- 积分
- 512
- 明经币
- 个
- 注册时间
- 2015-1-5
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
(setq ss0 (ssget '((0 . "*LINE,ARC,ELLIPSE,CIRCLE"))))
(setq ss (ssget '((0 . "*LINE,ARC,ELLIPSE,CIRCLE"))))
(setq K -1)
(while (setq E (ssname ss0 (setq K (1+ K))))
(setq i -1 o (vlax-ename->vla-object e))
(while (setq a (ssname ss (setq i (1+ i))))
(if (eq a e)
nil
(setq ints (vlax-invoke o 'intersectwith (vlax-ename->vla-object a) acExtendNone))
(while ints
(setq pts (cons (list (car ints) (cadr ints) (caddr ints)) pts)
ints (cdddr ints)
(if pts
(setq dts (mapcar '(lambda (x) (vlax-curve-getdistatpoint o x)) pts))
(setq dts (vl-sort dts '>))
(setq p1 (vlax-curve-getpointatdist e (- x 30))
p2 (vlax-curve-getpointatdist e (+ x 30)))
(if (not p1)(setq p2 (vlax-curve-getstartpoint e)))
(if (not p2)(setq p2 (vlax-curve-getendpoint e)))
(command ".break" "_non" (list e p1) "_non" p2)
dts
