查看: 1731|回复: 0
获取多重引线样式WDAGAIN 的属性,输出到命令行
发表于 2016-7-7 15:17:30 | 显示全部楼层 |阅读模式
大侠看看这个程序这么改,获取多重引线样式WDAGAIN 的属性,输出到命令行
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(GetMleaderStyle.GetMlStyle))]
namespace GetMleaderStyle
    public class GetMlStyle
        [CommandMethod("GMlS")]
        public static void  GetMlSty()
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            using (Transaction acTrans = db.TransactionManager.StartTransaction())
                //获取所有多重标注样式
                DBDictionary MlStyleList = acTrans.GetObject(db.MLeaderStyleDictionaryId, OpenMode.ForRead) as DBDictionary;
                MLeaderStyle myMleaderStyle = new MLeaderStyle();
               //判断当前文件是否存在多重标注样式WDAGAIN,如果不存,执行下边语句。
                if (MlStyleList.Contains("WDAGAIN"))
                myMleaderStyle = acTrans.GetObject(MlStyleList["WDAGAIN"], OpenMode.ForRead) as MLeaderStyle;
                    //获取多重标注样式WDAGAIN的ArrowSymbolId属性。
                ObjectId MyArrowSymbol = myMleaderStyle.ArrowSymbolId;
                double MyTextHeight = myMleaderStyle.TextHeight;
                    // 调用Editor对象的WriteMessage函数在命令行上显示文本
                ed.WriteMessage( MyArrowSymbol );
                ed.WriteMessage( MyTextHeight );
               acTrans.Commit();//回收内存
GMT+8, 2025-11-21 07:27 , Processed in 0.164978 second(s), 27 queries , Gzip On.
