查看: 1822|回复: 3
[提问] (求助)属性块文字直接替换
发表于 2016-7-25 01:37:49 | 显示全部楼层 |阅读模式
有没有一个办法在属性块里,我只要输入B1 他就将附档机种里的ABC值替换成123  ,输入B2他就换成456,求大神帮帮忙设定一下。。谢谢啦
发表于 2016-7-26 03:08:44 | 显示全部楼层
  1. (DEFUN CHATTRIB (OLDATT NEWATT)
  2. (IF (AND (PRINC "\nSelect Block with attribute 选择带属性图块 :")
  3.           (SETQ SS (SSGET '((0 . "INSERT") (66 . 1))))) (PROGN
  4.   (SETQ I -1)
  5.   (REPEAT (SSLENGTH SS)
  6.    (SETQ ENT (ENTGET (SSNAME SS (SETQ I (1+ I))))
  7.          ENT1 ENT)
  8.    (WHILE (= (CDR (ASSOC 0 (SETQ ENT1 (ENTGET (ENTNEXT (CDR (ASSOC -1 ENT1))))))) "ATTRIB")
  9.     (IF (= (CDR (ASSOC 1 ENT1)) OLDATT) (PROGN
  10.   (SETQ ENT1 (SUBST (CONS 1 NEWATT) (ASSOC 1 ENT1) ENT1))
  11.   (ENTMOD ENT1)
  12.   (ENTMOD ENT)
  13. ))
  14.    )
  15.   )
  16. ))
  17. (PRINC)
  18. )
  19. (DEFUN C:A11 (/ input)
  20.   (setq input (getstring "\输入b1/b2<b1>:"))
  21.   (if (= input "")
  22.       (setq input "b1")
  23.   )
  24.   (IF (= input "b1")
  25.       (SETQ OATT "ABC" NATT "123")
  26.       (SETQ NATT "ABC" NATT "456")
  27.   )
  28.   (CHATTRIB OATT NATT)
  29. (PRINC)
发表于 2023-3-21 14:22:59 | 显示全部楼层
感谢大佬分享
GMT+8, 2025-9-19 04:12 , Processed in 0.133729 second(s), 25 queries , Gzip On.
