查看: 885|回复: 3
关于按照颜色值筛选对象的问题
发表于 2016-4-30 06:01:11 | 显示全部楼层 |阅读模式
我想实现,通过点选一个实体,然后根据它的颜色,全部选中途中相同颜色的实体对象。我是通过读取TrueColor的ColorIndex属性来获取颜色索引值。但是有个问题了。当颜色值为256,既为bylayer类型时,就搞不定了。这种情况应该怎么做呢。谢谢
'按颜色选择相同颜色的实体对象:************************************
Sub PublicSub333()
On Error GoTo errhandle
     ThisDrawing.Utility.Prompt vbCrLf & "当前命令:颜色选择" & vbCrLf
'     Exit Sub
    Dim i As Long
    Dim k As Long
    Dim entityObj As AcadEntity '实体变量
    Dim nColor As Integer '颜色值
   '创建空白选择集
    Dim SelSet As AcadSelectionSet
    If ThisDrawing.SelectionSets.Count > 0 Then '如果选择集已经存在,删除
        For i = 0 To ThisDrawing.SelectionSets.Count - 1
           If ThisDrawing.SelectionSets.Item(i).Name = "SelSet" Then
              Set SelSet = ThisDrawing.SelectionSets.Item("SelSet")
              SelSet.Delete
              Exit For
           End If
        Next i
    End If
    Set SelSet = ThisDrawing.SelectionSets.Add("SelSet")
    ThisDrawing.Utility.GetEntity entityObj, setpoint, "请拾取对象:"
    nColor = entityObj.TrueColor.ColorIndex '获取颜色值
    '0为block,256为bylayer,
    Dim FilterType(0) As Integer
    Dim FilterData(0) As Variant
    Dim lyObj As AcadLayer
    Set lyObj = ThisDrawing.Layers.Item(entityObj.Layer)
    If nColor = 256 Then '颜色为bylayer时不能刷选??????????????????????
       nColor = lyObj.TrueColor.ColorIndex
    End If
    FilterType(0) = 62
    FilterData(0) = nColor
    SelSet.Select acSelectionSetAll, , , FilterType, FilterData '将目标颜色所有对象添加到选择集中
    SelSet.Highlight True
    Exit Sub
errhandle:
    If Err.Number = -2147352567 Then
       ThisDrawing.Utility.Prompt "取消选择" & vbCrLf
    Else
       ThisDrawing.Utility.Prompt vbCrLf & Err.Number & vbCrLf
       ThisDrawing.Utility.Prompt vbCrLf & Err.Description & vbCrLf
    End If
End Sub
发表于 2016-5-2 21:08:30 | 显示全部楼层
    End If
把这段代码删掉就行了,画蛇添足
 楼主| 发表于 2016-5-3 06:10:52 | 显示全部楼层
删了不行,所有按照bylayer的实体颜色值都是256,但是颜色是不一样的。要是删除了,都当成一样选择了
发表于 2016-5-3 19:54:44 | 显示全部楼层
哪估计得选完再过滤了
GMT+8, 2025-5-23 23:23 , Processed in 0.152911 second(s), 23 queries , Gzip On.
