查看: 2237|回复: 6
ThisDrawing.Blocks.Item(ExternalBlock).Bind False
发表于 2004-2-27 13:38:00 | 显示全部楼层 |阅读模式
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt">为甚么会出现"Invalid procedure call or argument"的错误提示
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt">请高手帮我解答为谢<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
发表于 2004-2-27 13:52:00 | 显示全部楼层
ExternalBlock必须是一个字符串,而且必须是块的名称,这个块必须是外部引用块。
 楼主| 发表于 2004-2-27 14:17:00 | 显示全部楼层
Dim InsertPoint(0 To 2) As Double
Dim ExternalBlock As AcadExternalReference
Dim TempBlock As AcadBlock
Dim MsgStr As String
For I = 1 To 10 Dim J As Integer
J = 10 * I InsertPoint(0) = 1 + J InsertPoint(1) = 1 + J InsertPoint(2) = 0 FileName = "E:\lgs\4052.dwg" Set ExternalBlock = ThisDrawing.ModelSpace.AttachExternalReference(FileName, "ExternalReference", InsertPoint, 1, 1, 1, 0, False) ThisDrawing.Blocks.Item(ExternalBlock).Bind False Next
请帮我看看这些代码有甚么问题吗?
发表于 2004-2-27 15:00:00 | 显示全部楼层
ExternalBlock是个实体,不是字符串
 楼主| 发表于 2004-2-27 15:37:00 | 显示全部楼层
ThisDrawing.Blocks.Item(ExternalBlock1.name).Bind False
ThisDrawing.Blocks.Item(ExternalBlock2.name).Bind False
< class=MsoNormal style="MARGIN: 0cm 0cm 0pt">为甚么不能两次采用Bind,也不能运行两次<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
发表于 2004-2-27 16:31:00 | 显示全部楼层
ExternalBlock1?ExternalBlock2?有没有指向有效的块引用对象。
 楼主| 发表于 2004-2-27 16:40:00 | 显示全部楼层
But files access error!
GMT+8, 2025-11-30 04:15 , Processed in 0.143350 second(s), 24 queries , Gzip On.
