- 积分
- 17991
- 明经币
- 个
- 注册时间
- 2010-11-4
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
公司装有64位的AutoCAD2012,但是OFFICE套件都是32位的,ACCESS数据库引擎也是32位的。又没有管理员权限装64位数据库引擎。
借助VBA ADO访问ACCESS,将记录写入字典,再通过LISP将字典中的数据读出。
LISP部分:假定dvb文件名为ado.dvb,且在CAD支持路径中,宏名为ado
(defun ado(dbase strrs)
(vl-load-com)
(setvar "users4" dbase)
(setvar "users5" strrs)
(dictadd (namedobjdict) "MyDict" (entmakex '((0 . "DICTIONARY")(100 . "AcDbDictionary"))))
(vl-vbaload (findfile "ado.dvb"))
(vl-vbarun "ado")
(vl-vbaunload (findfile "ado.dvb"))
(setq recordset (mapcar '(lambda(w)(mapcar 'cdr (vl-remove-if-not '(lambda(z)(= (car z) 1)) w)))(mapcar '(lambda(y)(entget (cdr y)))(vl-remove-if-not '(lambda(x)(= (car x) 350))(dictsearch (namedobjdict) "MyDict")))))
(setvar "users4" "")
(setvar "users5" "")
(dictremove (namedobjdict) "MyDict")
VBA部分,需引用Microsoft ActiveX Data Objects 2.x Library
Dim Cn As New ADODB.Connection
Dim Rs As New ADODB.Recordset
Dim dbase As String
Dim strCn As String
Dim strRs As String
Sub ado()
Dim fld As ADODB.Field
Dim Dict As String
Dim strfld As String
Dim strRec As String
Dim i As Integer
Dim j As Integer
Dim TrackingDictionary As AcadDictionary
Dim TrackingXRecord As AcadXRecord
Dim ArraySize As Long
Dim XRecID As String
Dim XRecordDataType As Variant
Dim XRecordData As Variant
dBase = ThisDrawing.GetVariable("users4")
strCn = "Provider=Microsoft.JET.OLEDB.4.0;Data Source=D:\" & dBase & ".mdb"
strRs = ThisDrawing.GetVariable("users5")
Cn.Open strCn
If Left(strRs, 6) = UCase("SELECT") Then
Set TrackingDictionary = ThisDrawing.Dictionaries.Item("MyDict")
With Rs
.Open strRs, Cn, adOpenStatic, adLockOptimistic
XRecID = "K000"
Set TrackingXRecord = TrackingDictionary.AddXRecord(XRecID)
ArraySize = .Fields.Count - 1
ReDim XRecordDataType(0 To ArraySize) As Integer
ReDim XRecordData(0 To ArraySize) As Variant
j = 0
For Each fld In Rs.Fields
XRecordDataType(j) = 1
XRecordData(j) = fld.Name TrackingXRecord.SetXRecordData XRecordDataType, XRecordData
j = j + 1
Next
i = 1
Do While Not .EOF
Select Case i
Case 1 To 9
XRecID = "K00" & CStr(i)
Case 10 To 99
XRecID = "K0" & CStr(i)
Case Else
XRecID = "K" & CStr(i)
End Select
For j = 0 To ArraySize
If IsNull(.Fields.Item(j).Value) Then
XRecordData(j) = ""
Else
XRecordData(j) = .Fields.Item(j).Value
End If
Next j TrackingXRecord.SetXRecordData XRecordDataType, XRecordData
.MoveNext
i = i + 1
Loop
.Close
End With
Else
Cn.Execute (strRs)
End If
Cn.Close
End Sub
调用方法:如果存在数据库d:\test.mdb;并且有表test且其中字段都是文本。可在lisp中调用(ado "test" "SELECT * FROM test")来获取表中数据,存放在变量recordset中,之后就可以对recordset进行进一步操作了。函数的第一个参数是放在D盘根目录下的数据库名,第二个参数是SQL语句。SQL语句第一个词是SELECT,则recordset有新数据,如果是INSERT、DELECT、UPDATE等词,则只操作数据库而无新记录返回。本程序没有加入数据库操作出错的处理,所有的功能仅在数据库有效执行的情况下测试。本程序仅说明lisp在不能直接操作数据库时的一种变通方法,直接操作的程序请参考Gu版和无痕的程序。有兴趣的可以发展新功能。 |
