查看: 1144|回复: 2
[讨论] 加载影像图插件,求大神给加一条批量打开的代码。
发表于 2016-5-10 17:45:51 | 显示全部楼层 |阅读模式
(defun c:insg()
  (VL-LOAD-COM)
  (setq AcadObject(vlax-get-acad-object)
        AcadDocument(vla-get-ActiveDocument Acadobject)
        mSpace(vla-get-ModelSpace Acaddocument)
  (setq imageName (getfiled "指定政区数据文件" "*.*" "jpg;tif" 2))
;;; 读取并计算tfw文件参数
  (setq tfwname (strcat (substr imageName 1 (- (strlen imageName) 3)) "tfw"))
  (setq fp (open tfwname "r"))
  (setq reco (read-line fp) ii 1)
  (setq chat nil)
  (while reco
     (setq chat (append (list reco) chat))
     (setq reco (read-line fp) ii (1+ ii))
   )  ;end while
  (close fp)
  (setq pt (list (atof (nth 1 chat)) (atof (nth 0 chat)) 0))
  (setq bl (atof (nth 5 chat)))
  (setq insertionPnt(vlax-make-safearray vlax-vbDouble '(0 . 2)))
  (vlax-safearray-fill insertionPnt pt )
;;; 在模型空间中建立一个光栅图像
  (setq RasterObj(vla-AddRaster mSpace imageName insertionPnt 1 0))
  (setq width (vla-get-Width RasterObj))
  (setq height (vla-get-height RasterObj))
  (vla-put-ImageWidth RasterObj (* width bl))
  (vla-put-Imageheight RasterObj (* height bl))
  (command "move" (entlast) "" (list 0 (* height bl)) (list 0 0))
  (command "zoom" "e" "zoom" "0.8x")
发表于 2016-9-24 23:36:18 | 显示全部楼层
不建议批量加载,因为影像文件一般都很大,如果批量加载可能会导致CAD崩溃。
发表于 2019-4-23 01:20:43 | 显示全部楼层
qq群114378090有fas的批量插入影像的插件.
GMT+8, 2025-5-19 01:25 , Processed in 0.167936 second(s), 26 queries , Gzip On.
