查看: 949|回复: 1
id.getobject失效了吗? 出致命错误!?
发表于 2016-1-8 13:13:27 | 显示全部楼层 |阅读模式
下面的代码
        <CommandMethod("ShowEntType")>
        Public Shared Sub Crotate()
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            ed = Application.DocumentManager.MdiActiveDocument.Editor
            ed.WriteMessage(vbLf & "选择实体: ")
            Dim res As PromptSelectionResult = ed.GetSelection()
            Dim SS As SelectionSet = res.Value
            For Each theid As ObjectId In SS.GetObjectIds
               Dim ent As Entity = CType(theid.GetObject(OpenMode.ForWrite), Entity)
               ed.WriteMessage(ent.GetType.ToString)
            Next
        End Sub
会在Dim ent As Entity = CType(theid.GetObject(OpenMode.ForWrite), Entity) 这里出致命错误,只有用
    Dim db As Database
            Dim tm As Transaction
            db = HostApplicationServices.WorkingDatabase
            tm = db.TransactionManager.StartTransaction()
            '  Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            '构建用于移动实体的矩阵
            Dim vector As Vector3d = sourcePt.GetVectorTo(targetPt)
            Dim mt As Matrix3d = Matrix3d.Displacement(vector)
            '以写的方式打开id表示的实体对象
            Try
                Dim acadEntity As Entity = CType(tm.GetObject(id, OpenMode.ForWrite), Entity)
                ' ed.WriteMessage(vbCrLf & acadEntity.IsWriteEnabled.ToString)
                acadEntity.TransformBy(mt)
                tm.Commit()
            Finally
                tm.Dispose()
            End Try
这样的语法才不会出错,这是什么原因呢?
查询objectid是有这个GetObject接口的。
 楼主| 发表于 2016-1-8 14:13:18 | 显示全部楼层
GMT+8, 2025-5-24 18:18 , Processed in 0.162214 second(s), 23 queries , Gzip On.
