查看: 1514|回复: 3
[提问] 可以框选块内对象吗?
发表于 2016-1-22 17:43:32 | 显示全部楼层 |阅读模式
  • (ssget "_:S") - selecting a single object
  • (ssget "_:E") - selecting all objects crossing the selection box (can be also combined to e.g. (ssget "_:E:S")
  • (ssget "_:N") - selecting objects including nested/child objects - e.g. with block references, polymeshes, etc.
  • (ssget "_:D") - duplicate objects counted separately (2x selected object = 2 selections)
  • (ssget "_:L") - stops users from selecting objects on locked layers
  • (ssget "_:P") - rejects selection of viewports
  • (ssget "_:R") - allow selection in long transactions
  • (ssget "_:U") - enable subentity selection with Ctrl
  • (ssget "_:V") - force subentity selection
  • (ssget "_+.") - allows window selection even in the single selection mode - e.g. (ssget "_+.:E:S") (may not work in some localized versions of AutoCAD)
(ssget "_:V")根本就不能选择子对象。nentsel又只能选一个对象。
发表于 2016-1-22 21:55:20 来自手机 | 显示全部楼层
行当然行,但不是一般人能搞定的
 楼主| 发表于 2016-1-22 22:07:08 | 显示全部楼层
arx????
发表于 2023-3-15 02:19:25 | 显示全部楼层
自贡黄明儒 发表于 2016-1-22 21:55
行当然行,但不是一般人能搞定的
有这个需求
GMT+8, 2025-5-14 23:41 , Processed in 0.165871 second(s), 26 queries , Gzip On.
