查看: 3069|回复: 3
[源码] 相邻多段线合并
发表于 2015-9-20 20:47:03 | 显示全部楼层 |阅读模式
5明经币
  1. (defun c:tt ()
  2.   (setq ss(ssget '((0 . "*line"))))
  3.   (setq $i -1)
  4.   (setq ssd (ssadd))
  5.   (repeat (sslength ss)
  6.     (setq $i (1+ $i))
  7.     (command "REGION" (ssname ss $i) "")
  8.     (setq ssd (ssadd (ssname(ssget "L")0) ssd))
  9.   )
  10.   (command "_union" ssd "")
  11.   (setq ss (ssget "L"))
  12.   (command "_explode"ss "")
  13.   (setq ss (ssget "P"))
  14.   (pex ss)
  15. )
  16. ;多线连接
  17. (defun pex(ss / i ename endata entype)
  18.   (command "PEDITACCEPT" "1")
  19.     (command ".pedit" "m" ss "" "j" "0" "w" "0" "" "PEDITACCEPT" "0"))
不小心发成悬赏贴了
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2015-9-20 20:47:04 | 显示全部楼层
发表于 2015-9-20 21:38:09 | 显示全部楼层
沙发支持一下,用循环面域会不会不太好
发表于 2015-10-1 08:59:13 来自手机 | 显示全部楼层
附件在哪里呀?
GMT+8, 2025-5-2 19:40 , Processed in 0.209660 second(s), 30 queries , Gzip On.
