tumu2008323 发表于 2016-1-17 19:09
谁可以上传一下吗?五楼地址注册了还是不能下载啊
- ;;; ZeroRotation.lsp v1.2
- ;;; Copyright?03.09.09
- ;;; Alan J. Thompson (alanjt)
- ;;; Contact: alanjt @ TheSwamp
- ;;; Permission to use, copy, modify, and distribute this software
- ;;; for any purpose and without fee is hereby granted, provided
- ;;; that the above copyright notice appears in all copies and
- ;;; that both that copyright notice and the limited warranty and
- ;;; restricted rights notice below appear in all supporting
- ;;; documentation.
- ;;; The following program(s) are provided "as is" and with all faults.
- ;;; Alan J. Thompson DOES NOT warrant that the operation of the program(s)
- ;;; will be uninterrupted and/or error free.
- ;;; Set objects (Multileaders, Text, Mtext, Blocks) with a
- ;;; rotation of 0 (relative to current UCS).
- ;;; Revision History:
- ;;; v1.1 (10.23.09) 1. Minor rewrite for speed optimization.
- ;;; v1.2 (05.31.11) 1. Complete rewrite.
- (defun c:TE () (c:ZeroRotation))
- (defun c:ZeroRotation (/ *error* AT:UCSAngle ang ss name)
- ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; SUBROUTINES ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
- (defun *error* (msg)
- (and *AcadDoc* (vla-endundomark *AcadDoc*))
- (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
- (princ (strcat "\nError: " msg))
- (defun AT:UCSAngle (/)
- ;; Return current UCS angle
- ;; Alan J. Thompson, 04.06.10
- ((lambda (x) (atan (cadr x) (car x))) (trans (getvar 'UCSXDIR) 0 (trans '(0. 0. 1.) 1 0 T) T))
- ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; MAIN ROUTINE ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
- (vl-load-com)
- (vla-startundomark
- (cond (*AcadDoc*)
- ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
- (if (ssget "_:L" '((0 . "INSERT,MTEXT,MULTILEADER,TEXT")))
- (progn
- (setq ang (AT:UCSAngle))
- (vlax-for x (setq ss (vla-get-activeselectionset *AcadDoc*))
- (cond ((vl-position (setq name (vla-get-objectname x)) '("AcDbBlockReference" "AcDbText"))
- (vla-put-rotation x ang)
- ((eq name "AcDbMText") (vla-put-rotation x 0.))
- ((and (eq name "AcDbMLeader") (eq (vla-get-contenttype x) 2))
- (vla-put-textrotation x 0.)
- (vla-delete ss)
- (*error* nil)
- (princ)
