查看: 1007|回复: 0
[讨论] 求高手帮忙。对话框 toggle对象的$value值不能和KEY值同步
发表于 2016-4-6 17:54:09 | 显示全部楼层 |阅读模式
[url=]10 秒后保存[/url] [url=]保存数据[/url] | [url=]恢复数据[/url]    [url=]字数检查[/url] | [url=]清除内容[/url]    [url=]加大编辑框[/url] | [url=]缩小编辑框[/url]
(vl-load-com)
(defun c:xx1(/ lsfs  blls lsfx zdjd xcdx xcdy ycdx yxdy  dcl dd sl qgpta qgptb qgptc qgptd dist1 ss  en dista distb distc Lmax p1 p2)
  ;;;读取对话框的参数
  (setq lsfs (vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "lsfs"))
  (if (null (and lsfs (member lsfs '("ztls" "ftls" ))))
    (setq lsfs "ftls")
    (setq lsfx (vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "lsfx"))
  (if (null (and lsfx (member lsfx '("fxh" "fxsh" "fxs" ))))
    (setq lsfx "fxsh")
    (setq blls (vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "vvs"))
    (if (null blls) (setq blls "0"))
  (setq blls1 (vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "blls1"))
  (if (null blls1) (setq blls1 "0"))
      (setq zdjd (vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "zdjd"))
  (if (null (and zdjd (member zdjd '("ptz7" "ptz8" "ptz9"  "ptz4"  "ptz5" "ptz6" "ptz1" "ptz2" "ptz3"))))
    (setq zdjd "ptz1")
  (setq xcdx(vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "dist1^"))
  (if (null xcdx) (setq xcdx "2700"))
      (setq ycdx(vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "dist2^"))
  (if (null ycdx) (setq ycdx "1"))
  (setq xcdy(vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "dist3^"))
  (if (null xcdy) (setq xcdy "2700"))
  (setq ycdy(vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "dist4^"))
  (if (null ycdy) (setq ycdy "1"))
;;;读取对话框
  (setq dcl (load_dialog "C:/Program Files/Havis&CAD/Havis&CAD/对话框定义/墙体拉伸1.DCL"))
  ;(setq dcl (load_dialog "墙体拉伸1.DCL"))
  (setq dd 6)
  (while (> dd 1)
    (if (null (new_dialog "qglsX" dcl)) (exit))
   ;;获取对话框内各个对象的值
    (set_tile "lsfs" lsfs)
    (set_tile "lsfx" lsfx)
    (set_tile "blls" blls)
    (if (= lsfx "fxh")
     (foreach x '("xcdy"  "xcdisy" "ycdx" "ycdy" "yDisy" "yDisx")(mode_tile x 1))
    (if (= blls "blss")
     (foreach x '("xcdy"  "xcdisy"  "ycdy" "yDisy" )(mode_tile x 1)))
     (if (= lsfx "fxsh")
     (foreach x '("xcdx"  "xcdisx" "ycdx" "ycdy" "yDisy" "yDisx")(mode_tile x 1))
     (if (= blls "blss")
      (foreach x '("xcdx"  "xcdisx" "ycdx"  "yDisx")(mode_tile x 1)))
      (if (= lsfx "fxs")
     (foreach x '("ycdx" "ycdy" "yDisy" "yDisx")(mode_tile x 1))
    (if (= blls "blss")
    (foreach x '("ycdx" "ycdy" "yDisy" "yDisx")(mode_tile x 0)))
   (if (= blls "blss")
    ;;关闭不响应的控件
    (set_tile "zdjd" zdjd)
    (set_tile "xcdx" (VL-PRINC-TO-STRING xcdx))
    (set_tile "ycdx" (VL-PRINC-TO-STRING ycdx))
    (set_tile "xcdy" (VL-PRINC-TO-STRING xcdy))                ;距离
    (set_tile "ycdy" (VL-PRINC-TO-STRING ycdy))
     ;;调用按钮
    (action_tile "fxh" "(setq lsfx $key)
    (foreach x '(\"fxsh\" \"fxs\" )(set_tile x \"0\"))
    (foreach x '(\"xcdy\"  \"xcdisy\"  )(mode_tile x 1))
    (foreach x '(\"xcdx\"  \"xcdisx\"  )(mode_tile x 0))
    (if (= blls1 \"1\")
    (H_sub_blls $value))
    (action_tile "fxsh" "(setq lsfx $key)
    (foreach x '(\"fxh\" \"fxs\")(set_tile x \"0\"))
    (foreach x '(\"xcdy\"  \"xcdisy\"  )(mode_tile x 0))
    (foreach x '(\"xcdx\"  \"xcdisx\"  )(mode_tile x 1))
    (if (= blls1 \"1\")
    (action_tile "fxs" "(setq lsfx $key)
    (foreach x '(\"fxh\" \"fxsh\")(set_tile x \"0\"))
    (foreach x '(\"xcdy\"  \"xcdisy\"  \"xcdx\"  \"xcdisx\" )(mode_tile x 0))
    (if (= blls1 \"1\")
    (action_tile "blls" "(setq blls $key)(setq blls1 $value)
    (foreach x '(\"ycdy\"  \"yDisy\"  \"ycdx\"  \"yDisx\" \"blls1\" \"blls\")(mode_tile x 0))
    (foreach x '(\"blls1\") (set_tile x \"1\"))
    (if (= blls1 \"1\")
    (H_sub_blls $value)(foreach x '(\"ycdy\"  \"yDisy\"  \"ycdx\"  \"yDisx\" )(mode_tile x 1)))")
    (action_tile "xcdisx" "(getyx4)(done_dialog 2)")
    (action_tile "yDisx" "(getyx4)(done_dialog 3)")
    (action_tile "xcdisy" "(getyx4)(done_dialog 4)")
    (action_tile "yDisy" "(getyx4)(done_dialog 5)")
    (action_tile "accept" "(getyx4)(done_dialog 1)")
    (setq dd (start_dialog)) (null (wcmatch "534e5" "*[~0-9]*"))
    (cond
      ((= dd 2)
       (setq xcdx (getdist "\n确定距离:"))
       (if xcdx(setq xcdx xcdx))
       ((= dd 3)
       (setq ycdx (getdist "\n确定距离:"))
       (if ycdx (setq ycdx ycdx))
       ((= dd 4)
       (setq xcdy (getdist "\n确定距离:"))
       (if xcdy (setq xcdy xcdy))
       ((= dd 5)
       (setq ycdy (getdist "\n确定距离:"))
       (if ycdy (setq ycdy ycdy))
       );;cond
    );while
  (UNLOAD_DIALOG dcl);;退出对话框
  (if (= dd 1)
      (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "lsfs" lsfs)
      (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "vvs" blls)
      (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "blls1" blls1)
      (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "lsfx" lsfx)
      (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "zdjd" zdjd)
      (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "dist1^" xcdx);距离
      (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "dist2^" ycdx)
      (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "dist3^" xcdy)
      (VL-REGISTRY-WRITE "HKEY_CURRENT_USER\\Software\\Microsoft\\MyLispSettings\\chunxiaoyan" "dist4^" ycdy)
      (princ "\n*选择要拉伸的线条*")
      (setq ss (ssget))
      (if (null ss)(exit))
      (setq xcdx (atof xcdx))
      (setq ycdx (atof ycdx))
      (setq xcdy (atof xcdy))
      (setq ycdy (atof ycdy))
      );progn dd
    );if dd
;;获取对话框内各个对象的值
(defun getyx4()
  (setq lsfs (get_tile "lsfs"))
  (setq blls (get_tile "blls"))
  (setq blls1 (get_tile "blls1"))
  (setq lsfx (get_tile "lsfx"))
  (setq zdjd (get_tile "zdjd"))
  (setq xcdx (get_tile "xcdx"))
  (setq ycdx (get_tile "ycdx"))
  (setq xcdy (get_tile "xcdy"))
  (setq ycdy (get_tile "ycdy"))
(defun H_sub_blls(blls1)
  (if  (= blls1 "1")
    (if (= lsfx "fxh")
    (foreach x '("ycdx"  "yDisx")(mode_tile x 0))
    (foreach x '("ycdy"  "yDisy")(mode_tile x 1))
     (if(= lsfx "fxsh")
    (foreach x '("ycdx"  "yDisx")(mode_tile x 1))
    (foreach x '("ycdy"  "yDisy")(mode_tile x 0))
   (if(= lsfx "fxs")
   (foreach x '("ycdy"  "yDisy" "ycdx"  "yDisx" )(mode_tile x 0))
   );;progn
    (foreach x '("ycdy"  "yDisy" "ycdx"  "yDisx" )(mode_tile x 1))
(princ) 同时发表至新浪微博 开通此功能(将打开新窗口)
阅读权限售价设置主题标签
本版积分规则发表帖子 保存草稿 将此主题同步到: [url=]腾讯微博[/url]
附加选项
HTML 代码
[img] 代码
解析图片链接
禁用链接识别
禁用表情
禁用编辑器代码
使用个人签名
回帖仅作者可见
回帖倒序排列
接收回复通知
发送动态
GMT+8, 2025-10-27 05:10 , Processed in 0.170420 second(s), 26 queries , Gzip On.
