查看: 4676|回复: 24
[提问] 这个程序有时会漏选
发表于 2016-9-9 16:00:30 | 显示全部楼层 |阅读模式
(defun c:tjj()
  (setvar "cmdecho" 0)
  (setvar "osmode" 1)
  (command "osnapcoord" 2)
  (command "ucs" "w")
  (command "layer" "s" "txt" "")
  (setq p4 (getpoint "\n 请输入图框左下角:"))
  (setq p5 (getpoint "\n 请输入图框右上角:"))
  (setq p1 (getpoint "\n 请输入要统计的左下角:"))
  (setq x1 (car p1) y1 (cadr p1))
  (setq p0 (getpoint "\n 请输入要统计的右上角:"))
  (setq p3 (getpoint "\n 请输入统计文字位置:"))
  (setq x4 (car p4) x5 (car p5))
  (setq w (- x5 x4))
  (setq h (* (/ w 280) 2))
  (setq p8 (getpoint "\n 请输入座标放置位置:"))
  (setq p9 (polar p8 0 (* 4 h)))
  (setq p10 (polar p8 0 (* 14 h)))
  (setq p11 (polar p8 0 (* 22 h)))
  (setq p12 (polar p8 (* 1.5 pi) h))
  (setq p13 (polar p11 (* 1.5 pi) h))
  (command "line" p12 p13 "" "")
  (setvar "osmode" 0)
  (command "text" "ml" p9 h 0 "X")
  (command "text" "ml" p10 h 0 "Y")
  (setq txt "ABCDEFGHIJKLMNOPQ")
  (setq ss (ssget "w" p1 p0 '((-4 . "<or") (0 . "arc") (0 . "circle") (-4 . "or>"))))
  (setq i 1)
  (setq pt p3)
  (while ss
     (setq en (ssname ss 0))
     (setq end (entget en))
     (setq rad (+ (cdr (assoc 40 end)) 0.000))
     (setq pci (cdr (assoc 0 end)))
     (setq d (rtos (* 2 rad)))
     (setq ssa (ssget "w" p1 p0 (list (cons 40 rad) (cons 0 pci))))
     (setq nn (sslength ssa))
     (setq stxt (substr txt i 1))
     (setq m 0)
     (setq x 0)
       (repeat nn
          (setq een (ssname ssa m))
          (setq eend (entget een))
          (setq cen (cdr (assoc 10 eend)))
          (setq xxx (- (+ 0.000 (car cen)) x1))
          (setq yyy (- (+ 0.000 (cadr cen)) y1))
          (setq xxxt (rtos xxx))
          (setq yyyt (rtos yyy))
          (setq ssb (ssget "x" (list (cons 10 cen))))
          (setq nnn (sslength ssb))
            (if (= nnn 2)
                 (setq f (ssname ssb 0))
                 (setq g (ssname ssb 1))
                 (setq fn (entget f))
                 (setq gn (entget g))
                 (setq radf (+ (cdr (assoc 40 fn)) 0.000))
                 (setq radg (+ (cdr (assoc 40 gn)) 0.000))
                 (setq radma (max radf radg))
                 (setq radmi (min radf radg))
                 (setq p2 (polar cen (* 1.75 pi) (+ 4 radma)))
                 (if (= rad radf) (setq ss (ssdel g ss)) (setq ss (ssdel f ss)))
                 (if (= rad radf) (setq hn fn) (setq hn gn))
                 (setq ty (cdr (assoc 0 hn)))
                 (setq dma (rtos (* 2 radma)))
                 (setq dmi (rtos (* 2 radmi)))
                 (if (= ty "CIRCLE") (setq sssstxt (strcat " %%c" dma "<CB>")) (setq sssstxt (strcat " M" dma)))
                 (setq ssstxt (strcat "-%%C" dmi "<THR>" sssstxt))
               (setq p2 (polar cen (* 1.75 pi) (+ 3 rad))
                     ssstxt (strcat "-%%C" (rtos (* 2 rad) 2 3) "<THR>"))
          (setq x (+ 1 x))
          (setq xt (itoa x))
          (setq xtxt (strcat stxt xt))
          (setq xxxxt (strcat xtxt ":"))
          (command "text" "ml" p2 h 0 xtxt)
          (setq p8 (polar p8 (* 1.5 pi) (* 2 h)))
          (setq p9 (polar p9 (* 1.5 pi) (* 2 h)))
          (setq p10 (polar p10 (* 1.5 pi) (* 2 h)))
          (setq p11 (polar p11 (* 1.5 pi) (* 2 h)))
          (command "line" (polar p8 (* 1.5 pi) h) (polar p11 (* 1.5 pi) h) "" "")
          (command "text" "ml" p8 h 0 xxxxt)
          (command "text" "ml" p9 h 0 xxxt)
          (command "text" "ml" p10 h 0 yyyt)
          (setq ss (ssdel een ss))
          (setq m (+ 1 m))
     (setq sstxt (strcat stxt " : " (itoa nn) ssstxt))
     (command "text" "ml" pt h 0 sstxt)
     (setq i (+ i 1))
     (setq pt (polar pt (* 1.5 pi) (* 1.5 h)))
  (setvar "osmode" 7)
(prinl)
发表于 2016-9-18 14:44:41 来自手机 | 显示全部楼层
(defun c:tjj ()
  (setvar "osmode" 1)
  (command "ucs" "w")
  ;(command "layer" "s" "txt" "");; 没有这个层就去掉吧
;;;  (setq p4 (getpoint "\n 请输入图框左下角:")) 只是为了取字高 可以和P1 P0共用 减少操作吧
;;;  (setq p5 (getpoint "\n 请输入图框右上角:"))
  (setq p1 (getpoint "\n 请输入图框左下角:"))
  (setq        x1 (car p1)
        y1 (cadr p1)
  (setq p0 (getcorner p1 "\n 请输入图框右上角:"));;;可以用这个带有特效的
  (setq        x4 (car p1);;;;
        x5 (car p0);;;;
  (setq w (- x5 x4))
;;;  (setq p8 (getpoint "\n 请输入座标放置位置:")) 也是为了减少操作
  (setq p8 (polar p3 0.06 80))
  (setvar "osmode" 0);;
  (command "line" p12 p13 "");; 语法多了 ""
  (setq ss (ssget "w" p1 p0 '((0 . "circle"))));;;单个弧不再处理
  (setq i 1)
  (setq pt p3)
  (while (> (sslength ss) 0)
    (setq rad (cdr (assoc 40 end)));;;
    (setq d (rtos (* 2 rad) 2));;; 不加指定的话 可以出意外啊 下面也一样
    (setq m 0)
    (setq x 0)
    (repeat nn
;;;      (setq xxx (- (+ 0.000 (car cen)) x1))
;;;      (setq yyy (- (+ 0.000 (cadr cen)) y1))
      (setq xxx (- (car cen) x1))
      (setq yyy (- (cadr cen) y1))
      (setq xxxt (rtos xxx 2));;;
      (setq yyyt (rtos yyy 2));;;
      (setq ssb (ssget "w" p1 p0 (list (cons 10 cen))))
      (if (= nnn 2)
        (progn (setq f (ssname ssb 0))
;;;               (setq radf (+ (cdr (assoc 40 fn)) 0.000))
;;;               (setq radg (+ (cdr (assoc 40 gn)) 0.000))
               (setq radf (cdr (assoc 40 fn)))
               (setq radg (cdr (assoc 40 gn)))
               (if (= rad radf)
                 (setq ss (ssdel f ss));;上下调换
                 (setq ss (ssdel g ss));;
               (if (= rad radf)
                 (setq hn gn);;上下调换
                 (setq hn fn);;
               (setq dma (rtos (* 2 radma) 2 0));;;消零
               (setq dmi (rtos (* 2 radmi) 2));;;;
               (if (= ty "CIRCLE")
              ss     (ssdel een ss);;; D
      (setq x (+ x 1));;;语法
      (setq xt (itoa x))
      (command "line" (polar p8 (* 1.5 pi) h) (polar p11 (* 1.5 pi) h) "");;语法多了 ""
      ;;;(setq ss (ssdel een ss)) D 放到上面去
      (setq m (1+ m));;;语法
    (setq i (1+ i));;;语法
  (setvar "osmode" 7)
  (princ);;;没见过这函数,自定义的吗?
都是搞模具的 给你改了 拿去看看效果吧
 楼主| 发表于 2016-9-21 15:51:01 | 显示全部楼层
革天明 发表于 2016-9-21 14:45
你先看看统计出的数量对不对
谢谢。请问:程序你做了改动了吗?编码序号全变成a1 a2 a3,,,,,,,没有b  c  d,,,,  失去了孔径大小区分功能。
r弧统计,要是能做到只识别270度圆弧就好了,非270度圆弧忽略不统计,要不然干脆所有圆弧都不统计
目前只有坐标列表,孔径以及对应编码那部分列表好像不在了
此外,编码a1 a2 a3,,,,,,,b1 b2 b3,,,c1 c2 c3,,,,,的排序要是能从左下角开始,从左到右 从下到上  那样排就好了
辛苦你了,这是个很烦人是程序,,我都不好意思了,麻烦了你们各位这么多人
发表于 2016-9-21 21:45:50 | 显示全部楼层
皇上快溜 发表于 2016-9-21 15:51
谢谢。请问:程序你做了改动了吗?编码序号全变成a1 a2 a3,,,,,,,没有b  c  d,,,,  失去了孔径大小区分功 ...
我不是修改程序,我是重新写了一个
我上次还提了你想要实现的功能,意思是你最终想要的效果(最好是dwg文件而不是图片),这样大家给你写一个就行了,
我就没看你提供的源程序,因为我看这么多人都在改来改去的,还不如新写一个
你把想要有效果写清楚,要是早这样的话,估计新程序都能用了,改程序最好找原作者改,否则花在改程序的时间有可能重新写也能完成了
 楼主| 发表于 2016-9-9 16:19:41 | 显示全部楼层
该程序的选择方式(setq ss (ssget "w" p1 p0 '((-4 . "<or") (0 . "arc") (0 . "circle") (-4 . "or>"))))有点特别。不知他的原理是怎样的。
有时它会漏选,如图:
尝试将(setq ss (ssget "w" p1 p0 '((-4 . "<or") (0 . "arc") (0 . "circle") (-4 . "or>"))))中的(0 . "arc") 删掉,漏选更多,基本上一碰到圆弧图元,就不再往下统计。
这两句:(setq p4 (getpoint "\n 请输入图框左下角:"))
只是为了确定字高(setq w (- x5 x4))         的吗?
不知它与(setq ss (ssget "w" p1 p0 '((-4 . "<or") (0 . "arc") (0 . "circle") (-4 . "or>"))))中的(0 . "arc") 选取动作有什连系?
另外,它的编码a1 a2 a3,,,b1 ,, b1,,排序方式是从右上角开始的。
尝试将   (setq p1 (getpoint "\n 请输入要统计的左下角:"))
的p1  p0 对调多来,包括这两句后面的所有p1  p0 对调多来,它的编排序还是从右上角开始的。
想请各位前辈指点一下,想弄清楚其中的原理,跟大家学学,谢谢各位
 楼主| 发表于 2016-9-14 00:47:31 | 显示全部楼层
弱弱顶一次
 楼主| 发表于 2016-9-14 00:48:07 | 显示全部楼层
弱弱顶一次,,,求解答
发表于 2016-9-14 01:18:41 | 显示全部楼层
(setq ss (ssget "c"
                p1
                p0
                    (list (cons 0 "ARC,CIRCLE"))
发表于 2016-9-14 01:19:18 | 显示全部楼层
(setq ss (ssget "c"
                p1
                p0
发表于 2016-9-14 01:20:10 | 显示全部楼层
(setq ss (ssget "c" p1 p0  (list (cons 0 "ARC,CIRCLE"))))
 楼主| 发表于 2016-9-14 15:26:59 | 显示全部楼层
谢谢楼上,,(setq ss (ssget "c" p1 p0  (list (cons 0 "ARC,CIRCLE"))))还是会漏选,不知怎么会这样
发表于 2016-9-14 16:05:21 来自手机 | 显示全部楼层
并没有漏选,(ssget "w") 和 (ssget "c") 只能选当前显示范围内的图元,应该是缩放导致显示不完整
解决办法可以加一句 (command "zoom" "e"),或者在命令前手动缩放到合适大小(能看到所需的全部图元)
 楼主| 发表于 2016-9-14 16:36:08 | 显示全部楼层
谢谢Sylvanas,,,是图元完整显示状态下选取的,还是那样
GMT+8, 2025-11-24 21:47 , Processed in 0.279027 second(s), 32 queries , Gzip On.
