查看: 533|回复: 1
[讨论] 这个出了什么问题
发表于 2016-8-5 20:54:27 | 显示全部楼层 |阅读模式
(defun c:SS(/ zhouchang mianji mm a name)
  (setq zhouchang 0)
  (setq mianji 0)
  (setq mm 0)
  (setq a nil)
(if (setq a (ssget))
    (setq name (ssname a 0))
        (command "area" "o" name)
        (setq mianji (getvar "area"))
        (setq zhouchang (getvar "perimeter"))
(setq mm (+ (* zhouchang 500) mianji))
  (print (list "mm=" mm))
发表于 2016-8-5 21:51:01 | 显示全部楼层
  1. (defun c:SS (/ zhouchang mianji mm a name)
  2.   (setq zhouchang 0)
  3.   (setq mianji 0)
  4.   (setq mm 0)
  5.   (setq a nil)
  6.   (if (setq a (ssget))
  7.     (progn
  8.       (setq name (ssname a 0))
  9.       (command "area" "o" name)
  10.       (setq mianji (getvar "area"))
  11.       (setq zhouchang (getvar "perimeter"))
  12.       (setq mm (+ (* zhouchang 500) mianji))
  13.       (print (list "mm=" mm))
  14.     )
  15.   )
  16.   (princ)
  17. )
GMT+8, 2025-5-20 06:42 , Processed in 0.155699 second(s), 26 queries , Gzip On.
