查看: 2162|回复: 3
[已解答] 关于多段线的打断与合并
发表于 2016-6-30 16:56:37 | 显示全部楼层 |阅读模式
请教如何将 打断与合并的lisp源码合在一起,使打断一条多段线的同时   将打断的多段线合并
打断可直接用(command "break" pause "f" pause "@")
合并可使用 “jion”
请老师教我
 楼主| 发表于 2016-6-30 17:04:14 | 显示全部楼层
老师教我
发表于 2016-7-1 00:16:12 | 显示全部楼层
  1. (defun c:ts (/ e en p pt)
  2.         (while (setq p (getpoint))
  3.                 (progn
  4.                         (cond
  5.                                 ((null (setq e (nentselp p)))
  6.                                         (princ "\nPoint does not lie on an LWPolyline.")
  7.                                 )
  8.                                 ((= 4 (length e))
  9.                                         (princ "\nObject is Nested.")
  10.                                         (setq e nil)
  11.                                 )
  12.                                 ((/= "LWPOLYLINE" (cdr (assoc 0 (entget (setq en (car e))))))
  13.                                         (princ "\nObject is not an LWPolyline.")
  14.                                         (setq e nil)
  15.                                 )
  16.                         )
  17.                         (if (and e p en (setq pt (vlax-curve-getclosestpointto en (trans p 1 0))))
  18.                                 (progn
  19.                                         (command "_.BREAK" e "F" pt "@")
  20.                                         (command "_.pedit" (entlast) "j" en "" "")
  21.                                 )
  22.                         )
  23.                 )
  24.         )
  25. )
 楼主| 发表于 2016-7-1 08:54:56 | 显示全部楼层
xiaolong1487 发表于 2016-7-1 00:16
谢谢老师,完美解决
GMT+8, 2026-1-21 04:34 , Processed in 0.165539 second(s), 29 queries , Gzip On.
