查看: 5296|回复: 20
删除
发表于 2015-11-28 10:42:48 | 显示全部楼层 |阅读模式
删除
发表于 2015-11-28 11:37:11 | 显示全部楼层
没必要这种联动,直接使用popup_list就行了。
 楼主| 发表于 2015-11-28 13:26:56 | 显示全部楼层
之前学了一些,都不记得怎么做的了,哥们能不能帮我实现一下,谢谢
发表于 2015-11-28 14:10:26 | 显示全部楼层
(write-line
    ":list_box  {label=\"选择字高\";key=\"zgxz\";is_default=ture; }"
    f
改成
(write-line
    ":popup_list  {label=\"选择字高\";key=\"zgxz\";is_default=ture; }"
    f
发表于 2015-11-28 14:53:04 | 显示全部楼层
  1. (defun c:tt ()
  2. ;;;;;对话框
  3.   (vl-load-com)
  4.   (setq newname (vl-filename-mktemp "txsize.dcl")
  5.         f (open newname "w"))
  6.   (write-line "txsize:dialog{label="文字高度设置";" f)
  7.   (write-line ":edit_box{label="文字高度";key="txtsiz";is_default=ture;}" f)
  8.   (write-line ":list_box{label="选择字高";key="zgxz";is_default=ture;}" f)
  9.   (write-line "ok_only;} " f)
  10.   (close f)
  11.   (new_dialog "txsize" (setq dcl_id (load_dialog newname)))
  12.   (set_tile "txtsiz" "45")
  13.   (start_list "zgxz")
  14.   (mapcar 'add_list (setq zgxz (list "1.0" "1.5" "2.0" "3.0" "5.0" "10.0" "15.0" "20.0" "25.0" "30.0")))
  15.   (end_list)
  16.   (action_tile "OK" "(get_maisiz)(done_dialog 1)")
  17.   (action_tile "zgxz" "(set_tile "txtsiz" (nth (atoi(get_tile "zgxz")) zgxz))")
  18.   (setq dd (start_dialog))
  19.   (if (= dd 1) (princ pp))
  20.   (start_dialog)
  21.   (unload_dialog dcl_id)
  22.   (vl-file-delete newname)
  23.   (princ)
  24. )
  25. (defun get_maisiz ()
  26.   (setq pp (get_tile "txtsiz"))
  27.   (print "AA")
  28.   (print pp)
  29. )
 楼主| 发表于 2015-11-28 15:43:51 | 显示全部楼层
ZZXXQQ 发表于 2015-11-28 14:53
非常感谢
 楼主| 发表于 2015-11-28 15:48:52 | 显示全部楼层
(setq pp (get_tile "txtsiz"))不能获得PP的值
发表于 2015-11-28 19:29:47 | 显示全部楼层
一般可套用 dos_combolist
Command: (dos_combolist "Set Text Height" "Select a Height" zgxz)
"10.0"
发表于 2015-11-28 23:31:12 | 显示全部楼层
求帮忙能帮帮我吗?
 楼主| 发表于 2015-11-29 08:15:28 | 显示全部楼层
张大锤 发表于 2015-11-28 23:31
求帮忙能帮帮我吗?
??什么情况
GMT+8, 2025-12-6 07:55 , Processed in 0.200146 second(s), 32 queries , Gzip On.
