查看: 1159|回复: 1
[提问] 关于WBLOCK写块路径的问题
发表于 2016-8-24 10:33:59 | 显示全部楼层 |阅读模式
(defun c:wg()
  (setvar "filedia" 0)
  (setq k 1)
  (while (= k 1)
    (initget 1)
    (setq wb_na(getstring "\n输入所用输出文件的名称:"))
(setq wb_na "D:\\My Documents")
    (if (= wb_na "") (exit))
    (initget 1)
    (setq base_pt (getpoint "\n选择基点:"))
    (setq wb_ss (ssget))
    (if (= wb_ss nil) (exit))
    (command "-wblock" wb_na "" base_pt wb_ss"")
  (setvar "filedia" 1)
各位大侠,麻烦看下为什么不能写到设定的路径文件夹下
发表于 2016-8-24 10:50:14 | 显示全部楼层
加上文件名再试试
GMT+8, 2025-5-20 06:16 , Processed in 0.214263 second(s), 25 queries , Gzip On.
