查看: 756|回复: 1
[提问] 求在绘多义线的同时能在线附近上标注出整段线的长度(起点到终点的从长度)
发表于 2016-3-8 22:57:11 | 显示全部楼层 |阅读模式
发表于 2020-8-14 22:11:23 | 显示全部楼层
(defun C:DZ (/ *error*_bak *error*_ch ang0 arc_cen arc_cen3d arc_stap b dist_offset
   ent_ss ent_xname entli_x i i_ss l_angle l_endp l_midp2d l_midp3d l_stap
   list_l osm_old pt3_arc pt3_line repeat_no ss ss_after_explod sss x y
;;;出错系统变量恢复函数-----
(defun *error*_CH (msg)
  (command)
  (setq *error* *error*_bak)
  (setvar "CMDECHO" 1)
  (setvar "osmode" osm_old)
; (print msg)
;;;更改系统变量------
(defun var_temp ()
  (setvar "CMDECHO" 0)
  (setvar "osmode" 0)
;;;恢复系统变量------
(defun var_should ()
;;; ===角度转弧度===
(defun dtr (ang0)
  (* ang0 (/ pi 180.0))
;;; 选择线,并转为多义线程序
(defun lj (sss / b)
  (setvar "peditaccept" 1)               ; 设置系统变量,避免区分直线和多段线.
  (setq b sss)
  (command "pedit" "m" b "" "j" "0" "")
  (setvar "peditaccept" 0)
  (prin1)
;| 判断POLYLINE顺时针或逆时针--------------------------------------------------------
  (defun CH:plfx (ent_ss / ang direction fd offdis offobj offsetplineobj plineobj)
  (if ent_ss
      (setq plineObj (vlax-ename->vla-object ent_ss))
      (setq fd (vlax-curve-getFirstDeriv plineObj 0.5))
      (setq ang (atan (/ (cadr fd) (car fd))))
      (setq offdis 1e-5)
      (while (vl-catch-all-error-p
               (setq offobj (vl-catch-all-apply 'vla-offset (list plineObj offdis)))
        (setq offdis (* 10 offdis))
      (setq offsetplineObj (car (vlax-safearray->list (vlax-variant-value offobj))))
      (if (> (vla-get-length plineobj) (vla-get-length offsetplineobj))
        (setq direction "clockwise")
        (setq direction "anticlockwise")
      (vla-delete offsetplineObj)
    )                                       ; progn
    ;(princ "\nNo object selected or object selected is not a polyline.")
  )                                       ; end_if
  direction
  (princ "\n 请选择多线段: ")
  (setq ss (ssget '((0 . "LWPOLYLINE") (100 . "AcDbPolyline"))));选择多线段
  ;(setq dist_offset (getdist "\n输入标注偏移距离: "))
  (setq dist_offset 50)
  (command "_.undo" "BE")
  (setq *error*_bak *error*)
  (setq *error* *error*_CH)
  (setq osm_old (getvar "osmode"));获得原标注系统变量参数
  (var_temp);更改系统变量
  (graphscr)
  (setq i_ss 0)
  (repeat (sslength ss)
    (setq ent_ss (ssname ss i_ss));获得多线图元名
    ;(setq pl_direction (CH:plfx ent_ss));判断多线方向
    (command "_.EXPLODE" ent_ss "");炸开多线图元
    (setq list_l nil)
    (setq ss_after_explod (ssget ""));获得炸开后线段的选择集
    (setq repeat_No (sslength ss_after_explod)
          i 0)
    (repeat repeat_No
      (setq ent_xname (ssname ss_after_explod i))
      (setq entLi_x (entget ent_xname))
      (if (= (cdr (assoc 0 entLi_x)) "ARC")
          (setq arc_cen3D (cdr (assoc 10 entLi_x));弧形圆心坐标3D
                arc_cen (list (car arc_cen3D) (cadr arc_cen3D));弧形圆心坐标2D
                pt3_arc (polar arc_cen (+ (cdr (assoc 50 entLi_x)) 0.1) (+ dist_offset (cdr (assoc 40 entLi_x))));标注放置点
                arc_StaP (polar arc_cen (cdr (assoc 50 entLi_x)) (cdr (assoc 40 entLi_x)));圆弧起点坐标
          (command "_.DIMARC" (list ent_xname arc_StaP) pt3_arc)
          (setq L_StaP (cdr (assoc 10 entLi_x));线段起点坐标
                L_EndP (cdr (assoc 11 entLi_x));线段终点坐标
                L_MidP3D (mapcar '(lambda (x y) (* (+ x y) 0.5)) L_StaP L_EndP);线段中心点3D
                L_MidP2D (mapcar '+ '(0 0) L_MidP3D);线段中心点2D
                L_angle (angle L_StaP L_EndP);线段角度
;          (if (= pl_direction "clockwise")
;            (setq pt3_line (polar L_MidP2D (+ L_angle (dtr 90)) dist_offset));标注放置点
;            (setq pt3_line (polar L_MidP2D (+ L_angle (dtr 90)) (- dist_offset)))
          ;(command "_.dimaligned" "" (list ent_xname L_MidP2D) pt3_line)
            ;(command ".line"  L_StaP  L_EndP "")
(command ".TEXT" "j" "m" pt3_line "40" "0" (STRCAT (rtos i 2 0) "K"))
      (setq i (1+ i))
    (lj ss_after_explod)
    (setq i_ss (1+ i_ss))
    (command "_.undo" "E")
  (var_should)
  (princ "\n共有< ")
  (princ (sslength ss))
  (princ " >条多线段标注完成,请查看!")
GMT+8, 2025-5-18 00:02 , Processed in 0.178132 second(s), 26 queries , Gzip On.
