查看: 1058|回复: 2
[提问] 求高手优化选定层连续复制
发表于 2016-4-10 11:46:55 | 显示全部楼层 |阅读模式
5明经币
求高手帮小弟优化一下这个选定层连续复制程序,程序本身可用,但达不到CAD自带复制的视觉效果,不胜感激。
  1. (defun c:ccv (/ ss n ln ssl )
  2. (princ "\n指定图层选定物体复制")
  3. (princ "\n请选择目标层:")
  4.    (setq ssl (ssget))
  5.    (setq n 0)
  6.    (setq ln nil)
  7.    (repeat (sslength ssl)
  8.    (setq ln (append ln (list (cdr(assoc 8 (entget (ssname ssl n)))))))
  9.         (setq n (1+ n))
  10.   )
  11.   (princ "\n请框选要移动的图元:")
  12.        (setq ss (ssget (list (cons 8 (apply 'strcat (mapcar '(lambda (x) (strcat x ",")) ln))))))
  13.        (setq p1 (getpoint))
  14.        (while
  15.    (setq p2 (getpoint))
  16.          (command "_.copy" ss "" p1 p2 "")
  17.    )
  18.
  19.   (princ)
  20. )
发表于 2016-4-10 11:46:56 | 显示全部楼层
  1. (defun c:tt (/ ssl n la lst ss p1)
  3.   (princ "\n请选择目标层: ")
  5.         n   0
  6.   )
  8.     (setq la  (cdr (assoc 8 (entget (ssname ssl n))))
  9.           lst (if (not (member la lst))
  10.                 (cons la lst)
  11.                 lst
  12.               )
  13.           n   (1+ n)
  14.     )
  15.   )
  16.   (setq la (apply 'strcat (mapcar '(lambda (x) (strcat x ",")) lst)))
  17.   (princ "\n请框选要移动的图元: ")
  18.   (setq ss (ssget (list (cons 8 la))))
  19.   (setq p1 (getpoint))
  20.   (command "_.copy" ss "" "M" p1 pause)
  21.   (princ)
  22. )
tryhi + 1
发表于 2016-4-10 12:36:02 来自手机 | 显示全部楼层
选定图层(commond "copy" "")
GMT+8, 2025-10-27 05:08 , Processed in 0.161635 second(s), 28 queries , Gzip On.
