查看: 1127|回复: 5
[提问] 请问如何对一个文件夹下的所有txt文本进行批量操作
发表于 2016-3-9 16:34:34 来自手机 | 显示全部楼层 |阅读模式
比如将该文件夹下所有的txt文本的第一行删除之类的
麻烦大神们提供下大概的框架 谢谢
发表于 2018-10-10 14:43:44 | 显示全部楼层
用lisp里Open, read, write-line, close几个命令
发表于 2018-10-10 17:04:28 | 显示全部楼层
请先备份! 原始文件将被覆盖!
  1. (defun c:tt (/ *error* f fd fl fn l out str tmp)
  2.   (defun *error* (msg) (if f (close f)) )
  3.   (alert "\n文本的第一行删除!后果自负!")
  4.   (prompt "\n请选择文件夹 \n")
  5.   (if
  6.     (and (princ (setq fd (acet-ui-pickdir)))
  7.        (setq fl (vl-directory-files fd "*.txt"))
  8.        (foreach x fl
  9.          (and
  10.                 (setq l nil fn (strcat fd "\\" x)
  11.                       f  (open fn "r")
  12.                       )
  13.                 (while (setq str (read-line f)) (setq l (cons str l)))
  14.                 (progn (if f (close f))
  15.        (setq tmp (vl-filename-mktemp))
  16.        (setq out (open tmp "w"))
  17.        (foreach x (cdr (reverse l)) (write-line x out))
  18.               (if out
  19.                 (close out)
  20.                 )
  21.               (vl-file-delete fn)
  22.               (vl-file-rename tmp fn)
  23.               (terpri)
  24.               (princ x)
  25.               ) ;progn
  26.        ); and
  27.        ); foreach
  28.        ); and
  29.     (princ "\n执行完毕!")
  30.     (princ "\n无文件?")
  31.     )
  32.    (textscr)
  33.   (princ)
  34.   )
发表于 2018-10-15 20:34:58 | 显示全部楼层
小生有礼了,前来学习下
发表于 2019-3-29 08:04:03 | 显示全部楼层
谢谢! lisperado 分享学习!!!!!!
GMT+8, 2025-5-19 01:15 , Processed in 0.186074 second(s), 25 queries , Gzip On.
