查看: 1841|回复: 5
[求助]问题多多啊!!!
发表于 2004-2-29 19:55:00 | 显示全部楼层 |阅读模式
我的一个程序,原意是点击一个图框然后图框里的各种比例都相应于图框比例变化(图框的外框用封闭的polyline绘制,然后再作成块,需要时只是scale一下,通过函数可以获得放大比例)。但是我发现用endmake建立dimstyle时,不能建立标注文字样式和箭头样式,总是用standard文字样式代替,不知道怎么解决!!所以写不下去了。 下面是我的code,请帮助!可以试用 ;点图框修改图框内的各种比例
;(a3图框按1:1画出,并且内框用闭和pl画出,然后做成块)
;以便取出四个角点
(Defun c:#ss ()
;------sub function:列出符号"block"的表.----------------
(defun block_list (elist)
(setq dict_block_name (cdr(assoc 2 elist))
dict_block_list (tblsearch "block" dict_block_name)
dict_block_xobject(cdr (assoc -2 dict_block_list))
block_xlist '()
(while (setq block_xlist (cons (entget dict_block_xobject) block_xlist)
dict_block_xobject (entnext dict_block_xobject)
;-----sub function:修改标注比例--------
(defun dim_style (c_scale)
(setq dim_sj '((0 . "DIMSTYLE") (100 . "AcDbSymbolTableRecord")
(100 . "AcDbDimStyleTableRecord")
(2 . "$1") (70 . 0)(40 . 1.0) (41 . 1.5)
(42 . 1.0) (43 . 1.0) (44 . 1.0) (73 . 0)
(74 . 0) (77 . 1)(78 . 8) (140 . 2.5) (141 . 0.0)
(147 . 1.0) (176 . 1) (177 . 1) (178 . 2)
(271 . 1) (272 . 1) (279 . 2) (284 . 8))
(entmake dim_sj)
(if (>= (- c_scale (fix c_scale)) 0.5)
(setq c_sc(itoa (1+ (fix c_scale))))
(setq c_sc (itoa (fix c_scale)))
(setq dim_sj (subst (cons 2 (strcat "$" c_sc)) (assoc 2 dim_sj) dim_sj))
(setq dim_sj (subst (cons 40 (read c_sc)) (assoc 40 dim_sj) dim_sj))
(entmake dim_sj)
(command "-dimstyle" "r" (strcat "$" c_sc)) ;上边也有问题:建立了新标注 后不 能让它成为当前注
;必须要用上面那句话来让它成为当前标注
(command "-dimstyle" "a" "wp" p0 p1 p2 p3 "" "")
;----------main function----------------------------------
(while(not(setq entname(car (entsel ":请选择图框:"))))
(princ "\n图框不是块!从新选择.")
(setq entlist (entget entname '("*"))
(setq c_scale (cdr (assoc 41 entlist))
c_to_ucs (trans (cdr (assoc 10 entlist) ) 0 1)
(block_list entlist)
(setq block_xlist (reverse block_xlist))
(type (car block_xlist))
(setq len_th (length block_xlist)
list1 '()
(repeat len_th
(if(and
(vl-position '(0 . "LWPOLYLINE") (nth 0 block_xlist))
(vl-position '(70 . 1) (nth 0 block_xlist))
(setq list1 (cons (nth 0 block_xlist) list1 )
block_xlist (vl-remove (nth 0 block_xlist) block_xlist))
(setq block_xlist (vl-remove (nth 0 block_xlist) block_xlist))
(setq list1 (car list1)
counter 0
p_list '()
(while (setq bb (nth counter list1))
(if (= (car bb) 10)
(setq point (nth counter list1)
p_list (cons point p_list)
counter (1+ counter)
(setq counter (1+ counter))
;;;-很奇怪,如果放大插入块,reference-block 的数据结构中符号表中的数据(lwploylien的连接点点位居然不变,
;;;只好把ocs的点坐标乘以当前块的比例系数(c_scale)再加上ucs下的插入点坐标(经trans函数处理),以得到图的
;;;四个角点.
(setq dp(cdr(nth 0 p_list))
p0 (mapcar '+ (mapcar '* (list c_scale c_scale c_scale)
(reverse(cons '0.0 (reverse dp)))) c_to_ucs))
(setq dp(cdr(nth 1 p_list))
p1 (mapcar '+ (mapcar '* (list c_scale c_scale c_scale)
(setq dp(cdr(nth 2 p_list))
p2 (mapcar '+ (mapcar '* (list c_scale c_scale c_scale)
(setq dp(cdr(nth 3 p_list))
p3 (mapcar '+ (mapcar '* (list c_scale c_scale c_scale)
(setq p_l(list p0 p1 p2 p3))
(setq ss_get (ssget "wp" p_l))
(dim_style c_scale)
发表于 2004-3-1 18:51:00 | 显示全部楼层
给个图先!
 楼主| 发表于 2004-3-1 19:05:00 | 显示全部楼层
不懂,具体点好吗?
meflying发表于2004-3-1 18:51:00给个图先!
到底怎么用endmake建立dimstyle 中的文字样式?请斑竹详细说一下,谢谢!
发表于 2004-3-1 20:19:00 | 显示全部楼层
给个图一供调试,不一定能建一个跟你要求相同的图框,除非把整个程序看明白了,不过这样就太费劲了,有个图调试,再来看问题,就简单很多
 楼主| 发表于 2004-3-1 23:13:00 | 显示全部楼层
不能上传!
哦,好的。看附件。用了再说问题。本来还再原程序中加了一段显示四个角点点位的listbox,并且在四点连线以确定是否放缩后依然能找到角点,这个时候就出现了我在最开始说的问题(符号block中,pl的四个连接点点位部随缩放更新,必须要乘以块的比例(x.y.z比例一致),后来想想这个数据结构石对的,应该不变,是一个基本值。
然后就出了第二个问题,如何建立dimstyle中的文字样式和箭头样式(分别以330.340为组码),所以请帮忙!
好象不能上传!实在不行,请斑竹简单的用pl画一个框然后作成块,然后缩放图框,并且再图框中放一些标注,再运行命令,就可以了!
发表于 2004-3-2 09:23:00 | 显示全部楼层
1、你说不能用entmake建立dimstyle,可在程序中你已经做到了 2、看看帮助文件的介绍:
(只读)
类型:字符串
保存位置:图形
DIMSTYLE 既是命令又是系统变量。作为系统变量,DIMSTYLE 将显示当前标注样式。要显示 DIMSTYLE 系统变量,请使用 SETVAR 命令。DIMSTYLE 系统变量类型是只读的,不能在命令行修改它的值。要改变当前标注样式,请使用 DIMSTYLE 命令。
3、无论你怎样放大及缩小块,其实改变的是INSERT对象,而并没有对BLOCK对象做任何修改,所以其内部一些东西当然就没有改变了
GMT+8, 2025-5-14 05:13 , Processed in 0.173847 second(s), 25 queries , Gzip On.
