查看: 683|回复: 0
[提问] Sizing Mtext box through VBA
发表于 2016-5-10 17:00:55 | 显示全部楼层 |阅读模式
What is the command for resizing the MText box. I can control the width with the.Width property but the.Height property only changes the text height and not the box height.
反应器里面是不可以用entmod的,只能用vba。
当然如果lisp可以LockDocument就最好了,不需要用vba,直接用dxf就行。
GMT+8, 2025-5-20 11:37 , Processed in 0.163927 second(s), 29 queries , Gzip On.
