查看: 15289|回复: 81
[源码] 将多个点连接为曲线
发表于 2015-12-28 23:31:27 | 显示全部楼层 |阅读模式
;;;连点成线
(defun c:t1 (/ ptlist)
  (setvar "blipmode" 0)
  (setvar "pickfirst" 1)
  (setvar "expert" 0)
  (setvar "GRIPOBJLIMIT" 50)
  (setvar "osmode" 15359)
  (setvar "cmdecho" 0)
  (princ "\n★功能:将邻近的点连接为一条曲线。\n")
  (vl-load-com)
  (princ "\n请选择要连接的点对象:\n")
  (command "undo" "be")
  (setq ss (ssget '((0 . "POINT"))))
  (if (null ss)
    (progn (princ "\n提示:未选取点对象!") (exit))
  (initget "P S")
  (if (not
        (setq kw
               (getkword
                 "曲线样式:[多段线(P)/样条曲线(S)]<S>"
    (setq kw "S")
(setq i 0)
  (setvar "osmode" 0)
  (repeat (sslength ss)
    (setq entnam (entget (ssname ss i))
          pt         (cdr (assoc 10 entnam))
          ptlist (cons pt ptlist)
          i         (1+ i)
  (setq        ptlist (vl-sort        ptlist
                        '(lambda (e1 e2)
                           (if (equal (car e1) (car e2) 1e-5)
                             (if (equal (cadr e1) (cadr e2) 1e-5)
                               (< (cadr e1) (cadr e2))
                               (< (car e1) (car e2))
  (if (= kw "P")
      (command "pline")
      (foreach pt ptlist (command pt))
      (command "")
      (command "spline")
      (command "" "" "")
  (command "undo" "e")
参与人数 1明经币 +1 金钱 +10 收起 理由
lucas_3333 + 1 + 10 分享快乐!
发表于 2024-1-11 11:27:26 | 显示全部楼层
取點成線,取點成曲線,在路徑規劃,地圖分析有妙用!
发表于 2025-5-17 11:14:19 | 显示全部楼层
感谢分享代码!
发表于 2024-1-4 19:31:04 | 显示全部楼层
收藏,将多个点连接为曲线
发表于 2025-5-16 12:22:25 | 显示全部楼层
感谢分享,好程序
发表于 2021-11-19 20:56:37 | 显示全部楼层
多谢楼主!学习学习
发表于 2019-11-25 11:56:10 | 显示全部楼层
路过学习下喽
发表于 2019-9-14 16:35:54 | 显示全部楼层
挺好的,收一下
发表于 2019-7-26 14:47:03 | 显示全部楼层
学习学习!多谢楼主!!
发表于 2016-6-27 10:46:42 | 显示全部楼层
看看思路,学习一下!
GMT+8, 2025-6-24 04:27 , Processed in 0.207921 second(s), 35 queries , Gzip On.
