查看: 4102|回复: 12
[讨论] 如何删除重复的线
发表于 2016-1-23 21:07:20 | 显示全部楼层 |阅读模式
求删除重复线的思路,把一个图层中重复的多段线给删掉,怎么才能实现呢?得用到那个函数啊谢谢各位啦先
发表于 2017-11-14 17:01:57 | 显示全部楼层
(defun c:scf(/ dxf tang chg_ent on_ent undup os 2pi sline sarc scircle n ss ent pmt)
     (setvar "cmdecho" 0)
     (PRINC "\n刪除重複功能")
    (PRINC)
  (defun dxf(ent i)
    (cdr (assoc i (entget ent)))
  (defun tang(ang sty)
    (rem (+ 2pi ang) sty)
  (defun chg_ent(ent i pt / en)
    (setq en (entget ent) en (subst (cons i pt) (assoc i en) en))
    (entmod en)
  (defun on_ent(a a1 a2 sty)
    (if (= sty "直線")
      (equal (+ (distance a1 a) (distance a a2)) (distance a1 a2) 0.01)
      (if (> a2 a1) (>= a2 a a1) (or (<= a a2) (>= a a1)))
  (defun undup(s sty / nm m ss ent1 spt1 ept1 cpt1 r1 ent2 spt2 ept2 cpt2 r2)
    (setq n -1 nm 0)
    (if (= sty "圓")
      (repeat (sslength s)
        (setq ent1 (ssname s (setq n (1+ n))))
        (if (entget ent1)
            (setq cpt1 (dxf ent1 10) r1 (dxf ent1 40))
            (if (setq ss (ssget "x" (list (cons 0 "circle") (cons 10 cpt1) (cons 40 r1))))
                (ssdel ent1 ss)
                (setq m -1)
                (repeat (sslength ss)
                  (setq ent (ssname ss (setq m (1+ m))))
                  (if (not (ssmemb ent s))
                      (ssdel ent ss)
                      (setq m (1- m))
                (command "_.erase" ss "")
                (setq nm (+ nm (sslength ss)))
        (if (entget ent1)
            (if (= sty "直線")
              (setq spt1 (dxf ent1 10) ept1 (dxf ent1 11))
              (setq spt1 (tang (dxf ent1 50) 2pi)
                    ept1 (tang (dxf ent1 51) 2pi)
                    cpt1 (dxf ent1 10)
                    r1 (dxf ent1 40)
            (if (setq ss (if (= sty "直線")
                           (ssget "cp" (list (polar spt1 (angle ept1 spt1) 0.1)
                                             (polar ept1 (- (angle spt1 ept1) (/ pi 4)) 0.15)
                                             (polar ept1 (+ (angle spt1 ept1) (/ pi 4)) 0.15)
                                       ) '((0 . "line"))
                           (ssget "x" (list (cons 0 "arc") (cons 10 cpt1) (cons 40 r1)))
                (ssdel ent1 ss)
                (setq m -1)
                      (ssdel ent ss)
                      (setq m (1- m))
                (setq m -1)
                  (setq ent2 (ssname ss (setq m (1+ m))))
                  (if (= sty "直線")
                    (setq spt2 (dxf ent2 10)
                          ept2 (dxf ent2 11)
                    (setq spt2 (tang (dxf ent2 50) 2pi)
                          ept2 (tang (dxf ent2 51) 2pi)
                          cpt2 (dxf ent2 10)
                          r2 (dxf ent2 40)
                  (cond
                    ((and (on_ent spt2 spt1 ept1 sty) (on_ent ept2 spt1 ept1 sty))
                      (entdel ent2)
                    ((and (on_ent spt1 spt2 ept2 sty) (on_ent ept1 spt2 ept2 sty))
                      (entdel ent1)
                      (setq ent1 ent2 spt1 spt2 ept1 ept2)
                      (if (= sty "圓弧")
                        (setq cpt1 cpt2 r1 r2)
                    ((and (if (= sty "直線")
                            (equal (tang (angle spt1 ept1) pi) (tang (angle spt2 ept2) pi) 0.001)
                            T
                          (or (on_ent spt2 spt1 ept1 sty) (on_ent ept2 spt1 ept1 sty))
                      (entdel ent2)
                      (if (= sty "直線")
                          (if (on_ent spt2 spt1 ept1 sty)
                            (setq spt2 ept2)
                          (if (> (distance spt1 spt2) (distance ept1 spt2))
                            (progn (chg_ent ent1 11 spt2) (setq ept1 spt2))
                            (progn (chg_ent ent1 10 spt2) (setq spt1 spt2))
                          (progn (chg_ent ent1 51 ept2) (setq ept1 ept2))
                          (progn (chg_ent ent1 50 spt2) (setq spt1 spt2))
                    (T (setq nm (1- nm)))
                  (setq nm (1+ nm))
    (prompt (strcat "-->共選到:" (itoa (sslength s)) "個" sty ",消去" (itoa nm) "個。"))
  (command "_.undo" "_be")
  (command "_.ucs" "")
  (setq os (getvar "osmode")
        2pi (* 2 pi)
        sline (ssadd)
        sarc (ssadd)
        scircle (ssadd)
        n -1
  (setvar "osmode" 0)
  (prompt "\n請選取 直線或圓")
  (if (setq ss (ssget '((0 . "line,arc,circle"))))
      (prompt "\n正在消除合併重複線條,請稍後...")
      (prompt "\n")
        (setq ent (ssname ss (setq n (1+ n))))
        (cond
          ((= (dxf ent 0) "LINE") (ssadd ent sline))
          ((= (dxf ent 0) "ARC") (ssadd ent sarc))
          ((= (dxf ent 0) "CIRCLE") (ssadd ent scircle))
  (if (> (sslength sline) 1) (progn (undup sline "直線") (setq pmt T)))
  (if (> (sslength sarc) 1) (progn (undup sarc "圓弧") (setq pmt T)))
  (if (> (sslength scircle) 1) (progn (undup scircle "圓") (setq pmt T)))
  (if (and ss (not pmt)) (prompt "\n沒有重複線段"))
  (setvar "osmode" 695)
(PRINC "\n所選地方 刪除重複 完成")
(PRINC)
发表于 2017-11-6 12:05:50 | 显示全部楼层
一直,想自己写一个。但是一直没有动手。
一是网上有很多,直接借用就好,二来时,是自己作图习惯的问题。
很少有重复线。
有重复线的图一般都比较乱,比如客人给的图,3D直接转过来的图,那个叫晕,
断线,重复线,z坐标不在一个面上,圆全是碎的。
发表于 2018-3-29 13:46:34 | 显示全部楼层
非常好用
发表于 2016-1-23 21:26:53 | 显示全部楼层
消除重覆圖元
消除重覆圖元
 楼主| 发表于 2016-1-23 21:30:18 | 显示全部楼层
song宋_74729 发表于 2016-1-23 21:26
引用 flyfox1047 原碼
(defun unique ( linlst )
能解释下不,看不懂[em0]
发表于 2016-1-23 21:34:37 | 显示全部楼层
菜鸟的萌 发表于 2016-1-23 21:30
能解释下不,看不懂
此回答让人无语~~~
发表于 2016-1-24 09:13:05 | 显示全部楼层
overkill CAD自带命令
发表于 2016-1-24 21:48:01 | 显示全部楼层
发表于 2017-11-5 16:02:43 | 显示全部楼层
谢谢楼主分享!
GMT+8, 2025-5-1 02:55 , Processed in 0.222818 second(s), 32 queries , Gzip On.
