查看: 2016|回复: 10
[已解答] excel单元格自动换行问题
发表于 2016-6-7 17:36:30 | 显示全部楼层 |阅读模式
如果用lisp设置excel单元格自动换行?谢谢!
发表于 2016-6-8 10:33:16 | 显示全部楼层
  1. (defun zdhh () ;A1单元格设置为自动换行
  2.   (setq ExcelApp (vlax-get-object "Excel.Application"))
  3.         (setq range (vlax-get-property ExcelApp "range" "A1"))
  4.         (vlax-put-property range "WrapText" :Vlax-true)
  5.         )
USER2128 + 1 很给力!
 楼主| 发表于 2016-6-8 10:55:39 | 显示全部楼层
819534890 发表于 2016-6-8 10:33
非常感谢!好人一生平安,今年必定发大财。
 楼主| 发表于 2016-6-8 11:12:26 | 显示全部楼层
可以再问一个问题吗?如何用lisp设置多个单元的外侧框线(非所有框线),如图所示,谢谢!
发表于 2016-6-8 12:56:47 | 显示全部楼层
  1. (defun bk () ;设置区域B2:F5区域的外框
  3.         (setq range (vlax-get-property ExcelApp "range" "B2:F5"))
  4.         (setq range_B (vlax-get-property range "Borders"))
  5.         (setq range_l (vlax-get-property range_B 'item 7))
  6.         (vlax-put-property range_l "LineStyle" 1)
  7.         (vlax-put-property range_l "ColorIndex" -4105)
  8.                 (vlax-put-property range_l "TintAndShade" 0)
  9.                 (vlax-put-property range_l "Weight" 2)
  10.
  11.                 (setq range_t (vlax-get-property range_B 'item 8))
  12.         (vlax-put-property range_t "LineStyle" 1)
  13.         (vlax-put-property range_t "ColorIndex" -4105)
  14.                 (vlax-put-property range_t "TintAndShade" 0)
  15.                 (vlax-put-property range_t "Weight" 2)
  16.
  17.                                         (setq range_bt (vlax-get-property range_B 'item 9))
  18.         (vlax-put-property range_bt "LineStyle" 1)
  19.         (vlax-put-property range_bt "ColorIndex" -4105)
  20.                 (vlax-put-property range_bt "TintAndShade" 0)
  21.                 (vlax-put-property range_bt "Weight" 2)
  22.
  23.                 (setq range_r (vlax-get-property range_B 'item 10))
  24.         (vlax-put-property range_r "LineStyle" 1)
  25.         (vlax-put-property range_r "ColorIndex" -4105)
  26.                 (vlax-put-property range_r "TintAndShade" 0)
  27.                 (vlax-put-property range_r "Weight" 2)
  28.
  29.                                                 (setq range_iv (vlax-get-property range_B 'item 11))
  30.         (vlax-put-property range_iv "LineStyle" -4142)
  31.
  32.                                                 (setq range_ih (vlax-get-property range_B 'item 12))
  33.         (vlax-put-property range_ih "LineStyle" -4142)
  34.
  35.
  36. )
USER2128 + 1 很给力!
 楼主| 发表于 2016-6-8 15:03:14 | 显示全部楼层
819534890 发表于 2016-6-8 12:56
谢谢!高手啊,太帅了,设置单元格保留小数点位数如何实现?
发表于 2016-6-8 16:10:05 | 显示全部楼层
不错收藏了
发表于 2016-6-8 16:28:38 | 显示全部楼层
感谢 819534890 分享程序,学习了!
发表于 2016-6-9 09:44:33 | 显示全部楼层
有了前边两个作为基础,在EXCEL的VBA里边把前两个手动做一下录制成宏,对照一下
再把你最后这个在EXCEL里边手动做出来录制所宏,差不多就知道该怎么写了
 楼主| 发表于 2016-6-11 10:58:39 | 显示全部楼层
再把你最后这个在EXCEL里 ...
谢谢提示,解决了,感谢大家的帮助,谢谢!
GMT+8, 2025-5-20 08:02 , Processed in 0.167637 second(s), 27 queries , Gzip On.
