- 积分
- 4295
- 明经币
- 个
- 注册时间
- 2007-5-7
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
10明经币
Private Sub Initialize(ByVal vKeyString As String)
Dim intI As Integer, intJ As Integer
Randomize(Rnd(-1)) '得到初始值(种子值)
'每次调用初始值均相同
'根据初始值(种子值)得到随机数序列,每次调用Initialize时,初始值均相同。只要vKeyString相同,所产生的随机数序列一定相同
For intI = 1 To Len(vKeyString)
intJ = Rnd(-Rnd * AscW(Mid(vKeyString, intI, 1)))
Randomize(intJ)
Next intI
End Sub
Public Sub DoXor(ByRef msFileText As String)
Dim intC As Integer
Dim intB As Integer
Dim lngI As Long
For lngI = 1 To Len(msFileText)
intC = AscW(Mid(msFileText, lngI, 1))
intB = Int(Rnd() * 2 ^ 7)
'选用< =127可正确处理汉字,ChrW(n):n 有一个范围
Mid(msFileText, lngI, 1) = ChrW(intC Xor intB)
Next lngI
End Sub
Public Function Hash(ByVal ET As String) As String
Dim BitLenString As String, KeyString As String,
FileText As String
BitLenString = "12345678"
KeyString = ET & BitLenString
Call Initialize(KeyString)
'根据KeyString产生随机数序列
FileText = ET & BitLenString
Call DoXor(FileText)
'根据上述随机数序列对FileText加密
KeyString = FileText
'根据上述的加密结果产生新的随机数序列
FileText = BitLenString
'根据上述随机数序列对FileText加密,8位字符
Hash = FileText
'8位字符送作HASH值
End Function
Private Sub Button8_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button8.Click
Dim str As String = "abcd" & <a class="baidu-highlight" href="https://www.baidu.com/s?wd=vb&tn=44039180_cpr&fenlei=mv6quAkxTZn0IZRqIHckPjm4nH00T1Y3mym3nhwbm1T4mWb1nj6z0AP8IA3qPjfsn1bkrjKxmLKz0ZNzUjdCIZwsrBtEXh9GuA7EQhF9pywdQhPEUiqkIyN1IA-EUBtvnH6zrjf4nW04njcsrHDznHc" target="_blank">vb</a>CrLf
TextBox6.Text = str & Hash(str)
End Sub
unsigned int SDBMHash(char *str)
unsigned int hash = 0;
while (*str)
// equivalent to: hash = 65599*hash + (*str++);
hash = (*str++) + (hash << 6) + (hash << 16) - hash;
return (hash & 0x7FFFFFFF);
// RS Hash
unsigned int RSHash(char *str)
unsigned int b = 378551;
unsigned int a = 63689;
while (*str)
hash = hash * a + (*str++);
a *= b;
// JS Hash
unsigned int JSHash(char *str)
unsigned int hash = 1315423911;
while (*str)
hash ^= ((hash << 5) + (*str++) + (hash >> 2));
// P. J. Weinberger Hash
unsigned int PJWHash(char *str)
unsigned int BitsInUnignedInt = (unsigned int)(sizeof(unsigned int) * 8);
unsigned int ThreeQuarters = (unsigned int)((BitsInUnignedInt * 3) / 4);
unsigned int OneEighth = (unsigned int)(BitsInUnignedInt / 8);
unsigned int HighBits = (unsigned int)(0xFFFFFFFF) << (BitsInUnignedInt
- OneEighth);
unsigned int test = 0;
while (*str)
hash = (hash << OneEighth) + (*str++);
if ((test = hash & HighBits) != 0)
hash = ((hash ^ (test >> ThreeQuarters)) & (~HighBits));
// ELF Hash
unsigned int ELFHash(char *str)
unsigned int x = 0;
while (*str)
hash = (hash << 4) + (*str++);
if ((x = hash & 0xF0000000L) != 0)
hash ^= (x >> 24);
hash &= ~x;
// BKDR Hash
unsigned int BKDRHash(char *str)
unsigned int seed = 131; // 31 131 1313 13131 131313 etc..
while (*str)
hash = hash * seed + (*str++);
// DJB Hash
unsigned int DJBHash(char *str)
unsigned int hash = 5381;
while (*str)
hash += (hash << 5) + (*str++);
// AP Hash
unsigned int APHash(char *str)
int i;
for (i=0; *str; i++)
if ((i & 1) == 0)
hash ^= ((hash << 7) ^ (*str++) ^ (hash >> 3));
else
hash ^= (~((hash << 11) ^ (*str++) ^ (hash >> 5)));
最佳答案
查看完整内容
可以参考一下Mac Lee的MD5算法LISP版
