查看: 1345|回复: 8
[提问] 如何通过关键字提取表中的元素?
发表于 2015-12-5 22:45:00 | 显示全部楼层 |阅读模式
setq we ("a,123,111" "b,321,222" "c,345,333")如何通过关键字a提取a,123,111或关键字b提取b,321,222或关键字c提取c,345,333?
 楼主| 发表于 2015-12-5 22:46:09 | 显示全部楼层
自己先顶一下
发表于 2015-12-6 08:00:33 | 显示全部楼层
  1. ;;; by USER2128:
  2. (defun aaa (lst key)
  3.   (car (vl-remove 'nil (mapcar '(lambda(x)
  4.     (if (= (strcase (substr x 1 (strlen key))) (strcase key))
  5.       x nil)) lst)))
  6.   )
  7. (setq lst '("a,123,111" "b,321,222" "c,345,333"))
  8. ;;; (aaa lst "a,") ==> "a,123,111"
  9. ;;; (aaa lst "B,") ==> "b,321,222"
  10. ;;; (aaa lst "c")  ==> "c,345,333"
发表于 2015-12-6 10:11:25 | 显示全部楼层
(cdr (assoc key (mapcar '(lambda(x) (cons (substr x 1 1) x)) lst)))
发表于 2015-12-6 10:46:00 来自手机 | 显示全部楼层
(car (vl-member-if '(lambda(x) (wcmatch x "a*")) lst))
 楼主| 发表于 2015-12-6 17:49:23 | 显示全部楼层
USER2128 发表于 2015-12-6 08:00
谢谢
 楼主| 发表于 2015-12-6 17:50:00 | 显示全部楼层
谢谢!!
 楼主| 发表于 2015-12-6 17:50:35 | 显示全部楼层
谢谢!!!
发表于 2015-12-19 17:59:03 | 显示全部楼层
好东西值得分享
GMT+8, 2025-5-21 01:09 , Processed in 0.176125 second(s), 25 queries , Gzip On.
