查看: 2044|回复: 2
[已解答] 以下是等分线画XL线的源码,请问怎么取消首尾的两根XL线只保留中间的.
发表于 2016-7-26 19:23:42 | 显示全部楼层 |阅读模式
3明经币
(defun c:daa1 () ( c:dfx1)(princ))
(defun c:dfx1 (/ nn p1 p2 rr tt-df)
  (setvar "CMDECHO" 0)
  (defun tt-df (p1 p2 nn / dd rr ptn)
    (setq dd (/ (distance p1 p2) nn 1.0)
          rr (angle p1 p2)
          ptn (list p1)
    (repeat (1- nn)
      (setq p1 (polar p1 rr dd)
            ptn (cons p1 ptn)
    (reverse(cons p2 ptn))
  (setq p1 (getpoint "\n第一点: ")
        p2 (getpoint p1 "\n第二点: ")
        nn  (getint "\n等分数量<2>")
        rr (angle p1 p2)
        (if (null nn) (setq nn 2))
  (foreach x (tt-df p1 p2 nn)(command -s "xline" "_non" x "_non" (polar x (+ rr (* pi 0.5)) 1.0) ""))
最佳答案
查看完整内容
(foreach x (tt-df p1 p2 nn)(command -s "xline" "_non" x "_non" (polar x (+ rr (* pi 0.5)) 1.0) "")) 改成 (foreach x (cdr (reverse (cdr (tt-df p1 p2 nn)))) (command -s "xline" "_non" x "_non" (polar x (+ rr (* pi 0.5)) 1.0) ""))
发表于 2016-7-26 19:23:43 | 显示全部楼层
改成
 楼主| 发表于 2016-7-26 21:03:08 | 显示全部楼层
太给力了.谢谢你了,兄台.
GMT+8, 2025-12-3 10:43 , Processed in 0.157656 second(s), 28 queries , Gzip On.
