist))
  137.   (setq fx (+ f1x (* index0 netdist)))
  138.   (drawcrossup fx rightupy mapscale)
  139.   (writex fx (+ rightupy (* 4.9 mapscale)) mapscale)
  140.   (setq textlong_fx (strlen (rtos fx 2 0)))
  141.   (setq textstr_fx (substr (rtos fx 2 0) 1 (- textlong_fx 4)))
  142.   (if (/= textstr_fx test)
  143.       (progn
  144.     (writexforeside
  145.         fx
  146.         (+ rightupy (* 12.4 mapscale))
  147.         mapscale
  148.     )
  149.     (setq test textstr_fx)
  150.       )
  151.   )
  152.   (setq index0 (1+ index0))
  153.     )
  154.     (writexforeside fx (+ rightupy (* 12.4 mapscale)) mapscale)
  155. ;;;    左边
  156.     (setq fy 0)
  157.     (setq index0 1)
  158.     (setq test "aaaaaa")
  159.     (while (< fy (- rightupy netdist))
  160.   (setq fy (+ f1y (* index0 netdist)))
  161.   (drawcrossleft leftdownx fy mapscale)
  162.   (writey  (- leftdownx (* 5 mapscale))
  163.     (+ fy (* 1.5 mapscale))
  164.     mapscale
  165.   )
  166.   (setq textlong_fy (strlen (rtos fy 2 0)))
  167.   (setq textstr_fy (substr (rtos fy 2 0) 1 (- textlong_fy 4)))
  168.   (if (/= textstr_fy test)
  169.       (progn
  170.     (writeleftyforeside leftdownx fy mapscale)
  171.     (setq test textstr_fy)
  172.       )
  173.   )
  174.   (setq index0 (1+ index0))
  175.     )
  176.     (writeleftyforeside leftdownx fy mapscale)
  177. ;;;    右边
  178.     (setq fy 0)
  179.     (setq index0 1)
  180.     (setq test "aaaaaa")
  181.     (while (< fy (- rightupy netdist))
  182.   (setq fy (+ f1y (* index0 netdist)))
  183.   (drawcrossright rightupx fy mapscale)
  184.   (writey  (+ rightupx (* 3.8 mapscale))
  185.     (+ fy (* 1.5 mapscale))
  186.     mapscale
  187.   )
  188.   (setq textlong_fy (strlen (rtos fy 2 0)))
  189.   (setq textstr_fy (substr (rtos fy 2 0) 1 (- textlong_fy 4)))
  190.   (if (/= textstr_fy test)
  191.       (progn
  192.     (writerightyforeside rightupx fy mapscale)
  193.     (setq test textstr_fy)
  194.       )
  195.   )
  196.   (setq index0 (1+ index0))
  197.     )
  198.     (writerightyforeside rightupx fy mapscale)
  199. ;;;四角
  200.     (drawline leftdownxy
  201.         (list (- leftdownx (* 10 mapscale)) leftdowny)
  202.     )
  203.     (drawline leftdownxy
  204.         (list leftdownx (- leftdowny (* 10 mapscale)))
  205.     )
  206.     (setq leftdownbl (xytobl54 leftdownx leftdowny centerm))
  207.     (entmake
  208.   (list
  209.       (cons 0 "TEXT")
  210.       (cons 8 "图框")
  211.       (cons 7 "TUKUANG")
  212.       (cons 10
  213.       (list  (- leftdownx (* mapscale 5.5644))
  214.       (- leftdowny (* mapscale 6.2651))
  215.       )
  216.       )
  217.       (cons 40 (* mapscale 1.8))
  218.       (cons 50 0)
  219.       (cons 1 (car leftdownbl))
  220.   )
  221.     )
  222.     (entmake
  223.   (list
  224.       (cons 0 "TEXT")
  225.       (cons 8 "图框")
  226.       (cons 7 "TUKUANG")
  227.       (cons 10
  228.       (list  (- leftdownx (* mapscale 4.3258))
  229.       (+ leftdowny (* mapscale 1.35))
  230.       )
  231.       )
  232.       (cons 40 (* mapscale 1.8))
  233.       (cons 50 0)
  234.       (cons 1 (substr (nth 1 leftdownbl) 1 4))
  235.   )
  236.     )
  237.     (entmake
  238.   (list
  239.       (cons 0 "TEXT")
  240.       (cons 8 "图框")
  241.       (cons 7 "TUKUANG")
  242.       (cons 10
  243.       (list  (- leftdownx (* mapscale 8.7))
  244.       (- leftdowny (* mapscale 2.8))
  245.       )
  246.       )
  247.       (cons 40 (* mapscale 1.8))
  248.       (cons 50 0)
  249.       (cons 1 (substr (nth 1 leftdownbl) 5))
  250.   )
  251.     )
  252. ;;;单行文本
  253.     (entmake
  254.         (list '(0 . "TEXT")
  255.                (cons 1 str)
  256.                (cons 10 pt)
  257.                (cons 40 5)))
  258.     (drawline (list rightupx leftdowny)
  259.         (list (+ rightupx (* 10 mapscale)) leftdowny)
  260.     )
  261.     (drawline (list rightupx leftdowny)
  262.         (list rightupx (- leftdowny (* 10 mapscale)))
  263.     )
  264.     (setq rightdownbl (xytobl54 rightupx leftdowny centerm))
  265.     (entmake
  266.   (list
  267.       (cons 0 "TEXT")
  268.       (cons 8 "图框")
  269.       (cons 7 "TUKUANG")
  270.       (cons 10
  271.       (list  (- rightupx (* mapscale 10.6))
  272.       (- leftdowny (* mapscale 6.2651))
  273.       )
  274.       )
  275.       (cons 40 (* mapscale 1.8))
  276.       (cons 50 0)
  277.       (cons 1 (car rightdownbl))
  278.   )
  279.     )
  280.     (entmake
  281.   (list
  282.       (cons 0 "TEXT")
  283.       (cons 8 "图框")
  284.       (cons 7 "TUKUANG")
  285.       (cons 10
  286.       (list  (- rightupx (* mapscale 0))
  287.       (+ leftdowny (* mapscale 1.35))
  288.       )
  289.       )
  290.       (cons 40 (* mapscale 1.8))
  291.       (cons 50 0)
  292.       (cons 1 (substr (nth 1 rightdownbl) 1 4))
  293.   )
  294.     )
  295.     (entmake
  296.   (list
  297.       (cons 0 "TEXT")
  298.       (cons 8 "图框")
  299.       (cons 7 "TUKUANG")
  300.       (cons 10
  301.       (list  (- rightupx (* mapscale 3.5))
  302.       (- leftdowny (* mapscale 2.8))
  303.       )
  304.       )
  305.       (cons 40 (* mapscale 1.8))
  306.       (cons 50 0)
  307.       (cons 1 (substr (nth 1 rightdownbl) 5))
  308.   )
  309.     )
  310.     (drawline rightupxy
  311.         (list (+ rightupx (* 10 mapscale)) rightupy)
  312.     )
  313.     (drawline rightupxy
  314.         (list rightupx (+ rightupy (* 10 mapscale)))
  315.     )
  316.     (setq rightupbl (xytobl54 rightupx rightupy centerm))
  317.     (entmake
  318.   (list
  319.       (cons 0 "TEXT")
  320.       (cons 8 "图框")
  321.       (cons 7 "TUKUANG")
  322.       (cons 10
  323.       (list  (- rightupx (* mapscale 10.6))
  324.       (+ rightupy (* mapscale 5.0))
  325.       )
  326.       )
  327.       (cons 40 (* mapscale 1.8))
  328.       (cons 50 0)
  329.       (cons 1 (car rightupbl))
  330.   )
  331.     )
  332.     (entmake
  333.   (list
  334.       (cons 0 "TEXT")
  335.       (cons 8 "图框")
  336.       (cons 7 "TUKUANG")
  337.       (cons 10
  338.       (list  (- rightupx (* mapscale 0))
  339.       (+ rightupy (* mapscale 1.35))
  340.       )
  341.       )
  342.       (cons 40 (* mapscale 1.8))
  343.       (cons 50 0)
  344.       (cons 1 (substr (nth 1 rightupbl) 1 4))
  345.   )
  346.     )
  347.     (entmake
  348.   (list
  349.       (cons 0 "TEXT")
  350.       (cons 8 "图框")
  351.       (cons 7 "TUKUANG")
  352.       (cons 10
  353.       (list  (- rightupx (* mapscale 3.5))
  354.       (- rightupy (* mapscale 2.8))
  355.       )
  356.       )
  357.       (cons 40 (* mapscale 1.8))
  358.       (cons 50 0)
  359.       (cons 1 (substr (nth 1 rightupbl) 5))
  360.   )
  361.     )
  362.     (drawline (list leftdownx rightupy)
  363.         (list (- leftdownx (* 10 mapscale)) rightupy)
  364.     )
  365.     (drawline (list leftdownx rightupy)
  366.         (list leftdownx (+ rightupy (* 10 mapscale)))
  367.     )
  368.     (setq leftupbl (xytobl54 leftdownx rightupy centerm))
  369.     (entmake
  370.   (list
  371.       (cons 0 "TEXT")
  372.       (cons 8 "图框")
  373.       (cons 7 "TUKUANG")
  374.       (cons 10
  375.       (list  (- leftdownx (* mapscale 5.5644))
  376.       (+ rightupy (* mapscale 5.0))
  377.       )
  378.       )
  379.       (cons 40 (* mapscale 1.8))
  380.       (cons 50 0)
  381.       (cons 1 (car leftupbl))
  382.   )
  383.     )
  384.     (entmake
  385.   (list
  386.       (cons 0 "TEXT")
  387.       (cons 8 "图框")
  388.       (cons 7 "TUKUANG")
  389.       (cons 10
  390.       (list  (- leftdownx (* mapscale 4.3258))
  391.       (+ rightupy (* mapscale 1.35))
  392.       )
  393.       )
  394.       (cons 40 (* mapscale 1.8))
  395.       (cons 50 0)
  396.       (cons 1 (substr (nth 1 leftupbl) 1 4))
  397.   )
  398.     )
  399.     (entmake
  400.   (list
  401.       (cons 0 "TEXT")
  402.       (cons 8 "图框")
  403.       (cons 7 "TUKUANG")
  404.       (cons 10
  405.       (list  (- leftdownx (* mapscale 8.7))
  406.       (- rightupy (* mapscale 2.8))
  407.       )
  408.       )
  409.       (cons 40 (* mapscale 1.8))
  410.       (cons 50 0)
  411.       (cons 1 (substr (nth 1 leftupbl) 5))
  412.   )
  413.     )
  414.     (setvar "osmode" oldosmode)
  415.     (setvar "cmdecho" oldcmdecho)
  416.     (princ)
  417. )
  418. ;;;drawcross()
  419. (defun drawcross (x y s / x1 x2 y1 y2)
  420.     (setq x1 (list (- x (* 5 s)) y)
  421.     x2 (list (+ x (* 5 s)) y)
  422.     y1 (list x (+ y (* 5 s)))
  423.     y2 (list x (- y (* 5 s)))
  424.     )
  425.     (drawline x1 x2)
  426.     (drawline y1 y2)
  427.     (princ)
  428. )
  429. (defun drawcrossdown (x y s / y1 y2)
  430.     (setq y1 (list x (+ y (* 5 s)))
  431.     y2 (list x (- y (* 10 s)))
  432.     )
  433.     (drawline y1 y2)
  434.     (princ)
  435. )
  436. (defun drawcrossup (x y s / y1 y2)
  437.     (setq y1 (list x (+ y (* 10 s)))
  438.     y2 (list x (- y (* 5 s)))
  439.     )
  440.     (drawline y1 y2)
  441.     (princ)
  442. )
  443. (defun drawcrossleft (x y s / x1 x2)
  444.     (setq x1 (list (- x (* 10 s)) y)
  445.     x2 (list (+ x (* 5 s)) y)
  446.     )
  447.     (drawline x1 x2)
  448.     (princ)
  449. )
  450. (defun drawcrossright (x y s / x1 x2 y1 y2)
  451.     (setq x1 (list (- x (* 5 s)) y)
  452.     x2 (list (+ x (* 10 s)) y)
  453.     )
  454.     (drawline x1 x2)
  455.     (princ)
  456. )
  457. (defun drawline  (xy1 xy2 /)
  458.     (entmake
  459.   (list
  460.       (cons 0 "LINE")
  461.       (cons 8 "图框")
  462.       (cons 10 xy1)
  463.       (cons 11 xy2)
  464.   )
  465.     )
  466. )
  467. (defun writex (x y s / textlong textstr)
  468.     (setq textlong (strlen (rtos x 2 0)))
  469.     (setq textstr (substr (rtos x 2 0) (- textlong 3) 2))
  470.     (entmake
  471.   (list
  472.       (cons 0 "TEXT")
  473.       (cons 8 "图框")
  474.       (cons 7 "TUKUANG")
  475.       (cons 10 (list x y))
  476.       (cons 40 (* s 3))
  477.       (cons 50 0)
  478.       (cons 1 textstr)
  479.   )
  480.     )
  481. )
  482. (defun writey (x y s / textlong textstr)
  483.     (setq textlong (strlen (rtos y 2 0)))
  484.     (setq textstr (substr (rtos y 2 0) (- textlong 3) 2))
  485.     (entmake
  486.   (list
  487.       (cons 0 "TEXT")
  488.       (cons 8 "图框")
  489.       (cons 7 "TUKUANG")
  490.       (cons 10 (list x y))
  491.       (cons 40 (* s 3))
  492.       (cons 50 0)
  493.       (cons 1 textstr)
  494.   )
  495.     )
  496. )
  497. (defun writexforeside (x y s / textlong textstr texthigh)
  498.     (setq textlong (strlen (rtos x 2 0)))
  499.     (setq textstr (substr (rtos x 2 0) 1 (- textlong 4)))
  500.     (setq textlong (strlen textstr))
  501.     (setq texthigh (* s 1.8))
  502.     (entmake
  503.   (list
  504.       (cons 0 "TEXT")
  505.       (cons 8 "图框")
  506.       (cons 7 "TUKUANG")
  507.       (cons 10
  508.       (list  (- x (* textlong texthigh 0.7))
  509.       (- y texthigh (* 4.4676 s))
  510.       )
  511.       )
  512.       (cons 40 texthigh)
  513.       (cons 50 0)
  514.       (cons 1 textstr)
  515.   )
  516.     )
  517. )
  518. (defun writeleftyforeside (x y s / textlong textstr texthigh)
  519.     (setq textlong (strlen (rtos y 2 0)))
  520.     (setq textstr (substr (rtos y 2 0) 1 (- textlong 4)))
  521.     (setq textlong (strlen textstr))
  522.     (setq texthigh (* s 1.8))
  523.     (entmake
  524.   (list
  525.       (cons 0 "TEXT")
  526.       (cons 8 "图框")
  527.       (cons 7 "TUKUANG")
  528.       (cons 10
  529.       (list  (- x (* s 8.924))
  530.       (+ y (* s 2.6517))
  531.       )
  532.       )
  533.       (cons 40 texthigh)
  534.       (cons 50 0)
  535.       (cons 1 textstr)
  536.   )
  537.     )
  538. )
  539. (defun writerightyforeside (x y s / textlong textstr texthigh)
  540.     (setq textlong (strlen (rtos y 2 0)))
  541.     (setq textstr (substr (rtos y 2 0) 1 (- textlong 4)))
  542.     (setq textlong (strlen textstr))
  543.     (setq texthigh (* s 1.8))
  544.     (entmake
  545.   (list
  546.       (cons 0 "TEXT")
  547.       (cons 8 "图框")
  548.       (cons 7 "TUKUANG")
  549.       (cons 10
  550.       (list  x
  551.       (+ y (* s 2.6518))
  552.       )
  553.       )
  554.       (cons 40 texthigh)
  555.       (cons 50 0)
  556.       (cons 1 textstr)
  557.   )
  558.     )
  559. )
  560. ;;;    BJ-54坐标系的椭球参数为:
  561. ;;;    长半轴:a=6378245
  562. ;;;    短半轴:b=6356863.018773
  563. (defun xytobl54  (y x cm /)
  564.     (setq a  6378245.0
  565.     b  6356863.018773
  566.     e1 (sqrt (- 1.0 (expt (/ b a) 2.0)))
  567.     e2 (sqrt (- (expt (/ a b) 2.0) 1.0))
  568.     k0 1.0
  569.     fn 0.0
  570.     fe 500000.0
  571.     )
  572.     (if  (= (strlen (rtos (fix y))) 8)
  573.   (progn
  574.       (setq zoneid (atof (substr (rtos (fix y)) 1 2)))
  575.       (setq l0 (* (/ (* zoneid 3) 180.0) pi))
  576.       (setq y (- y (* zoneid 1000000)))
  577.   )
  578.   (progn
  579. ;;;      (setq cm (getreal "本投影带(3°带)中央经线........"))
  580.       (setq l0 cm)
  581.   )
  582.     )
  583.     (setq mf (/ (- x fn) k0))
  584.     (setq e3 (/ (- a b) (+ a b)))
  585.     (setq q (/ mf
  586.          (* a
  587.       (- 1
  588.          (/ (expt e1 2) 4)
  589.          (/ (* 3 (expt e1 4)) 64)
  590.          (/ (* 5 (expt e1 6)) 256)
  591.       )
  592.          )
  593.       )
  594.     )
  595.     (setq bf (+  q
  596.     (* (- (* 3 (/ e3 2)) (* 27 (/ (expt e3 3) 32)))
  597.        (sin (* 2 q))
  598.     )
  599.     (* (- (* 21 (/ (expt e3 2) 16))
  600.           (* 55 (/ (expt e3 4) 32))
  601.        )
  602.        (sin (* 4 q))
  603.     )
  604.     (* (* 151 (/ (expt e3 3) 96)) (sin (* 6 q)))
  605.        )
  606.     )
  607.     (setq tf (expt (/ (sin bf) (cos bf)) 2))
  608.     (setq cf (* (expt e2 2) (expt (cos bf) 2)))
  609.     (setq rf (/  (* a (- 1 (expt e1 2)))
  610.     (expt (- 1 (* (expt e1 2) (expt (sin bf) 2))) 1.5)
  611.        )
  612.     )
  613.     (setq nf (/ a (sqrt (- 1 (* (expt e1 2) (expt (sin bf) 2))))))
  614.     (setq d (/ (- y fe) (* k0 nf)))
  615.     (setq b (- bf
  616.          (/ (* nf
  617.          (/ (sin bf) (cos bf))
  618.          (-  (/ (* d d) 2)
  619.       (/ (* (expt d 4)
  620.             (+ 5 (* 3 tf) cf (* -9 tf cf))
  621.          )
  622.          24
  623.       )
  624.       (/ (* (expt d 6)
  625.             (+ 61 (* 90 tf) (* 45 tf tf))
  626.          )
  627.          -720
  628.       )
  629.          )
  630.       )
  631.       rf
  632.          )
  633.       )
  634.     )
  635.     (setq l (+ l0
  636.          (* (/ 1 (cos bf))
  637.       (+ d
  638.          (/ (* (+ 1 (* 2 tf) cf) (expt d 3)) -6)
  639.          (/  (* (+ 5
  640.             (* 28 tf)
  641.             (* 6 cf)
  642.             (* 8 tf cf)
  643.             (* 24 tf tf)
  644.          )
  645.          (expt d 5)
  646.       )
  647.       120
  648.          )
  649.       )
  650.          )
  651.       )
  652.     )
  653.     (list (dfm l) (dfm b))
  654. )
  655. (defun dfm (degree / d f d_error f_error result)
  656.     (setq degree (/ (* degree 180) pi))
  657.     (setq d (fix degree))
  658.     (setq d_error (* (- degree d) 60))
  659.     (setq f (fix d_error))
  660.     (setq f_error (* (- d_error f) 60))
  661.     (setq result (strcat (rtos d 2 0)
  662.        "°"
  663.        (rtos f 2 0)
  664.        "'"
  665.        (rtos f_error 2 2)
  666.        (chr 34)
  667.      )
  668.     )
  669.     result
  670. )
我想在图框上再加个标题,而且标题要随比例尺变化而变化,求教。
发表于 2015-8-28 10:38:16 | 显示全部楼层
你的代码格式化有问题,  插入代码时请使用lisp
GMT+8, 2025-10-19 04:05 , Processed in 0.182294 second(s), 26 queries , Gzip On.
