查看: 1978|回复: 3
请帮我看一下这段设置图层的代码问题出在哪里?
发表于 2004-3-2 00:57:00 | 显示全部楼层 |阅读模式
(if (tblsearch "layer" "aaa") (command "layer" "ON" "aaa" "T" "aaa" "U" "aaa" "M" "aaa" "" )
(command "layer" "m" "xxx" "C" "6" "L" "dashed" "" "")
) 其中红色字体部分有什么问题呢 为什么该命令不能执行完而是出现“layer”命令的标准提示 而把红色部分分成两句例如 (command "layer" "m" "xxx" "C" "6" "" "")
(command "layer" "m" "xxx" "L" "dashed" "" "") 就没有这个问题了 这是为什么呢???
发表于 2004-3-2 01:17:00 | 显示全部楼层
(command "layer" "m" "xxx" "C" "6"[U] "xxx" [/U]"L" "dashed" "" "")
发表于 2004-3-2 11:13:00 | 显示全部楼层
这样就行了 (command "layer" "m" "xxx" "C" "6" "" "L" "dashed" "" "")
 楼主| 发表于 2004-3-2 18:30:00 | 显示全部楼层
多谢 多谢
GMT+8, 2025-5-14 06:00 , Processed in 0.157083 second(s), 25 queries , Gzip On.
