查看: 2099|回复: 7
[已解答] 对话框的编辑框对齐问题
发表于 2015-9-24 16:44:01 | 显示全部楼层 |阅读模式
如题,做了一个对话框,图片如下,编辑框不知道怎么对齐,
初学DCL没有多久,请各位帮忙指点下,谢谢!
附对话框源码:
insert_a34tk:dialog {
    label = "插入A3/A4图框" ;
    :boxed_radio_row {
        children_alignment = centered ;
        fixed_width = false ;
        label = "选择图框" ;
        :radio_button {
            key = "form_a3" ;
            label = "A3图框" ;
           // value = "1" ;//
        :radio_button {
            key = "form_a4" ;
            label = "A4图框" ;
    :boxed_column {
        alignment = left ;
        fixed_width = true ;
        label = "可变信息区" ;
        :row {
            alignment = right ;
            :edit_box {
                height = 1.2 ;
                key = "mat" ;
                label = "材料:       " ;
                width = 33 ;
            :edit_box {
                height = 1.2 ;
                key = "thick" ;
                label = "板厚T:     " ;
                width = 31 ;
        :row {
            alignment = right ;
            :edit_box {
                height = 1.2 ;
                key = "pname" ;
                label = "零件名称:" ;
                width = 33 ;
            :edit_box {
                height = 1.2 ;
                key = "pcode" ;
                label = "零件图号:" ;
                width = 31 ;
    :boxed_column {
        alignment = left ;
        label = "固定信息区" ;
        :row {
            :edit_box {
                height = 1.2 ;
                key = "cpmc" ;
                label = "产品名称:" ;
                width = 30 ;
            :edit_box {
                height = 1.2 ;
                key = "pbom_code" ;
                label = "产品编号: " ;
                width = 30 ;
        :row {
            :edit_box {
                height = 1.2 ;
                key = "draw" ;
                label = "绘图:        " ;
                width = 30 ;
            :edit_box {
                height = 1.2 ;
                key = "draw_date" ;
                label = "绘图日期: " ;
                width = 30 ;
        :row {
            :edit_box {
                height = 1.2 ;
                key = "check" ;
                label = "审核:        " ;
                width = 30 ;
            :edit_box {
                height = 1.2 ;
                key = "check_date" ;
                label = "审核日期: " ;
                width = 30 ;
        :row {
            :edit_box {
                height = 1.2 ;
                key = "appr" ;
                label = "批准:        " ;
                width = 30 ;
            :edit_box {
                height = 1.2 ;
                key = "appr_date" ;
                label = "批准日期: " ;
                width = 30 ;
        :row {
            :edit_box {
                height = 1.2 ;
                key = "rev" ;
                label = "版本:        " ;
                width = 30 ;
            :edit_box {
                height = 1.2 ;
                key = "burr" ;
                label = "毛刺面:     " ;
                width = 30 ;
        :row {
            alignment = left ;
            :edit_box {
                height = 1.2 ;
                key = "scale" ;
                label = "比例:        " ;
                width = 15 ;
            :button {
                key = "save_data" ;
                label = "保存固定信息" ;
                width = 20 ;
            :button {
                key = "dqtkxx" ;
                label = "读取图框信息" ;
                width = 20 ;
    spacer_1;
    :row {
        :button {
            is_default = true ;
            key = "is_ok" ;
            label = "插入图框" ;
        cancel_button;
    spacer_1;
 楼主| 发表于 2015-9-25 08:50:38 | 显示全部楼层
各位大神啊,谁能告诉我那个参数可以控制。[em0][em0]
发表于 2015-9-25 09:53:19 | 显示全部楼层
加:spacer { }来调整,或者文字中加空格。
 楼主| 发表于 2015-9-25 10:10:47 | 显示全部楼层
我试下,谢谢黄大师。
发表于 2015-9-25 10:49:36 | 显示全部楼层
你可以改变排列顺序,把文字提示在一个Cloumn中,而Editboxs在同一个 Column中试试
发表于 2015-9-25 10:51:08 | 显示全部楼层
发表于 2015-9-25 10:53:09 | 显示全部楼层
用spacer控件
 楼主| 发表于 2015-9-25 11:02:21 | 显示全部楼层
xyp1964 发表于 2015-9-25 10:51
谢谢院长。。。
看来下下载工具箱才行。
GMT+8, 2025-10-28 04:25 , Processed in 0.254113 second(s), 31 queries , Gzip On.
