查看: 2033|回复: 7
[提问] 关于云线revcloud的使用
发表于 2015-10-1 18:46:44 | 显示全部楼层 |阅读模式
在编写一个小插件,用到了revcloud这个命令,但在调式的时候发现,revcloud这个命令会在程序全都走完后才开始执行,原程序如下:
  1. (defun c:tt ( / cla la )
  2.   (setvar "cmdecho" 0)
  3.   (setq cla (getvar "clayer"))
  4.   (setq la "云线")
  5.   (if (= (tblobjname "layer" la) nil)
  6.      (command "layer" "n" la "c" 6 la "p" "n" la  "")
  7.   )
  8.   (command "revcloud" "a" 1000 1000 "s" "c" )
  9.   (setvar "clayer" cla )
  10.   (setvar "cmdecho" 1)
  11. )
程序本想更改一下云线所在的图层,但这个程序执行调试过程中发现,(command "revcloud" "a" 1000 1000 "s" "c" )这名命令是在程序走完所有语句后才开始返回AutoCAD界面进行画云线,为什么会出现这种情况?
如果在(command "revcloud" "a" 1000 1000 "s" "c" )这个语句之前画一个矩形后,命令更改成
(command "revcloud" "a" 1000 1000 "s" "c" "o" "l"  "")这样就可以按顺序运行语句,除了这种方法外,是否有其它的解决办法?
是不是有类似的需要不断输入点取信息的cad命令在采用command命令调用时都会更改顺序?
谢谢~
发表于 2015-10-2 08:22:38 | 显示全部楼层
try
(while (= (logand (getvar "CmdActive") 1) 1) (command pause))   ; add this line
 楼主| 发表于 2015-10-2 19:03:38 | 显示全部楼层
Andyhon 发表于 2015-10-2 08:22
try
(while (= (logand (getvar "CmdActive") 1) 1) (com ...
谢谢,完美地解决了问题。
学到了位运算logand。
好奇问一下,为什么不直接
(while (= (getvar "CmdActive") 1  (command pause)),要采用函数logand?
CmdActive系统变量中只有值1是奇数,其它均是偶数,如果要判断奇数采用logand挺合适,但本例中采用logand有什么特别的考虑吗?
谢谢~
发表于 2015-10-2 19:34:07 | 显示全部楼层
CMDACTIVE System Variable
(Read-only)
Type: Integer
Not saved
Stores the bitcode that indicates whether an ordinary command, transparent command, script, or dialog box is active. The value is the sum of the following:
1 Ordinary command is active
2 Ordinary command and a transparent command are active
4 Script is active
8 Dialog box is active
16 DDE is active
32 AutoLISP is active (only visible to an ObjectARX-defined command)
64 ObjectARX command is active
 楼主| 发表于 2015-10-2 20:48:38 | 显示全部楼层
(Read-only)
不太明白,这不就是autocad帮助文件里有关cmdactive系统变量的说明部分?
回复给我的意思是?
发表于 2015-10-2 21:36:27 | 显示全部楼层
与捕捉相仿, OsMode的值是各捕捉模式的总和...
 楼主| 发表于 2015-10-3 07:53:05 | 显示全部楼层
明白了,谢谢了。
发表于 2021-9-4 13:46:50 | 显示全部楼层
还是不能框选全部~~~~~~~
GMT+8, 2025-5-16 15:54 , Processed in 0.191628 second(s), 25 queries , Gzip On.
