查看: 1695|回复: 1
[几何] BoundaryRepresentation怎么获取边界
发表于 2016-7-29 22:41:57 | 显示全部楼层 |阅读模式
  1.                 ObjectId[] ids = new ObjectId[] { solid.ObjectId };
  2.                 SubentityId subentId = new SubentityId();
  3.                 FullSubentityPath path = new FullSubentityPath(ids, subentId);
  4.                 List<SubentityId> edgePath = new List<SubentityId>();
  5.                 using (Brep brep = new Brep(path))
  6.                 {
  7.                     foreach (Edge edge in brep.Edges)
  8.                     {
  9.                         edgePath.Add(edge.SubentityPath.SubentId);
  10.                     }
  11.
  12.                 }
  13.                 for (int i = 1; i < edgePath.Count; i++)
  14.                 {
  15.                     Autodesk.AutoCAD.Colors.Color col = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByColor, (short)i);
  16.                     solid.SetSubentityColor(edgePath, col);
  17.                 }
根据教程上的,倒是能给边界改颜色了,怎么能获取边界的类型,是直线还是曲线,然后创建实体呢?
 楼主| 发表于 2016-7-29 23:00:35 | 显示全部楼层
好像可以了,用CopyEdge就行
GMT+8, 2025-5-24 13:44 , Processed in 0.188948 second(s), 23 queries , Gzip On.
