查看: 1184|回复: 3
[讨论] 有个零件坐标标注的源码,请大家帮忙完善下
发表于 2015-10-19 21:19:15 | 显示全部楼层 |阅读模式
大家好在网上看到了这个求助贴子,对我来说也很有用,所以再次贴出来请大家帮忙,谢谢!
希望这个零件标注源码能筛选出圆弧和倒角的端点不要标注,如图(最下面有打包程序)
贴出源码:
;;; 自动坐标标注
;;; 原作者:zml84  由langjs修改于2009-05-25  命令:tt
(defun C:TT (/ chanshu001 ent ent1 i lst_1 lst_2 lst_3 lst_4 lst_pt lst_x lst_y lstlx lstly lstx1
               lstx2 lsty1 lsty2 p001 p002 p003 p004 pmax pmay pminx pminy pt0 pt0linshijidian pzhx
               pzhxl pzhy pzhyl sc snap ss ssguol uuu x_last xlins xxxx xzuih xzuihbak xzuihbak2
               y_last ylins yyyy yzuih yzuihbak2 yzuihbak3 xsw
  (setvar "cmdecho" 0)                 ; 关闭命令响应
  (setq ss (ssget '((0 . "LINE,CIRCLE,PLINE,LWPOLYLINE,INSERT"))))
  (setq PT0linshijidian '(0.0 0.0 0.0))
  (setq PT0 (getpoint "\n指定基点: "))
  (cond
    ((null PT0)
      (setq PT0 PT0linshijidian)
    ((= PT0 0.0)
  (setq SC 1)
  (setq SC (getreal "\n输入比例 <1>: "))
  (cond
    ((null SC)
      (setq SC 1)
    ((= uuu 0.0)
      (setq SC 1)
  (setq chanshu001 (* 7 (getvar "dimtxt") (getvar "dimscale")))
  (setq uuu (atof (getstring (strcat "\n标注拉伸 <" (rtos chanshu001) ">:"))))
  (cond
    ((null uuu)
      (setq uuu chanshu001)
    ((= uuu 0.0)
  )                                    ; 下面程序设置过滤虚线条件
  (setq ssguol '("ACAD_ISO03W100" "ACAD_ISO02W100"
         "DASHED" "DASHED2"
         "DASHEDX2" "HIDDEN"
         "HIDDEN2" "HIDDENX2"
  )                                    ; 下面程序将虚线图层加入虚线过滤条件
  (setq ssguol (append
                 SSguol
                 (TT-01 "ACAD_ISO03W100")
                 (TT-01 "ACAD_ISO02W100")
                 (TT-01 "DASHED")
                 (TT-01 "DASHED2")
                 (TT-01 "DASHEDX2")
                 (TT-01 "HIDDEN")
                 (TT-01 "HIDDEN2")
                 (TT-01 "HIDDENX2")
  )                                    ; 下面程序将选择集中随层的虚线图层中的线过滤掉
  (SETQ i 0)
  (while (< i (sslength ss))
    (setq ent (ssname ss i))
    (setq ent1 (entget ent))
    (if (and
          (member (cdr (assoc 8 ent1)) ssguol)
          (/= (cdr (assoc 0 ent1)) "INSERT")
          (= (assoc 6 ent1) nil)
      (setq ss (ssdel ent ss))
      (SETQ i (+ 1 i))
  )                                    ; 下面程序将选择集中其他层的虚线图元过滤掉
  (SETQ i 0)
    (if (member (cdr (assoc 6 ent1)) ssguol)
      (SETQ i (+ 1 i))
  )                                    ; 主要程序
  (vl-cmdf ".UNDO" "BE")               ; 设置UNDO起点
  (setq snap (getvar "osmode"))
  (setvar "osmode" 0)                  ; 关闭捕捉
  (setq xsw (getvar "DIMZIN"))
  (setvar "DIMZIN" 0)                  ; 关闭小数点末尾数为0时候省略
    (setq LST_PT (TT-02 ss))
    (setq LST_PT (cons PT0 LST_PT))    ; 下面程序坐标分象限
    (setq i 1
          pminx (car (nth 0 LST_PT))
          pmax pminx
          pminy (cadr (nth 0 LST_PT))
          pmay pminy
    (while (<= i (length LST_PT))
      (setq xxxx (car (nth (- i 1) LST_PT)))
      (setq yyyy (cadr (nth (- i 1) LST_PT)))
      (cond
        ((< xxxx pminx)
          (setq pminx xxxx)
        ((> xxxx pmax)
          (setq pmax xxxx)
        ((< yyyy pminy)
          (setq pminy yyyy)
        ((> yyyy pmay)
          (setq pmay yyyy)
        (t
      (setq i (+ i 1))
    )                                  ; 求坐标范围中间数值
    (setq pzhx (/ (+ pminx pmax) 2))
    (setq pzhy (/ (+ pminy pmay) 2))   ; 求4个象限的坐标对齐点
    (setq p001 (list (- pminx uuu) (- pminy uuu) 0.0)
          p002 (list (- pminx uuu) (+ pmay uuu) 0.0)
          p003 (list (+ pmax uuu) (- pminy uuu) 0.0)
          p004 (list (+ pmax uuu) (+ pmay uuu) 0.0)
    )                                  ; 将坐标分类到四个象限
    (setq i 0
          LST_1 '()
          LST_2 '()
          LST_3 '()
          LST_4 '()
    (while (< i (length LST_PT))
      (setq pzhxl (car (nth i LST_PT))
            pzhyl (cadr (nth i LST_PT))
      (if (and
            (<= pzhxl pzhx)
            (<= pzhyl pzhy)
        (setq LST_1 (cons (nth i LST_PT) LST_1))
      (if (and
            (<= pzhxl pzhx)
            (> pzhyl pzhy)
        (setq LST_2 (cons (nth i LST_PT) LST_2))
      (if (and
            (> pzhxl pzhx)
            (<= pzhyl pzhy)
        (setq LST_3 (cons (nth i LST_PT) LST_3))
      (if (and
            (> pzhxl pzhx)
            (> pzhyl pzhy)
        (setq LST_4 (cons (nth i LST_PT) LST_4))
      (setq i (+ i 1))
    )                                  ; 坐标分象限结束
    (setq Xlins '(0.0)
          Ylins '(0.0)
    (setq LSTX1 '()
          LSTX2 '()
          LSTY1 '()
          LSTY2 '()
    (setq LST_X (TT-03 LST_1)
          LST_Y (TT-04 LST_1)
    (setq LST_X (TT-10 SS LST_X)
          LST_Y (TT-11 SS LST_Y)
    (setq X_LAST (caar LST_X))
    (setq Y_LAST (caar LST_Y))
    (TT-07 LST_X LST_Y PT0 SC p001)
    (setq LSTX1 (append
                  LSTX1
                  (reverse LSTLX)
    (setq LSTY1 (append
                  LSTY1
                  (reverse LSTLY)
    (setq Xzuihbak Xzuih)
    (setq LST_X (TT-05 LST_2)
          LST_Y (TT-04 LST_2)
    (TT-07 LST_X LST_Y PT0 SC p002)
    (setq LSTX2 (append
                  LSTX2
                  (reverse LSTLX)
    (setq LSTY1 (append
                  LSTY1
                  (reverse LSTLY)
    (setq Xzuihbak2 Xzuih)
    (setq Yzuihbak2 Yzuih)
    (setq LST_X (TT-03 LST_3)
          LST_Y (TT-06 LST_3)
    (setq X_LAST Xzuihbak)
    (TT-07 LST_X LST_Y PT0 SC p003)
    (setq LSTX1 (append
                  LSTX1
                  (reverse LSTLX)
    (setq LSTY2 (append
                  LSTY2
                  (reverse LSTLY)
    (setq Yzuihbak3 Yzuih)
    (setq X_LAST Xzuihbak2)
    (setq LST_X (TT-05 LST_4)
          LST_Y (TT-06 LST_4)
    (if (= Yzuihbak2 Yzuihbak3)
      (setq Y_LAST Yzuihbak3)
    (TT-07 LST_X LST_Y PT0 SC p004)
    (setq LSTX2 (append
                  LSTX2
                  (reverse LSTLX)
    (setq LSTY2 (append
                  LSTY2
                  (reverse LSTLY)
  (TT-12 LSTX1 PT0)
  (TT-13 LSTY1 PT0)
  (TT-12 LSTX2 PT0)
  (TT-13 LSTY2 PT0)
  (vl-cmdf ".UNDO" "E")                ; 设置UNDO终点
  (setvar "osmode" snap)
  (setvar "DIMZIN" xsw)
;;; 获取包含指定线型的图层
(defun TT-01 (xianxing / layers)
  (setq layers '())
  (setq layers (get_layer_linetype xianxing)) ; 获取包含指定线型的图层
  layers
(defun get_layer (/ layer_info layers) ; 返回当前图纸中图层信息
  (setq layer_info (tblnext "layer" t))
  (while (/= layer_info nil)
    (setq layers (append
                   layers
                   (list layer_info)
    (setq layer_info (tblnext "layer"))
  layers
(defun get_layer_linetype (linetype / ly_info ly_infos tmplist) ; 提取包含指定线型的图层
  (setq ly_Infos (get_layer))
  (foreach ly_info ly_Infos
    (if (= linetype (substr (cdr (assoc 6 ly_info)) 1 (strlen linetype)))
      (setq tmplist (append
                      tmplist
                      (list (CDR (assoc 2 ly_info)))
  tmplist
;;; 获取特征点坐标
(defun TT-02 (SS / ent i lst_pt lstl n pt)
  (setq LST_PT '()
        I 0
  (repeat (sslength SS)
    (setq ENT (entget (ssname SS I)))
    (foreach N ENT
      (if (<= 10 (car N) 19)
        (setq PT (cdr N)
              LST_PT (cons PT LST_PT)
    (setq I (1+ I))
  (setq i 0
        LSTL '()
    (setq LSTL (cons (list (car (nth i LST_PT)) (cadr (nth i LST_PT)) 0.0) LSTL))
    (setq i (+ 1 i))
  (setq LST_PT LSTL)                   ; 返回
  (reverse LST_PT)
;;; 提炼 X 坐标,并排序
(defun TT-03 (LST_PT / e1 e2 i lst_x lstl pt tmp x y)
  (setq LST_X '())
  (foreach PT LST_PT
    (setq X (car PT)
          Y (cadr PT)
    (if (setq TMP (assoc X LST_X))
      (setq LST_X (subst
                    (append
                      (list X Y)
                      (cdr TMP)
                    TMP
                    LST_X
      (setq LST_X (cons (list X Y) LST_X))
  )                                    ; 排序
  (setq LST_X (mapcar
                '(lambda (E1)
                   (cons (car E1) (vl-sort (cdr E1) '<))
                LST_X
  (setq LST_X (vl-sort LST_X '(lambda (E1 E2)
                                (< (car E1) (car E2))
  (setq i 0
        LSTL '()
  (while (< i (length LST_X))
    (setq LSTL (cons (list (car (nth i LST_X)) (cadr (nth i LST_X)) 0.0) LSTL))
    (setq i (+ 1 i))
  (setq LST_X (reverse LSTL))          ; 返回
  LST_X
;;; 提炼 Y 坐标,并排序
(defun TT-04 (LST_PT / e1 e2 i lst_y lstl pt tmp x y)
  (setq LST_Y '())
  (foreach PT LST_PT
    (setq X (car PT)
          Y (cadr PT)
    (if (setq TMP (assoc Y LST_Y))
      (setq LST_Y (subst
                    (append
                      (list Y X)
                      (cdr TMP)
                    TMP
                    LST_Y
      (setq LST_Y (cons (list Y X) LST_Y))
  )                                    ; 排序
  (setq LST_Y (mapcar
                '(lambda (E1)
                LST_Y
  (setq LST_Y (vl-sort LST_Y '(lambda (E1 E2)
  (setq i 0
        LSTL '()
  (while (< i (length LST_Y))
    (setq LSTL (cons (list (car (nth i LST_Y)) (cadr (nth i LST_Y)) 0.0) LSTL))
    (setq i (+ 1 i))
  (setq LST_Y (reverse LSTL))          ; 返回
  LST_Y
;;; 提炼 X 坐标,并排序  (由大到小)
(defun TT-05 (LST_PT / e1 e2 i lst_x lstl pt tmp x y)
  (setq LST_X '())
  (foreach PT LST_PT
    (setq X (car PT)
          Y (cadr PT)
      (setq LST_X (subst
                    (append
                      (list X Y)
                      (cdr TMP)
                    TMP
                    LST_X
  )                                    ; 排序
  (setq LST_X (mapcar
                '(lambda (E1)
                LST_X
  (setq i 0
        LSTL '()
    (setq LSTL (cons (list (car (nth i LST_X)) (nth (- (length (nth i LST_X)) 1) (nth i LST_X)) 0.0)
                     LSTL
    (setq i (+ 1 i))
  LST_X
;;; 提炼 Y 坐标,并排序    (由大到小)
(defun TT-06 (LST_PT / e1 e2 i lst_y lstl pt tmp x y)
  (setq LST_Y '())
  (foreach PT LST_PT
    (setq X (car PT)
          Y (cadr PT)
      (setq LST_Y (subst
                    (append
                      (list Y X)
                      (cdr TMP)
                    TMP
                    LST_Y
  )                                    ; 排序
  (setq LST_Y (mapcar
                '(lambda (E1)
                LST_Y
  (setq i 0
        LSTL '()
    (setq LSTL (cons (list (car (nth i LST_Y)) (nth (- (length (nth i LST_Y)) 1) (nth i LST_Y)) 0.0)
                     LSTL
    (setq i (+ 1 i))
  LST_Y
;;; 标注
(defun TT-07 (LST_X LST_Y PT0 SC ppp / ent pt pt1 str tmp x y) ; 标注 X
  (setq LSTLX '()
        LSTLY '()
  (foreach TMP LST_X
    (setq X (car TMP)
          Y (cadr TMP)
          PT (list X Y 0.0)            ;       STR (rtos (* SC (- X (car
                                       ; PT0))));;标注的数据为实际数值
          STR (rtos (TT-09 (* SC (- X (car PT0))) 2)) ; 标注的数据保留小数点后2位
    (if (and
          (/= (TT-09 X 4) (TT-09 (car Xlins) 4))
          (not (member (TT-09 X 4) Xlins))
        (setq X_LAST (max
                       X
                       X_LAST
              PT1 (list X_LAST (- (cadr PT0) (* 1.0 SC)) 0.0) ; _标注点
              X_LAST (+ X_LAST (* 1.5 (getvar "dimtxt") (getvar "dimscale"))) ; 调整1.5调整标注间距?
                                       ; 小
        (setq Xlins (cons (TT-09 X 4) Xlins))
        (setq Xzuih X_LAST)            ;    (vl-cmdf "_dimordinate" PT "x" "t"  STR PT1)
                                       ; ;;标注负号
        (vl-cmdf "_dimordinate" PT "x" "t" (rtos (abs (atof STR)) 2 2) PT1) ; 不标注负号
        (setq ent (entlast))
        (setq LSTLX (cons ent LSTLX))
        (TT-08 ent ppp PT0)            ; 对齐坐标
  )                                    ; 标注 Y
  (foreach TMP LST_Y
    (setq Y (car TMP)
          X (cadr TMP)
          PT (list X Y 0.0)            ;       STR (rtos (* SC (- Y (cadr PT0))))
                                       ; ;;标注的数据为实际数值
          STR (rtos (TT-09 (* SC (- Y (cadr PT0))) 2)) ; 标注的数据保留小数点后2位
    (if (and
          (/= (TT-09 Y 4) (TT-09 (car Ylins) 4))
          (not (member (TT-09 Y 4) Ylins))
        (setq Y_LAST (max
                       Y
                       Y_LAST
              PT1 (list (- (car PT0) (* 1.0 SC)) Y_LAST 0.0) ; _标注点
              Y_LAST (+ Y_LAST (* 1.5 (getvar "dimtxt") (getvar "dimscale"))) ; 调整1.5调整标注间距?
                                       ; 小
        (setq Ylins (cons (TT-09 Y 4) Ylins))
        (setq Yzuih Y_LAST)            ;    (vl-cmdf "_dimordinate" PT "Y" "t"  STR PT1)
                                       ; ;;标注负号
        (vl-cmdf "_dimordinate" PT "Y" "t" (rtos (abs (atof STR)) 2 2) PT1) ; 不标注负号
        (setq LSTLY (cons ent LSTLY))
;;;     点坐标对齐
(defun TT-08 (ent p0 PT0 / np14 p0x p0y p14x p14y p70) ; 点坐标对齐
  (setq ent (entget ent))
  (setq p70 (cdr (assoc 70 ent))
        p14x (car (cdr (assoc 14 ent)))
        p14y (cadr (cdr (assoc 14 ent)))
  (setq p0x (car p0)
        p0y (cadr p0)
  (cond
    ((= p70 38.0)
      (setq np14 (list p0x p14y 0.0))
    ((= p70 102.0)
      (setq np14 (list p14x p0y 0.0))
    (t
      (exit)
  (setq ent (subst
              (cons 14 nP14)
              (assoc 14 ent)
              ent
  (setq ent (subst
              (cons 10 PT0)
              (assoc 10 ent)
              ent
  (entmod ent)
;;; 四舍五入函数,ent:实数,n:小数点保留位数
(defun TT-09 (ent n / fh)
  (if (>= ent 0.0)
    (setq FH +)
    (setq FH -)
  (setq ent (/ (atof (itoa (fix (fh (* ent (expt 10 n)) 0.5)))) (expt 10 n)))
  ent
;;; 优化中心线点X坐标
(defun TT-10 (ss xxx / ent ent1 i ptzhongxinx ptzhongxiny ssguol2 x1 x2 y1 y2)
  (setq ssguol2 '("ACAD_ISO04W100" "ACAD_ISO08W100"
         "CENTER" "CENTER2"
         "CENTERX2" "DASHDOT"
         "DASHDOT2" "DASHDOTX2"
  )                                    ; 下面程序将中心线图层加入一个列表
  (setq ssguol2 (append
                  SSguol2
                  (TT-01 "ACAD_ISO04W100")
                  (TT-01 "ACAD_ISO08W100")
                  (TT-01 "CENTER")
                  (TT-01 "CENTER2")
                  (TT-01 "CENTERX2")
                  (TT-01 "DASHDOT")
                  (TT-01 "DASHDOT2")
                  (TT-01 "DASHDOTX2")
  )                                    ; 下面程序将选择集中随层的中心线加入一个列表
  (SETQ i 0
        PTzhongxinX '()
        PTzhongxinY '()
    (if (or
          (and
            (member (cdr (assoc 8 ent1)) ssguol2)
          (member (cdr (assoc 6 ent1)) ssguol2)
        (setq X1 (car (cdr (assoc 10 ent1)))
              Y1 (cadr (cdr (assoc 10 ent1)))
              X2 (car (cdr (assoc 11 ent1)))
              Y2 (cadr (cdr (assoc 11 ent1)))
        (if (= Y1 Y2)
            (setq PTzhongxinX (cons (list X1 Y1 0.0) PTzhongxinX))
            (setq PTzhongxinX (cons (list X2 Y2 0.0) PTzhongxinX))
        (if (= X1 X2)
            (setq PTzhongxinY (cons (list X1 Y1 0.0) PTzhongxinY))
            (setq PTzhongxinY (cons (list X2 Y2 0.0) PTzhongxinY))
    (SETQ i (+ 1 i))
  (SETQ i 0)
  (while (< i (length PTzhongxinX))
    (if (member (nth i PTzhongxinX) xxx)
      (SETQ xxx (vl-remove (nth i PTzhongxinX) xxx))
    (SETQ i (+ 1 i))
  xxx
;;; 优化中心线点Y坐标
(defun TT-11 (ss yyy / ent ent1 i ptzhongxinx ptzhongxiny ssguol2 x1 x2 y1 y2)
         "CENTER" "CENTER2"
                  SSguol2
                  (TT-01 "CENTER")
                  (TT-01 "CENTER2")
                  (TT-01 "CENTERX2")
                  (TT-01 "DASHDOT")
                  (TT-01 "DASHDOT2")
                  (TT-01 "DASHDOTX2")
  (SETQ i 0
        PTzhongxinX '()
        PTzhongxinY '()
    (if (or
          (and
        (if (= Y1 Y2)
        (if (= X1 X2)
            (setq PTzhongxinY (cons (list Y1 X1 0.0) PTzhongxinY))
            (setq PTzhongxinY (cons (list Y2 X2 0.0) PTzhongxinY))
    (SETQ i (+ 1 i))
  (SETQ i 0)
  (while (< i (length PTzhongxinY))
    (if (member (nth i PTzhongxinY) yyy)
      (SETQ yyy (vl-remove (nth i PTzhongxinY) yyy))
    (SETQ i (+ 1 i))
  yyy
;;; 优化X坐标偏移
(defun TT-12 (lsp pt / ent ent1 i il lstl lsty lstz np14 x x_last x0 y0)
  (setq X0 (car pt))
  (setq Y0 (cadr pt))
  (setq i 0
        il 0
        LSTZ '()
        LSTY '()
  (while (< i (length lsp))
    (setq X (car (cdr (assoc 13 (entget (nth i lsp))))))
    (if (<= X X0)
      (setq LSTZ (cons (nth i lsp) LSTZ))
      (setq LSTY (cons (nth i lsp) LSTY))
    (SETQ i (+ 1 i))
  (setq LSTZ LSTZ)
  (setq LSTY (reverse LSTY))
  (if (/= LSTZ '())
      (setq i 0)
      (setq X_LAST (car (cdr (assoc 13 (entget (nth 0 LSTZ))))))
      (while (< i (length LSTZ))
        (setq ent (nth i LSTZ))
        (setq X (car (cdr (assoc 13 ent1))))
        (setq X_LAST (min
                       X
                       X_LAST
        (setq nP14 (list X_LAST (cadr (cdr (assoc 14 ent1))) 0.0))
        (setq ent1 (subst
                     (cons 14 nP14)
                     (assoc 14 ent1)
                     ent1
        (entmod ent1)
        (SETQ i (+ 1 i))
        (setq X_LAST (- X_LAST (* 1.5 (getvar "dimtxt") (getvar "dimscale"))))
  (if (/= LSTY '())
      (setq i 0)
      (setq X_LAST (+ X0 (* 1.5 (getvar "dimtxt") (getvar "dimscale"))))
      (while (< i (length LSTY))
        (setq ent (nth i LSTY))
        (setq X_LAST (max
                       X
                       X_LAST
        (setq ent1 (subst
                     (cons 14 nP14)
                     (assoc 14 ent1)
                     ent1
        (entmod ent1)
        (SETQ i (+ 1 i))
        (setq X_LAST (+ X_LAST (* 1.5 (getvar "dimtxt") (getvar "dimscale"))))
;;; 优化Y坐标偏移
(defun TT-13 (lsp pt / ent ent1 i il lstl lsty lstz np14 x x_last x0 y0)
  (setq X0 (car pt))
  (setq Y0 (cadr pt))
  (setq i 0
        il 0
        LSTX '()
        LSTS '()
    (setq Y (cadr (cdr (assoc 13 (entget (nth i lsp))))))
    (if (<= Y Y0)
      (setq LSTX (cons (nth i lsp) LSTX))
      (setq LSTS (cons (nth i lsp) LSTS))
    (SETQ i (+ 1 i))
  (setq LSTX LSTX)
  (setq LSTS (reverse LSTS))
  (if (/= LSTX '())
      (setq i 0)
      (setq Y_LAST (cadr (cdr (assoc 13 (entget (nth 0 LSTX))))))
      (while (< i (length LSTX))
        (setq ent (nth i LSTX))
        (setq Y (cadr (cdr (assoc 13 ent1))))
        (setq Y_LAST (min
                       Y
                       Y_LAST
        (setq nP14 (list (car (cdr (assoc 14 ent1))) Y_LAST 0.0))
        (setq ent1 (subst
                     (cons 14 nP14)
                     (assoc 14 ent1)
                     ent1
        (entmod ent1)
        (SETQ i (+ 1 i))
        (setq Y_LAST (- Y_LAST (* 1.5 (getvar "dimtxt") (getvar "dimscale"))))
  (if (/= LSTS '())
      (setq i 0)
      (setq Y_LAST (+ Y0 (* 1.5 (getvar "dimtxt") (getvar "dimscale"))))
      (while (< i (length LSTS))
        (setq ent (nth i LSTS))
        (setq Y_LAST (max
                       Y
                       Y_LAST
        (setq ent1 (subst
                     (cons 14 nP14)
                     (assoc 14 ent1)
                     ent1
        (entmod ent1)
        (SETQ i (+ 1 i))
        (setq Y_LAST (+ Y_LAST (* 1.5 (getvar "dimtxt") (getvar "dimscale"))))
  (command "undo" "be")
  (setq orig_cmd(getvar "cmdecho"))
  (setq orig_osm(getvar "osmode"))
  (setq orig_orth(getvar "orthomode"))
  (setq orig_lay(getvar "clayer"))
  (setq diml_f(getvar "dimlfac"))
  (setvar "errno" 0)
  (setq olderr *error*)
  (defun *error* (msg)
    (setq en_er (getvar "errno"))
    (setq errmsg (strcat "ERRNO = " (itoa en_er) "\nError: " msg))
    (prompt errmsg)
    (setq *error* olderr)
    (command "undo" "e")
    (command "undo" "")
    (prompt "\n**")
    (prin1)
  (setvar "osmode" 0)
  (setvar "orthomode" 0)
  (setq cla(strcase orig_lay))
  (prompt"\n匡璶夹猔Rà㎝Cà瓜じ :")
  (if (setq ss(ssget))
      (setq ss_n(sslength ss)
     n 0
     ssa(ssadd)
     ssl(ssadd)
     ssp(ssadd))
      (repeat ss_n
(setq en(ssname ss n)
       en_type(cdr(assoc 0 (entget en))))
(cond ((= "ARC" en_type)  (ssadd en ssa))
       ((= "LINE" en_type) (ssadd en ssl))
       ((= "LWPOLYLINE" en_type) (ssadd en ssp))
(setq n(1+ n))
  (if(> (setq ssp_n(sslength ssp)) 0)
    (ex_pl)
  (setq ssa_n(sslength ssa)
ssl_n(sslength ssl))
  (if (> ssa_n 0)
      (setq list_r '()
     n 0)
      (repeat ssa_n
(setq en(ssname ssa n)
       en_r(cdr(assoc 40 (entget en))))
(if(= n 0)
   (setq list_r(cons (rtos (* diml_f en_r) 2 3) list_r))
     (if(null (setq chk_r(member (rtos (* diml_f en_r) 2 3) list_r)))
(setq n(1+ n))
      (setq list_r_n(length list_r)
     n 0)
      (repeat list_r_n
(setq te_r(nth n list_r)
       r_n 0
       n1 0)
(repeat ssa_n
   (setq en(ssname ssa n1)
   (if(= te_r (rtos (* diml_f en_r) 2 3))
     (setq r_n(1+ r_n)
    r_pt(cdr(assoc 10 (entget en))))
   (setq n1(1+ n1))
(setq pt1(getpoint r_pt "\n翴匡ゅ癬翴 :")
       pt0(polar r_pt (angle r_pt pt1) (/ (atof te_r) diml_f)))
(if(= "." (substr te_r 1 1))
   (setq te1 "R0")
   (setq te1 "R")
(if(= r_n 1)
   (setq te(strcat te1 te_r))
   (setq te(strcat (rtos r_n 2 0) "-" te1 te_r))
(if(> (car pt1) (car pt0))
   (setq pt2(polar pt1 0 0.5))
   (setq pt2(polar pt1 pi 0.5))
(command "leader" pt0 pt1 "" te "")
(setq n(1+ n))
  (if(> ssl_n 0)
      (setq ssc(ssadd)
     list_c '()
     n 0)
      (repeat ssl_n
(setq en(ssname ssl n)
       en_ps(cdr(assoc 10 (entget en)))
       en_pe(cdr(assoc 11 (entget en)))
       dx(abs(- (car en_ps) (car en_pe)))
       dy(abs(- (cadr en_ps) (cadr en_pe))))
(if(equal dx dy 0.001)
     (ssadd en ssc)
     (if(null (setq chk_c(member (rtos (* diml_f dx) 2 1) list_c)))
       (setq list_c(cons (rtos (* diml_f dx) 2 1) list_c))
(setq n(1+ n))
      (if(> (setq list_c_n(length list_c)) 0)
   (setq n 0)
   (repeat list_c_n
     (setq te_c(nth n list_c)
    ssc_n(sslength ssc)
    n1 0
    c_n 0)
     (repeat ssc_n
       (setq en(ssname ssc n1)
       (if(= te_c (rtos (* diml_f dx) 2 1))
  (setq c_n(1+ c_n)
        c_pt(list (/ (+ (car en_ps) (car en_pe)) 2) (/ (+ (cadr en_ps) (cadr en_pe)) 2))
       (setq n1(1+ n1))
     (setq pt1(getpoint c_pt "\n翴匡ゅ癬翴 :"))
     (if(= "." (substr te_c 1 1))
       (setq te1 "C0")
       (setq te1 "C")
     (if(= c_n 1)
       (setq te(strcat te1 te_c))
       (setq te(strcat (rtos c_n 2 0) "-" te1 te_c))
     (if(> (car pt1) (car c_pt))
     (command "leader" c_pt pt1 "" te "")
     (setq n(1+ n))
  (if sst
    (command "erase" sst "")
  (setvar "cmdecho" orig_cmd)
  (setvar "osmode" orig_osm)
  (setvar "orthomode" orig_orth)
  (setvar "clayer" orig_lay)
  (prin1)
;;;(ex_pl)
(defun ex_pl(/ sst_n en en_type n)
  (command "-layer" "m" "temp-user" "c" "47" "temp-user" "lt" "hidden" "temp-user" "")
  (command "copy" ssp "" (list 0 0) (list 0 0))
  (command "change" ssp "" "p" "la" "temp-user" "")
  (command "explode" ssp)
  (setq sst(ssget "x" '((8 . "TEMP-USER"))))
  (setq sst_n(sslength sst)
n 0)
  (repeat sst_n
    (setq en(ssname sst n)
    (cond((= "ARC" en_type) (ssadd en ssa))
    (setq n(1+ n))
  (prin1)
(princ "\n*** 欢迎使用冲模设计软件,快捷功能已成功加载如有问题可联系本人QQ:381200902源码大部分来自网络 *** <><><><> ***");(setq t tt))
 楼主| 发表于 2015-10-20 16:55:59 | 显示全部楼层
不要沉了,顶上去,大家帮帮忙啊
 楼主| 发表于 2015-10-26 20:32:26 | 显示全部楼层
再顶一下,同行们帮帮忙啊
发表于 2015-10-28 14:27:23 | 显示全部楼层
右图确实是冲压模具零件加工需要的标注方式,帮忙顶一下
GMT+8, 2025-5-21 09:32 , Processed in 0.205717 second(s), 27 queries , Gzip On.
