查看: 1142|回复: 0
[源码] 一个小插件
发表于 2016-4-24 17:33:13 | 显示全部楼层 |阅读模式
(defun c:resets()
(command"'_insunits" "0" )          ;;插入无单位
(command"zoomfactor""90")          ;;滚轮缩放比例
(command"lunits""2")                ;;单位毫米
(command"XFADECTL""50")             ;;块编辑淡显
(command"XDWGFADECTL""0")           ;;外参淡显
(command"osoptions""1")             ;;。。。
(command"insunitsdefsource""0")
(command"insunitsdeftarget""0")
(command"dimassoc""1")              ;;标注不关联
(command"measureinit""0")           ;;。。。
(command"aperture""21")             ;;拾取框,比较大
(command"bindtype""1")              ;;插入绑定
(command"autosnap""47")             ;;不追踪F11
(command"snapmode""0")              ;;捕捉关F9
(command"gridmode""0")              ;;栅格F7
(command"polarmode""4")             ;;仅仅正交
(command"polarang""90")             ;;增量角90度
(command"dynmode""0")               ;;F12标注输入
(command"selectionpreview""2")      ;;未激活命令不预览
(command"pickstyle""1")             ;;。。。
(command"rollovertips""0")          ;;不显示悬停工具
(command"tooltips""0")              ;;不显工具提示
(command"GRIPMULTIFUNCTIONAL""0")   ;;关掉夹点菜单
(command"polaraddang"".")           ;;无增量角
GMT+8, 2025-5-20 13:05 , Processed in 0.150844 second(s), 25 queries , Gzip On.
