- 积分
- 8571
- 明经币
- 个
- 注册时间
- 2008-4-2
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2016-2-29 16:07:00
显示全部楼层
CopyObjects Method
Duplicates multiple objects (deep cloning).
RetVal = object.CopyObjects(Objects[, Owner][, IDPairs])
Object
Database, Document
The object or objects this method applies to.
Objects
Variant (array of objects); input-only
The array of primary objects to be copied. All the objects must have the same owner, and the owner must belong to the database or document that is calling this method.
Owner
Variant (a single object); input-only; optional
The new owner for the copied objects. If no owner is specified, the objects will be created with the same owner as the objects in the Objects array.
IDPairs
Variant (array of IDPair objects); input-output; optional
Information on what happened during the copy and translation process.
Input: an empty variant.
Output: an array of IDPair objects.
RetVal
An array of newly created duplicate objects. Only primary objects are returned in this array. For more information on what occured during the CopyObjects operation, or a list of objects owned by primary objects that were also copied, consult the IDPairs array.
Remarks
To copy objects to another open drawing, set the Owner parameter to the other drawing's model space.
During the CopyObjects operation, objects that are owned or referenced by the primary objects in the Objects parameter will also be copied.
NOTE You cannot execute this method while simultaneously iterating through a collection. An iteration will open the work space for a read-only operation, while this method attempts to perform a read-write operation. Complete any iteration before you call this method.
