查看: 1095|回复: 0
[提问] undo的问题
发表于 2015-12-9 17:06:57 | 显示全部楼层 |阅读模式
  1. (defun c:cn(/ sg gp11 gp12 sg1 gp21 gp22 sg2 gp31 gp32)
  2.
  3.   (while (null sg)
  4.     (setq sg(ssget))
  5.   )
  6.
  7.   (command "_undo" "be")
  8.   (initget 1)
  9.   (setq gp11(getpoint "\n指定第一个源点:"))
  10.   (initget 1)
  11.   (setq gp12(getpoint "\n指定第一个目标点:" gp11))
  12.   (command "line" gp11 gp12 "")
  13.   (setq sg1 (ssget "l"))
  14.   (command "chprop" sg1 "" "c" 7 "")
  15.
  16.   (initget 1)
  17.   (setq gp21(getpoint "\n指定第二个源点:"))
  18.   (initget 1)
  19.   (setq gp22(getpoint "\n指定第二个目标点:" gp21))
  20.   (command "line" gp21 gp22 "")
  21.   (setq sg2 (ssget "l"))
  22.   (command "chprop" sg2 "" "c" 7 "")
  23.
  24.   (if(setq gp31(getpoint "\n指定第三个源点:"))
  25.     (progn
  26.       (setq gp32(getpoint "\n指定第三个目标点:" gp31))
  27.       (command "copy" sg "" "0,0" "" "align" sg "" gp11 gp12 gp21 gp22 gp31 gp32 )
  28.     )
  29.     (progn
  30.       (setq gp32 1)
  31.       (command "copy" sg "" "0,0" "" "align" sg "" gp11 gp12 gp21 gp22 "" "n")
  32.     )
  33.   )
  34.   (command "_erase" sg1 sg2 "")
  35.
  36.   (command "_undo" "e")
  37.   (princ)
  38. )
命令运行完成后,我用U命令并不能返回到(command "_undo" "be"),这是为什么?
GMT+8, 2025-11-26 13:27 , Processed in 0.186102 second(s), 29 queries , Gzip On.
