查看: 1909|回复: 2
[提问] 指定起点终点连接PL线
发表于 2016-6-11 10:37:45 | 显示全部楼层 |阅读模式
求助:指定起点终点连接PL线
发表于 2016-6-12 11:34:04 | 显示全部楼层
用附件程序,自己再修改一下。
发表于 2022-9-5 15:06:27 | 显示全部楼层
荒野孤行作品
;;;连点成线
(defun c:t1 (/ ptlist)
  (setvar "blipmode" 0)
  (setvar "pickfirst" 1)
  (setvar "expert" 0)
  (setvar "GRIPOBJLIMIT" 50)
  (setvar "osmode" 15359)
  (setvar "cmdecho" 0)
  (princ "\n★功能:将邻近的点连接为一条曲线。\n")
  (vl-load-com)
  (princ "\n请选择要连接的点对象:\n")
  (command "undo" "be")
  (setq ss (ssget '((0 . "POINT"))))
  (if (null ss)
    (progn (princ "\n提示:未选取点对象!") (exit))
  (initget "P S")
  (if (not
        (setq kw
               (getkword
                 "曲线样式:[多段线(P)/样条曲线(S)]<S>"
    (setq kw "S")
(setq i 0)
  (setvar "osmode" 0)
  (repeat (sslength ss)
    (setq entnam (entget (ssname ss i))
          pt         (cdr (assoc 10 entnam))
          ptlist (cons pt ptlist)
          i         (1+ i)
  (setq        ptlist (vl-sort        ptlist
                        '(lambda (e1 e2)
                           (if (equal (car e1) (car e2) 1e-5)
                             (if (equal (cadr e1) (cadr e2) 1e-5)
                               (< (cadr e1) (cadr e2))
                               (< (car e1) (car e2))
  (if (= kw "P")
      (command "pline")
      (foreach pt ptlist (command pt))
      (command "")
      (command "spline")
      (command "" "" "")
  (command "undo" "e")
GMT+8, 2025-6-1 09:30 , Processed in 0.180414 second(s), 29 queries , Gzip On.
