查看: 1742|回复: 4
[源码] 一句话改造copy和move命令
发表于 2015-12-30 16:40:40 | 显示全部楼层 |阅读模式
经常用到move 和 copy 命令,对这两个命令进行小改造:
  1. (defun c:mx ( / p1)
  2.         (command "move" (ssget) "" (setq p1 (getpoint "\n请点取基点:")) (subst (car (getpoint "\n请点取参考点:")) (car p1) p1))
  3.         (princ)
  4. )
  5. (defun c:my ( / p1)
  6.         (command "move" (ssget) "" (setq p1 (getpoint "\n请点取基点:")) (subst (cadr (getpoint "\n请点取参考点:")) (cadr p1) p1))
  7.         (princ)
  8. )
  9. (defun c:cx ( / p1)
  10.         (command "copy" (ssget) "" (setq p1 (getpoint "\n请点取基点:")) (subst (car (getpoint "\n请点取参考点:")) (car p1) p1))
  11.         (princ)
  12. )
  13. (defun c:cy ( / p1)
  14.         (command "copy" (ssget) "" (setq p1 (getpoint "\n请点取基点:")) (subst (cadr (getpoint "\n请点取参考点:")) (cadr p1) p1))
  15.         (princ)
  16. )
发表于 2015-12-31 08:57:51 | 显示全部楼层
思路很好呀,有时候不用添加辅助线。。。。
发表于 2015-12-31 09:14:30 | 显示全部楼层
不错
发表于 2015-12-31 22:32:38 | 显示全部楼层
不是有各种捕捉的方法与坐标过滤吗?这些都可以实现你需要的效果,不需要专门写个程序来处理的。
发表于 2016-1-12 15:27:48 | 显示全部楼层
.x
.y
.xy
不过对象追踪也很不错
GMT+8, 2025-4-30 18:14 , Processed in 0.173709 second(s), 30 queries , Gzip On.
