查看: 1356|回复: 0
用ads改文字内容失败?
发表于 2016-4-25 10:16:48 | 显示全部楼层 |阅读模式
  1. BOOL chgEntDxf1(ads_name ent, wchar_t * str)
  2. {
  3.   struct resbuf *rbTargEnt;   // resbuf to hold ent data
  4.   struct resbuf *rbTrav;      // resbuf to traverse linked list
  5.   struct resbuf *tmp;
  6.   int rc;                     // Return code
  7.   wchar_t *sp2;
  8.
  9.   rbTargEnt = acdbEntGet(ent);
  10.   if(!rbTargEnt)
  11.   {
  12.     acutPrintf(_T("\nacdbEntGet失败. "));
  13.     return FALSE;
  14.   }
  15.   rbTrav = rbTargEnt;
  16.   while(rbTrav)
  17.   {
  18.     switch(rbTrav->restype)
  19.     {
  20.     case 1 : // 更改文字内容
  21.       //_tcscpy( rbTrav->resval.rstring,str);
  22.       tmp = acutBuildList(RTSTR, str, 0);
  23.       sp2 = rbTrav->resval.rstring;
  24.       rbTrav->resval.rstring = tmp->resval.rstring;
  25.       tmp->resval.rstring = sp2;
  26.       acutRelRb(tmp);
  27.       break;
  28.     }
  29.     rbTrav = rbTrav->rbnext;
  30.   }//while
  31.   rc = acdbEntMod(rbTargEnt);
  32.   if(rc != RTNORM)
  33.   {
  34.     acutPrintf(_T("\n更改dxf组码1失败,可能是对象图层锁定"));
  35.   }
  36.   //清理resbuf
  37.   if(rbTargEnt)
  38.   {
  39.     acutRelRb(rbTargEnt);
  40.   }
  41.   return TRUE;
  42. }
复制代码
先是直接_tcscpy( rbTrav->resval.rstring,str);   改lisp值,errno系统变量为2 Invalid entity or selection set name
有人说直接改dxf1组码的值会很危险,必须新建resbuf*,但errno系统变量为101,也不知道是什么错误号
GMT+8, 2025-12-7 06:05 , Processed in 0.162996 second(s), 27 queries , Gzip On.
