查看: 1238|回复: 0
[公告] cad调用窗体值为空?
发表于 2015-9-3 09:33:28 | 显示全部楼层 |阅读模式
Public Class entadd_data
          Dim name  ,age as String
         public sub new(byval pname as String,byval page as String)
          name=pname:age=page
         End Sub
     <CommandMethod("djpl")> _
    Public Sub djpl()
         Dim ed As Editor = acad.Application.DocumentManager.MdiActiveDocument.Editor
         Dim db As Database = HostApplicationServices.WorkingDatabase
           Dim opt As New PromptEntityOptions("请选择要显示扩展数据的对象")
            Dim res As PromptEntityResult = ed.GetEntity(opt)
            If res.Status <> PromptStatus.OK Then
                Return
            End If
            Dim id As ObjectId = res.ObjectId
            Dim frm1 As New Form1
            frm1.Visible = True
'name age 值为空,什么原因?要在此获得窗体数值后再执行  call adddata(id,name,age)
    end sub
Public Class Form1
    Public Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
       dim entdata as new entadd_data(Me.TextBox1.Text, Me.TextBox2.Text)
        Me.Visible = False
    End Sub
  End Sub
   此段程序目的是:在cad中注册djpl命令时通过窗体获得值后在cad中画图,求求大侠指导!
GMT+8, 2025-11-21 07:28 , Processed in 0.188045 second(s), 29 queries , Gzip On.
