查看: 24475|回复: 47
[函数] 拖进绘图区域自动加载至启动组
发表于 2016-3-22 11:42:54 | 显示全部楼层 |阅读模式
在论坛一直搜索不到一个现成的加入启动组的函数,写了一个跟大家分享
  1. (vl-Load-COM)
  2. (defun try-tuo-path(/ path str)
  3.   (princ "\n")
  4.   (setq path (getvar "lastprompt"))
  5.   (if (wcmatch (strcase path) "*(LOAD "*")
  6.     (setq str (vl-string-search "(LOAD "" path)
  7.       path (substr path (+ str 8) (- (vl-string-search "")" path) str 7))
  8.     )
  9.   )
  10.   (vl-string-translate "/" "\" path)
  11. )
  12. (defun try-appload-startup (path / i k n new-n strart-path)
  13.   (setq n
  14.     (vl-registry-read
  15.       (setq strart-path
  16.         (strcat "HKEY_CURRENT_USER\"
  17.           (vlax-product-key)
  18.           "\\Profiles\"
  19.           (getvar "CPROFILE")
  20.           "\\Dialogs\\Appload\\Startup"
  21.         ))
  22.       "NumStartup"
  23.     )
  24.     i 0
  25.     k T
  26.   )
  27.   (repeat (atoi n)
  28.     (setq i(1+ i))
  29.     (if(= path(vl-registry-read strart-path (strcat(itoa i)"Startup")))(setq k nil))
  30.   )
  31.   (if k
  32.     (progn
  33.       (vl-registry-write strart-path "NumStartup" (setq new-n(itoa (1+ (atoi n)))))
  34.       (vl-registry-write strart-path (strcat new-n "Startup") path)
  35.     )
  36.   )
  37. )
  38. ;;;程序开始
  39. (setq path(try-tuo-path))
  40. (if (= ":"(substr path 2 1))(progn(try-appload-startup path)(prompt "\n成功加载至启动组"))(prompt "\n本程序只能通过拖动来加载"))
  41. (prin1)
注:附件的内容跟帖子里面的源码是一样的,不过多了几句无关紧要的注释,附件只是方便大家下载
参与人数 6明经币 +6 收起 理由
szmaicy + 1
xiaocainiao + 1 很给力!
qiuhai1991 + 1 赞一个!
ymcui + 1 支持分享
vectra + 1 赞一个!
USER2128 + 1
本帖被以下淘专辑推荐:
  • · 工具|主题: 71, 订阅: 6
发表于 2016-3-22 11:48:18 | 显示全部楼层
;;;xshrimp 2011.7
参与人数 3明经币 +3 收起 理由
ymcui + 1 赞一个!
USER2128 + 1 赞一个!
tryhi + 1 赞一个!
回复 支持 3 反对 0
发表于 2024-6-10 18:54:49 | 显示全部楼层
楼主的代码,我,加载不成功。我用下面的代码,加载成功
(vl-load-com)
        (princ "\n")
        (setq path (getvar "lastprompt"));读取拖进黑框的路径
        (if (wcmatch (strcase path) "*(LOAD \"*")
                (setq str (vl-string-search "(LOAD \"" path)
                        path (substr path (+ str 8) (- (vl-string-search "\")" path) str 7))
        (vl-string-translate "/" "\\" path)
;(gps->appload-addfile "d:\\12.lsp")
(defun gps->appload-addfile (AppName /  $skey numstartup)
(if (= (type appname) 'STR)
  (setq  $skey (strcat "HKEY_CURRENT_USER\\"
                         (vlax-product-key)
                         "\\Profiles\\"
                         (getvar "CPROFILE")
                         "\\Dialogs\\Appload\\Startup")
  (setq NumStartup (vl-registry-read $skey "NumStartup"))
  (if NumStartup
    (vl-registry-write $skey (strcat (itoa (+ 1 (atoi NumStartup))) "Startup") AppName)
    (vl-registry-write $skey "NumStartup"(strcat (itoa (+ 1 (atoi NumStartup)))))
        (vl-registry-write $skey "0Startup" AppName)
    (vl-registry-write $skey "NumStartup" "1")
T
nil
(gps->appload-addfile (try-tuo-path))
参与人数 1明经币 +1 金钱 +5 收起 理由
tryhi + 1 + 5 赞一个!
发表于 2019-6-2 18:00:27 | 显示全部楼层
773786668 发表于 2016-4-6 19:11
不知道是不是电脑的问题,昨天拖入黑屏,重启后启动组里一直没有拖入的文件。
我的也是,不清楚为什么
发表于 2016-3-22 18:01:26 | 显示全部楼层
都是高手啊,只有膜拜的份儿,感谢!
发表于 2016-3-23 08:50:56 | 显示全部楼层
没明白啥意思,这个程序干啥用
发表于 2016-3-23 10:42:40 | 显示全部楼层
一定要顶一顶
发表于 2016-3-23 13:12:46 | 显示全部楼层
路过学习了
发表于 2016-3-28 11:00:40 | 显示全部楼层
有用,收藏了先
发表于 2016-3-28 11:31:50 | 显示全部楼层
Win7 64位的可能吗?
 楼主| 发表于 2016-3-28 12:10:53 | 显示全部楼层
gufeng 发表于 2016-3-28 11:31
Win7 64位的可能吗?
64位应该是可以的
实验失败了  发表于 2020-3-20 08:00
发表于 2016-3-28 17:40:47 | 显示全部楼层
有用
GMT+8, 2025-12-2 08:59 , Processed in 0.215418 second(s), 31 queries , Gzip On.
