查看: 516|回复: 2
[源码] 求助:如何实现多选,且能同时修改单行文字和多行文字的字高
发表于 2016-4-26 00:54 | 显示全部楼层 |阅读模式
  • (defun C:Z2(/ a en1 ent len n newr nn oldr s ss test)
  •   (setvar "CMDECHO" 0)
  •   (setq test T nn 0)
  •   (while test
  •     (setq ss (ssadd))
  •     (setq ss (ssget))
  •     (if (= nil ss)
  •       (setq test nil)
  •       (progn
  •         (setq len (sslength ss))
  •         (setq n 1 s 1)
  •         (while (<= n len)
  •           (setq en1 (ssname ss (1- n)))
  •           (setq a (entget en1))
  •           (if  (= "TEXT" (cdr (assoc 0 a)))
  •             (progn
  •               (if (= s 1)
  •                 (progn
  •                   (setq oldr (cdr (assoc 40 a)))
  •                   ;(setq newr (getreal (strcat "\nNew high <" (rtos oldr 2 1) ">:")))
  •                   (setq newr(* 5 5 (getvar "celtscale")))
  •                   (if (= newr nil) (setq newr oldr))
  •                   (setq s nil)
  •               (setq ent (subst (cons 40 newr) (assoc 40 a) a))
  •               (entmod ent)
  •               (setq nn (1+ nn))
  •           (setq n (1+ n))
  •   (princ)
 楼主| 发表于 2016-4-26 00:55 | 显示全部楼层
  (setq test T nn 0)
  (while test
    (setq ss (ssadd))
    (setq ss (ssget))
    (if (= nil ss)
      (setq test nil)
                                (setq n 1 s 1)
                                (while (<= n len)
                                                        (if (= s 1)
        (setq s nil)
                                                        (entmod ent)
              (setq nn (1+ nn))
                                        (setq n (1+ n))
发表于 2016-4-26 08:24 | 显示全部楼层
(defun C:Z2 (/ a en1 ent len n newr nn oldr s ss test)
  (setq        test T
        nn 0
  (while test
    (setq ss (ssadd))
    (setq ss (ssget))
    (if        (= nil ss)
      (setq test nil)
        (setq n        1
              s        1
        (while (<= n len)
          (if (wcmatch (cdr (assoc 0 a)) "*TEXT")
              (if (= s 1)
                  (setq newr (* 5 5 (getvar "celtscale")))
                  (if (= newr nil)
                    (setq newr oldr)
                  (setq s nil)
              (entmod ent)
              (setq nn (1+ nn))
          (setq n (1+ n))
GMT+8, 2024-4-17 00:48 , Processed in 0.145921 second(s), 25 queries , Gzip On.
