查看: 8633|回复: 20
[函数] 文本型点对表编辑
发表于 2015-9-15 10:56:23 | 显示全部楼层 |阅读模式
发个不成熟的函数,望高手们帮忙改进~~~~
1.dcl控件不能对齐,不美观~
2.代码程序好像比较累赘,结构也不够合理~
函数:
  1. ;文本型点对表编辑
  2. ;(editlst '(("标签1" . "值1") ("标签2" . "值2") ("标签3" . "值3") ("标签4" . "值4")))
  3. (defun editlst (lst / getdata fname F1 I lst1 dclid)
  4.   (defun getdata()
  5.      (setq lst1 NIL I 1)
  6.       (foreach n lst
  7.         (setq LST1 (cons (cons (car n) (get_tile (strcat "KEY" (itoa I)))) LST1)
  8.              I (1+ I)
  9.             )
  10.       )
  11.   )
  12.   (setq fname (vl-filename-mktemp nil nil ".dcl"))
  13.   (setq F1 (open fname "w"))
  14.   (write-line "EditDCL:dialog{label="文本型点对表编辑";" F1)
  15.   (write-line ":boxed_column{ " F1)
  16.   (write-line ":row{\n:column{" F1)
  17.   (setq I 1)
  18.   (foreach n lst
  19.    (write-line
  20.     (strcat ":edit_box{label="" (car n)
  21.                    "";value="" (cdr n)
  22.                    "";key="KEY" (itoa I) "";}"
  23.            )
  24.      F1
  25.    )
  26.    (if (= (rem i 10) 0) (write-line "}\n:column{" F1))
  27.    (setq I (1+ I))
  28.   )
  29. (if (/= (rem (1- i) 10) 0) (write-line "}" F1))
  30.   (write-line "}\n}" F1)
  31.   (write-line "ok_cancel;" F1)
  32.   (write-line "}" F1)
  33.   (close F1)
  34.   (setq dclid (load_dialog fname))
  35.   (vl-file-delete fname)
  36.   (new_dialog "EditDCL" dclid)
  37.   (action_tile "accept" "(getdata)(done_dialog 1)")
  38.   (action_tile "cancel" "(done_dialog 0)")
  39.   (start_dialog)
  40.   (unload_dialog dclid)
  41.   (if lst1
  42.     (setq lst (reverse lst1))
  43.     (setq lst lst)
  44.     )
  45. )
用法示例:
  1. (defun c:xx-tt(/ ENT attlst)
  2.    (prompt "***属性块编辑****")
  3.    (while (setq ENT (CAR(entsel "\n 选择属性块:")))
  4.      (setq attlst(editlst (GetAttributes ent)))
  5.      (SetAttributes ent attlst)
  6.      (princ "继续选择下一属性块")
  7.    )
  8.   (princ)
  9. );end defun
最简单的办法,分种两列  发表于 2015-9-15 22:15
为什么还要写代码做这个? CAD自带命令attedit 不可以吗?  发表于 2015-9-15 18:51
参与人数 3明经币 +1 金钱 +10 收起 理由
zhangcan0515 + 5
biya + 5 赞一个!
zctao1966 + 1 很给力!
发表于 2018-1-4 13:10:18 | 显示全部楼层
  1. ;|;;文本型点对表编辑
  2. |
  3. (editlst '(("标签1" . "值1")
  4.      ("标签2" . "值2")
  5.      ("标签3" . "值3")
  6.      ("标签4" . "值4")
  7.      ("标签5" . "值5")
  8.      ("标签6" . "值6")
  9.      ("标签7" . "值7")
  10.      ("标签8" . "值8")
  11.     )
  12. )
  13. |;
  14. (defun editlst (lst / getdata fname F1 I lst1 dclid)
  15.   (defun getdata ()
  16.     (setq lst1 NIL
  17.     I    1
  18.     )
  19.     (foreach n lst
  20.       (setq LST1 (cons (cons (car n) (get_tile (strcat "KEY" (itoa I))))
  21.            LST1
  22.      )
  23.       I   (1+ I)
  24.       )
  25.     )
  26.   )
  27.   (setq fname (vl-filename-mktemp nil nil ".dcl"))
  28.   (setq F1 (open fname "w"))
  29.   (write-line
  30.     "EditDCL:dialog{label=\"文本型点对表编辑 \";"
  31.     F1
  32.   )
  33.   (write-line ":boxed_column{ " F1)
  34.   (write-line ":row{\n:column{" F1)
  35.   (setq I 1)
  36.   (foreach n lst
  37.     (write-line
  38.       (strcat ":edit_box{label=\""
  39.         (car n)
  40.         "\";value=\""
  41.         (cdr n)
  42.         "\";key=\"KEY"
  43.         (itoa I)
  44.         "\";}"
  45.       )
  46.       F1
  47.     )
  48.     (if  (= (rem i 5) 0)
  49.       (write-line "}\n:column{" F1)
  50.     )
  51.     (setq I (1+ I))
  52.   )
  53.   (if (/= (rem (1- i) 5) 0)
  54.     (write-line "}" F1)
  55.   )
  56.   (write-line "}\n}" F1)
  57.   (write-line "ok_cancel;" F1)
  58.   (write-line "}" F1)
  59.   (close F1)
  60.   (setq dclid (load_dialog fname))
  61.   (vl-file-delete fname)
  62.   (new_dialog "EditDCL" dclid)
  63.   (action_tile "accept" "(getdata)(done_dialog 1)")
  64.   (action_tile "cancel" "(done_dialog 0)")
  65.   (start_dialog)
  66.   (unload_dialog dclid)
  67.   (if lst1
  68.     (setq lst (reverse lst1))
  69.     (setq lst lst)
  70.   )
  71. )
  72. (defun c:xx-tt (/ ENT attlst)
  73.   (prompt "***属性块编辑****")
  74.   (while (setq ENT (CAR (entsel "\n 选择属性块:")))
  75.     (setq attlst (editlst (GetAttributes ent)))
  76.     (SetAttributes ent attlst)
  77.     (princ "继续选择下一属性块")
  78.   )
  79.   (princ)
  80. )
怎么对齐??????
 楼主| 发表于 2021-2-20 21:37:51 | 显示全部楼层
调整了一下,用edit_box。
  1. (defun editlst (lst / dclfile dclfo i keys key dclid out)
  2.         (setq dclfile (vl-filename-mktemp nil nil ".dcl"))
  3.         (setq dclfo (open dclfile "w"))
  4.         (write-line "minbox:edit_box{fixed_width=true;fixed_height=true;vertical_margin=none;horizontal_margin=none;}" dclfo)
  5.         (write-line "consListEdit:dialog{label="文本型点对表编辑 ";" dclfo)
  6.         (write-line ":boxed_column{ " dclfo)
  7.         (setq i 1 keys nil)
  8.         (foreach n lst
  9.                 (setq key (strcat "key" (itoa i)) keys (cons key keys))
  10.                 (write-line ":row{" dclfo)
  11.                 (write-line(strcat ":minbox{width=15;is_enabled=false;value=""(car n)"";}")dclfo)
  12.                 (write-line(strcat ":minbox{width=20;value=""(cdr n)"";key="" key "";}")dclfo)
  13.                 (write-line "}" dclfo);row
  14.                 (setq i (1+ i))
  15.         )
  16.         (setq keys(reverse keys))
  17.         (write-line "}" dclfo);boxed_column
  18.         (write-line "ok_cancel;" dclfo)
  19.         (write-line "}" dclfo);dialog
  20.         (close dclfo)
  21.         (setq dclid (load_dialog dclfile))
  22.         (vl-file-delete dclfile)
  23.         (new_dialog "consListEdit" dclid)
  24.         (mode_tile (car keys) 2)
  25.         (action_tile "accept" "(setq out(mapcar '(lambda(v k)(cons (car v)(get_tile k))) lst keys))(done_dialog)")
  26.         (action_tile "cancel" "(setq out nil)(done_dialog)")
  27.         (start_dialog)
  28.         (unload_dialog dclid)
  29.         out
  30. )
发表于 2018-1-4 13:11:28 | 显示全部楼层
  1. (defun getAttributes        (ent / lst)
  2.   (if (safearray-value (setq lst (vlax-variant-value (vla-getattributes (vlax-ename->vla-object ent)))))
  3.     (mapcar '(lambda (x) (cons (vla-get-tagstring x) (vla-get-textstring x)))
  4.             (vlax-safearray->list lst)
  5.     )
  6.   )
  7. )
  8. (defun setAttributes        (ent lst / n atts)
  9.   (if (safearray-value (setq atts (vlax-variant-value (vla-getattributes (vlax-ename->vla-object ent)))))
  10.     (progn (foreach n lst
  11.              (mapcar '(lambda (x)
  12.                         (if (= (strcase (car n)) (strcase (vla-get-tagstring x)))
  13.                           (vla-put-textstring x (cdr n))
  14.                         )
  15.                       )
  16.                      (vlax-safearray->list atts)
  17.              )
  18.            )
  19.            (vla-update (vlax-ename->vla-object ent))
  20.     )
  21.   )
  22. )
 楼主| 发表于 2015-9-15 11:02:50 | 显示全部楼层
无图无真相~~~
发表于 2015-9-15 13:00:45 | 显示全部楼层
赞一个
坐等楼主完善了
完善啥? 楼主探讨的应该是方法, 如果实用就用attedit  发表于 2015-9-16 08:51
发表于 2015-9-15 14:11:06 | 显示全部楼层
非全部源码吧
发表于 2015-9-15 20:52:19 | 显示全部楼层
尝试构件这样的DCL,
框架代码
  1. :dialog {
  2.     :boxed_row {
  3.         :column {
  4.             :text {
  5.                 label = "属性名" ;
  6.             }
  7.             :text {
  8.                 label = "属性名" ;
  9.             }
  10.             :text {
  11.                 label = "属性名" ;
  12.             }
  13.             :text {
  14.                 label = "属性名" ;
  15.             }
  16.             :text {
  17.                 label = "属性名" ;
  18.             }
  19.             :text {
  20.                 label = "属性名" ;
  21.             }
  22.             :text {
  23.                 label = "属性名" ;
  24.             }
  25.             :text {
  26.                 label = "属性名" ;
  27.             }
  28.             :text {
  29.                 label = "属性名" ;
  30.             }
  31.             :text {
  32.                 label = "属性名" ;
  33.             }
  34.         }
  35.         :column {
  36.             :edit_box {
  37.                 value = "属性值" ;
  38.             }
  39.             :edit_box {
  40.                 value = "属性值" ;
  41.             }
  42.             :edit_box {
  43.                 value = "属性值" ;
  44.             }
  45.             :edit_box {
  46.                 value = "属性值" ;
  47.             }
  48.             :edit_box {
  49.                 value = "属性值" ;
  50.             }
  51.             :edit_box {
  52.                 value = "属性值" ;
  53.             }
  54.             :edit_box {
  55.                 value = "属性值" ;
  56.             }
  57.             :edit_box {
  58.                 value = "属性值" ;
  59.             }
  60.             :edit_box {
  61.                 value = "属性值" ;
  62.             }
  63.             :edit_box {
  64.                 value = "属性值" ;
  65.             }
  66.         }
  67.     }
  68.     ok_cancel;
  69. }
现将lst分解成两个表
(mapcar 'car lst)
(mapcar 'cdr lst)
计算新表字符串最大长度
(apply 'max (mapcar 'strlen lst1))
(apply 'max (mapcar 'strlen lst2))
分别赋值控件text和edit_box edit_box最好+上1~2个宽度值。
这样,DCL对齐,字符串在显示的时候完整。
发表于 2015-9-16 08:48:39 | 显示全部楼层
77077 发表于 2015-9-15 11:02
无图无真相~~~
给edit_box 一个宽度值不就可以了吗?
发表于 2015-9-16 08:53:28 | 显示全部楼层
edata 发表于 2015-9-15 20:52
尝试构件这样的DCL,
E大讲的好深奥,  学习了
发表于 2015-9-16 09:59:31 | 显示全部楼层
先MARK,学习。
发表于 2015-9-16 13:49:34 | 显示全部楼层
GetAttributes  SetAttributes 没有
这个通用函数,搜搜就有了, 爱劳动才有果子吃,[em14]  发表于 2015-9-16 14:10
 楼主| 发表于 2015-9-16 22:29:10 | 显示全部楼层
GetAttributes  SetAttributes 论坛里面的通用函数~~~
GMT+8, 2026-1-16 03:05 , Processed in 0.201815 second(s), 38 queries , Gzip On.
